Question about Master Products EP323 15-Sheet Duo Electric/Battery Punch, Two- and Three-Hole Fixed Position Sides MATEP323 MAT EP323
Makes a horrible sound and only one side comes down to punch
It jammed and we removed the paper. Now when you try to punch even a single piece of paper it makes a groaning sound for about thirty seconds and you can see that only one pin comes down.
Swingline 74030 manual hole punch handle is locked down
by locked down I am going to assume you mean it will not go back to the normal postion when it is not making a hole. this can be caused by too many of the scrap pieces of paper that are left from making the hole. clogging the punch area. remove all the excess pieces of paper that may be stuck in the whole punch, then try again, you may have to pry the handle and or push and pull it until it releases. do not use again until the handle moves smoothly, clean the areas around the punch.
Mar 07, 2014 | Swingline 74030 Manual Hole Punch SWI74030
Brother 2170W, toner is stuck after paper jammed. I try to pull out the toner (even with force!) but it stuck, there is a paper at the bottom that i can't pull either. I guess this paper holds the...
If the paper get stuck inside the printer you can also remove it fro the back of it. Open the back cover and try to remove the jammed paper inside of the printer. If still the paper can't be remove try again to removed the drum and toner.
Open the front cover or pull down the cover right above the brother logo infront of the machine then hold the handle of the drum and toner assembly.Pull the drum and toner assembly towards you, just put a little force on it. Then remove the jammed paper.
Just to make sure, remove the toner from the drum by holding down the tab on the side and lift the toner out. Look for any small piece of paper inside of the drum unit. Reinstall the toner back to the drum. reinstall the drum and toner back to the machine, make sure that you here a click sound. After that close the front and back cover.
The blue light should lit up again.
Hope this helps. Thanks
May 06, 2011 | Brother HL-2170W Laser Printer
Paper jam MFC 685 CW
Hello there
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Mar 10, 2010 | Brother MFC-685cw InkJet Printer
Printer says paper jam, now scanner wont work
you will need to open it to remove this piece of paper.
Aug 14, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
Brother MFC-9420CN Paper Jam Error message w/ loud grinding noiz
please try this
  1. Turn off the printer.
  2. Remove any paper trays. Inspect them for wrinkled or damaged paper.
  3. Also open the back cover of the printer if this model has one.
  4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
  6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
  7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
  8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
  9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
  10. see alternative if the problem is still not solved.
alternative :
Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
Jun 09, 2009 | Brother MFC-9420CN All-In-One Laser...
Cannot clear paper jam on L7580.
give this a try
try this, its probably a small part of jammed paper or then theres a problem with the pickup, try cleaning it.
alternative :
Apr 01, 2009 | HP Officejet Pro L7580 All-In-One InkJet...
Paper Jam light
Make sure paper is loaded properly (pushed down under the end clips.) There could be a small piece stuck in the rollers somewhere. Look from the side door.
Aug 20, 2008 | Canon PC-920 Black and White Copier
MP470, Paper jam on one side
There is something jammed in there....shake it upside down first.....if nothing then revese feed a paper through it manually......take left side off hold paper in front and roll wheel on the left side so the paper feeds back into the machine,,,,,,open top to see in there and when paper feeds under white rollers make sure it dosent jam where wite rollers are about an inch from the right there is a small rectangle hole with a black plastic piece in there pry it up carfullywith a paper clip and feed paper with the wheel under it at that point the paper push out a bobby pin into my back tray,,,,, now everything works great.......keep checking i didn't believe something was there either but there was..... also if your paper first starts to feed and stops pull out the paper and check for a bend or crinp in it mine kept doing that and that is exactly where the pin finally came out.....
Feb 01, 2008 | Canon PIXMA MP470 All-in-One Printer
Brother MFC paper jams on one side
Honestly? Unplug the machine...REMOVE THE DRUM UNIT!!!!! and other parts not locked down. Turn it upside down and shake it lightly to moderately. You can also try holding the lever forward while you do this. This has worked for so many machines you would be surprised. You might be even more surprised what comes out. I have seen pens, pieces of ceiling tiles, wire clippings, Matchbox cars, and grape jelly (I didn't ask).
Dec 16, 2007 | Brother MFC 6800 All-In-One Laser Printer
Brother MFC - 7420: Paper will not feed!
Does it make the same sound if you feed the single sheet through the bypass with the paper drawer removed? I hate to say it, but your printer's paper feed mechanism may need replaced. Go to http://www.brother-usa.com/AskUs/default.aspx and ask Brother to diagnose this one; I think they'll confer with me and should be able to point you to a nearby Brother-authorized repair center. Let me know what happens!
May 07, 2007 | Brother MFC 7420 All-In-One Laser Printer
Master Products EP323 15-Sheet Duo Electric/Battery Punch, Two- and Three-Hole Fixed Position Sides MATEP323 MAT EP323 Logo
360 people viewed this question
Top Master Products Office Equipment & Supplies Experts
k24674
Are you a Master Products Office Equipment and Supply Expert? Answer questions, earn points and help others
