Question about World Tech Toys Saturn-X 2-Channel RC Helicopter w/ Gyro, LED Lights, Durable Metal
I cant turn on my trio
Its been charging all night
I charged my new trio 8x s 4G quad core tabletYesterday, Plugged it in To recharge it Last night And it won't recharge Help me
Interesting - possible that it is not low enough on charge for the charger to operate?
Is the charger working and connected properly to wall outlet?
Sep 25, 2015 | Tablets & eReaders
Trio tablet wont turn on
sounds like the hard drive is froze up
Mar 08, 2014 | Mach Speed Speed Tablet Trio Stealth G2 7"...
My trio stealth g2 7" tablet wont turn on
Check for a bad battery, charger in that order.
Each can be gotten inexpensively on ebay. eBayeBay
Sep 04, 2017 | Trio Stealth G2 7 inch Tablet with 8GB...
What number do u do if ur trio stealth pro is not working
More then likely you powered the unit on before it had enough of a charge to operate, Chargers for these types of tablets are way to little power for these things, will hold the charge when you use it but will not charge the unit when you use it, needs to go into standby to charge. Hold the power button and see if you can get a reboot screen or a turn unit off screen. Turn the unit off fully let it charge up alll the way then powere the unit back on. Should reset it. If not look for a small hole in the unit that says reset. push this and see what happens.
Nov 28, 2013 | Mach Speed Trio Stealth Pro Trio Stealth...
My trio stealth g2 won't turn on the battery drained last night so I put it on charge and in the morning I took it off and I pushed the power button and all it said was trio stealth g2 and it thats all...
there are several things u can try to reset it. but i have not seen many of reset and continue to work without having other problems. check out this link first.
http://youtu.be/jcreuqRxK6w
there is a reset on the back of the tablet..l use a paper clip and push the reset button and hold it until it turns off and then push the power and the sound buttons together ..sound button up. if this does
work use the power cord to charge it. if this fails return it with the link i use above..
good luck
chad man
Sep 01, 2013 | Mach Speed Trio Stealth G2 Tablet -...
Trio won't hold charge.
For some reasons, trios **** at charging. Your trio probably isn't charging at all for some reason, like mine won't right now. I think they might be pieces of ****!
Mar 22, 2010 | Digital Audio TRIO MP3 Player
My Genesis Mp3 player 8GB does not turn on. When set for charging, it just says loading... Please help. Thank you.
1. let it charge all night long (8 hours)
2. put power switch in on mode.
3. hold "play" button 5 or more seconds until the mp3 player turns on.
If these steps fail, send it back and get a replacement. Better to start fresh than try to fiddle with it.
Sep 16, 2009 | Mach Speed TRIO Onyx MP3 Player
World Tech Toys Saturn-X 2-Channel RC Helicopter w/ Gyro, LED Lights, Durable Metal Logo
363 people viewed this question
Top World Tech Toys Crafts & Hobbies Experts
R.A. Ellis
R.A. Ellis
Debbie
Are you a World Tech Toys Craft and Hobby Expert? Answer questions, earn points and help others
