Question about HEWLETT-PACKARD HP Pavilion dm4-1165dx Notebook
CPU not functional
Screen blank. Cap lock blinked once for CPU not functional
I have an hp G42 notebook when i hit the power button i hear it turn on but nothing happens only the caps lock key light begins to blink
hp blink error code:
caps lock blink once: cpu error
caps lock blink twice: bios problem
etc,,,,
please, what is the numer of the blink ?
Feb 14, 2014 | Computers & Internet
Blank screen
Failed to boot. The most usual cause of this fault is a GPU issue. Overheating problem.
Jan 11, 2013 | Compaq Presario CQ40 Series Laptop Charger...
I have a HP Pavilion tx 2000 tablet pc. When i turn it on the power button it shows that its on. The hard drive light does not flash and the caps lock and the number lock button keeps on blinking. My...
Hi
Boss you need to mention here in what sequence do the lights blink.
Anyways you can take help from this
Caps Lock/Num Lock LED Component Tested Error Condition LEDs blink 1 time CPU CPU not functional LEDs blink 2 times BIOS BIOS corruption failure LEDs blink 3 times Memory Module error not functional LEDs blink 4 times Graphics Graphics controller not functional LEDs blink 5 times System board General system board failure LEDs blink 6 times BIOS BIOS authentication failure
DO RATE MY SOLUTION
Jul 04, 2011 | Compaq Presario Notebook
The capslock and the numlock leds r flashing continously. the screen is blank
How many blinks between pauses if there are pauses? Look at this chart.
Number of Blinks or Beeps Location of Blinking LEDs Component Being Checked Error Condition Continuous glow Battery power LED Battery The AC adapter is attached and the battery is charging, but does not yet have sufficient charge to power the notebook. 1 Caps Lock/Num Lock CPU CPU not functional 2 Caps Lock/Num Lock BIOS BIOS corruption failure 3 Caps Lock/Num Lock Memory Module error not functional 4 Caps Lock/Num Lock Graphics Graphics controller not functional 5 Caps Lock/Num Lock System board General system board failure 6 Caps Lock/Num Lock BIOS BIOS authentication failure Continuous blink AC power adapter LED Power adapter Insufficient power
Jun 30, 2011 | Compaq Presario Notebook
When i turn on my hp the screen stays blank and there is no pic screen seems dead the lock a button is also flashing is this normal
hi,
nope this is not normal. I have a article included below from hp. read this and you will understand the problem and also some ways on how to fix it. The blinking lights is a code on where the system fail or what component that fails.
Hope this helps you.
Don't forget to rate me OK!
Thanks for using Fixya!
regards,
John
HP Black screen error codes
Support details
This document pertains to HP Notebook PCs with the HP Unified Extensible Firmware Interface (UEFI) beginning in late-2008.
On startup, you may see a blank screen. If the diagnostic utilities detect a specific problem with hardware components, the fan turns on, but the screen remains blank. To help identify the cause of the problem, various LED lights on the keyboard blink a series of codes.
The diagnostic utilities use the LEDs near the Num Lock or Caps Lock keys to blink a series of error codes. At the end of the series the blinking stops. The pattern of blinks will occur any time you attempt to start the computer until the error is resolved.
Battery power LED blinks
The Battery power LED indicates the condition of the power supply. When starting the computer, or when the computer is in operation, use the chart to identify the power condition.
Battery low charge or failure
Battery power LED blinking Battery Insufficient charge on the battery
LEDs near Caps Lock and Number Lock keys blink when starting notebook
The LED lights near the Caps Lock and Num Lock keys will blink if an error is detected during the start up process. The LEDs will blink a number of times in a sequence and then stop. The number of blinks in the sequence indicates what component caused an error when it was being tested during start up.
If the LEDs stop blinking and the computer does not start, you can press the power button again to repeat the tests. Count the number of blinks, and use the chart to identify the error condition.
Knowing the number of blinks is helpful when you contact an HP support agent for technical help.
Error code explanations
The sections below provide some common explanations for each error code listed in the table above.
AC Adapter not connected or battery low charge
When the computer is on battery power only and the AC adapter is disconnected, if the Battery Power and Caps Lock / Number Lock LEDs do not glow, there is either a very low change or no charge in the battery. Connect the AC power adapter, verify that the battery power LED glows, allow the battery to charge for 15 - 30 minutes and then attempt to start the computer. If it starts, run the battery test and calibrate the battery. If it does not start, if possible, connect a replacement battery to verify that the battery is the problem.
If the computer does not start after charging the battery, remove the battery and connect the AC power supply. Verify that the battery power LED glows, and then attempt to start the computer. If the LED still does not glow, either the AC adapter has failed, or there is a bad connection between the adapter and the system board. If possible, connect a different AC power adapter to verify that the adapter is the problem, or contact HP for support which may require a service event.
showhide
If the battery light LED (which looks like a lightning bolt ) flashes, the battery has insufficient charge to start the computer. To resolve this error, try the following solutions.
Connect the notebook PC to AC power and attempt to start the computer again.
o
Check the AC adapter to confirm that all of the plugs are securely seated.
o
Determine if the power LED on the AC adapter is lit (if available) to verify that the computer is receiving AC power from the wall outlet.
If the computer operates on AC power correctly, charge the battery for thirty minutes to one hour and then restart the computer.
NOTE: Charging the battery for this length of time is called "trickle charging". Trickle charging is a continuous constant-current charge at a low rate, which recharges the battery slowly when it is in a deep discharge state. Deep discharge occurs when a battery is left unused for extended periods of time.
The computer processor (Blink code 1) has stopped functioning properly. Contact HP for assistance.
If a BIOS corruption error occurs (Blink code 2), you may not even notice the blink codes, because as soon as the computer recognizes the error, it restarts, attempts to recover the BIOS, and then restarts again. You may notice an extra-long startup process as a result, and a message indicating that the BIOS has been recovered may display on startup. If this occurs, update the BIOS on the computer. For more information, refer to the HP Notebook PCs - Locate and Install Updated BIOS, Drivers, and Software .
If you experience a memory failure (Blink code 3), follow the guide in the table below.
If Using Original Memory If New Memory Is Added
Reseat the memory.
If reseating the memory does not resolve the problem, try replacing the memory with new memory. Reseat the memory.
If you continue to experience this error code after reseating the memory, the problem may be with the memory itself. Take the new memory out of the computer, put the original memory back into the computer, and then retest it.
If you do not feel comfortable reseating the memory yourself, take the computer to a computer retailer and ask them to reseat it for you.
NOTE: Some memory module errors may allow the computer to start but will then cause the computer to restart and display a blinking error code.
If you experience a graphics controller failure (Blink code 4), contact HP for assistance.
A general system board failure (Blink code 5) is the failure of a component not covered by the other LED error codes. Contact HP for assistance.
The BIOS authentication error (Blink code 6) is extremely rare. It is the result of a discrepancy between the BIOS and the hardware that is installed on the computer. This error occurs when the BIOS cannot authenticate signatures from the hardware on the system. The purpose of the BIOS authentication is to be sure that no one has tampered with the BIOS on the computer.
If a BIOS authentication failure occurs, the computer automatically performs a BIOS recovery. If the computer does not automatically recover the BIOS, manually perform a BIOS recovery. To manually perform a BIOS recovery, press all four arrow keys at the same time to cause the BIOS to go to the EFI partition to find and recover the current BIOS.
Jan 17, 2011 | HP Compaq nc6220 Notebook
Power light comes on but not working
First you need to determine how many blinks you are getting when you try to power on the laptop. Check the blinking codes below and reason behind that for HP Compaq laptops Blinking battery power LED Battery Insufficient charge on the battery Blink: 1 - Caps Lock/Num Lock - CPU CPU not functional Blink: 2 - Caps Lock/Num Lock - BIOS BIOS corruption failure Blink: 3 - Caps Lock/Num Lock - Memory Module error not functional Blink: 4 - Caps Lock/Num Lock - Graphics Graphics controller not functional Blink: 5 - Caps Lock/Num Lock - System board General system board failure Blink: 6 - Caps Lock/Num Lock - BIOS BIOS authentication failure You need to first Remove the memory module (RAM)- Try to power on the laptop ? then again reset it and try to power on. Check whether it is coming on or not. try the same procedure with Hard drive. If laptop is getting power on after removing one of the device then we can be sure that that particular device is faulty and we can change that then? Let me know if you find any difficulties doing this.. I hope this will help you to get it work. Plz vote for me..Dreamkam
May 27, 2010 | Computers & Internet
Compaq 6735s notebook pc goes to HP screen, but wont boot
Plz get back so I can suggest you the steps to resolve the issue.
Dreamkam
May 24, 2010 | HP Compaq 6735s Notebook
My hp dv7 screen stays black and has cap lock, num lock lcds are blinking once. How do I find out if I need to replace or is it possible to repair the cpu?
I would attach an external monitor. The monitor select (function F5 on many laptops) will work if the computer is running.
If an external monitor has a picture (i think it will), then the LCD screen needs repair.
May 04, 2010 | HP Pavilion dv7-1245dx Notebook
My laptop does no more boot up. As soon as i start , the caps lock and the scroll lock lights keep flashing continuously and the fan even does not run.
Well hellonihar, As far as your issue is concerned it seems to be some hardware issue. LED
Component
Error Condition
Battery
CPU
CPU not functional
BIOS
Memory
Graphics
System board
BIOS
Apr 19, 2010 | HP Pavilion dv5-1000us Notebook PC
Dead T4220 - 4 beeps @ POST & blinking lock symbol, screen blank
this beeps are signal of a dead cpu or memory. Check with manufacturer to confirm diagnostics.
Jul 08, 2009 | Fujitsu LifeBook T4220 (A1A5J1A414B30000)...
HEWLETT-PACKARD HP Pavilion dm4-1165dx Notebook Logo
Top HEWLETT-PACKARD Computers & Internet Experts
Bilal Ahmed Qureshi
Michael Vincent Cruz
Are you a HEWLETT-PACKARD Computer and Internet Expert? Answer questions, earn points and help others
