Question about Giant Warp DS 2
Tire pressure How much air pressure do I put in?
    Problem Solver:
  • 7 Answers
The tire pressure will vary a bit depending on what activities u are doing but as far as I know the minimum pressure should be about 35 lbs for some off roading .dut if u ar to know for sure the pressure markings are on side wall of tyres.
Posted on Oct 15, 2014
Abs /vsa light on
A direct-sensing type Tire pressure warning system is used in TPMS
If the vehicle continues to be driven with 1 or more of the 4 inflated to a low air pressure that could cause problems during driving, this system will illuminate the tire pressure warning light to inform the driver of the low air pressure.
In addition to that, this system directly senses the air pressure of each Tire through Tire pressure warning system valve & transmitter that are attached to each wheel.
Before you could proceed you are required to please retrieve the error codes and freeze frame data to get to know about the problem.
Aug 12, 2013 | 2007 Honda Element LX
Does the service tire monitoring system cause the check engin light to come on
sound like two problems service tire light and check engine light.have vechicle code scan and put air in all four tires make sure put correct amount air pressure in all four tires.
Feb 26, 2013 | 2008 Chevrolet Impala
Hi will the tire rest light come on when one put more air than what is suppose to be? thanks
tire rest light? the tire pressure light may come on, but should go out when all tires have the correct pressure. the pressure listed on the drivers door, NOT the pressure on the tire.
Sep 08, 2011 | 2004 Ford Freestar
How do i get rid of the low tire pressure light on a 2001 chevy impala 3.6liter 6cyl?
Put air in whichever tire is low and the light should go off. Use a manual tire pressure gauge to find out which tire needs the air.
Jul 05, 2011 | 2004 Chevrolet Impala
2005 toyota highlander, what is the correct tire pressure? Cannot get the air pressure light out after pressing the reset button. What do you suggest. I put 32 lbs of air in the tires
Look on the end of the drivers door or door jam for a sticker that should list the pressures and tire size. I had air removed from my tires and installed nitrogen. It keeps the right level better and doesn't cause the sensors to go bad like air can. $5 a tire at most tire dealers.
Nov 08, 2010 | 2005 Toyota Highlander
Why does it show the message: LOW TIRE PRESSURE
there is a tire pressure sensor on each tire check the air pressure on each tire and recalibrate the system each time you put air in any of the 4 tires or if any of the tire gets low air.Its like teaching the system on the present tire air pressure.One thing more the valve on each tire are special valve that have electronic part inside so make sure you dont replace them with an ordinary tire valve.Recalibrating shld be done on workshops with the proper tool
Jan 30, 2010 | 2008 Ford Focus
Low tire pressure indicator is on. I have put the
if u have the right tire pressure in the tires the light will go out . but sometimes you have to put 5 to 10 miles on the car to reset
Nov 16, 2009 | 2007 Volkswagen EOS Convertible
To erase tire pressure reading
Make sure you put air in tthe tires, then find the reset button in the fuse box inside the car if not you can unplug the battery then put the battery back on.
Mar 28, 2009 | 2000 Buick Park Avenue
How mush air i need to put in my golf gti 2.0 year 2000
well that depends on how much air the tire requires if the tire requires 32 psi you will need at least that much to fill your tire and so on
Mar 24, 2009 | Air Tools & Compressors
Giant Warp DS 2 Logo
61 people viewed this question
Top Giant Cycling Experts
John Egan
John Egan
Mark Schmit
Mark Schmit
dante
Are you a Giant Cycling Expert? Answer questions, earn points and help others
