Question about Skyworth SLC1369A 13" LCD TV/DVD Combo with 13.3" LED Back Light Panel
TV stuck in standby mode
Battery ok on remote, nothing works.
What does it mean when your tv states standby and you cannot turn it on or off with the remote control?
How to Fix a Sony Plasma TV With a Standby Problem ...
smallbusiness.chron.com > Finances & Taxes > Other Finances & Taxes
A standby mode problem on your plasma TV can result in the TV being stuck instandby mode, ... You can troubleshoot a standby mode error by performing a power cycle or restoring the TV to its factory settings. ... Turn the television on. ... What Does It Mean When My Rumor Touch Says the Camera Is in Standby Mode?
tv on standby mode cant get it off - TV - Streaming Video & TVs
www.tomsguide.com/answers/id-1676193/standby-mode.html
Dec 27, 2015 | Televison & Video
Ive just bought a 22 inch lg tv, tuned in ok but remote is now not working, wont do anything, wont even put tv in standby mode. Any ideas?
unplug tv, take batteries out of remote. plug tv back in, replace batteries. best idea i have. sometimes that resets the devices. good luck
Mar 05, 2015 | LG 22LV2500 22" Inch 720p Widescreen LED...
Lc195emx stuck in standby mode
Hi D
Sounds like the Switch Mode Power Supply is failing to Power Up.
Often Caused by Bad Electrolytic Capacitors inside the Power Supply Circuitry.
Probably a replaceable PCB Module.
Take it in to your dealer or Electronics technician.
Cheers
Mar 03, 2015 | Televison & Video
How do I get out of video mode if remote will go to tv mode?
there should be several buttons along one side of the tv that work all functions . if remote is not working try new batteries
Feb 11, 2015 | Emerson LD190EM1 19 in. LCD TV/DVD Combo
Tv standby
If your TV is stuck in standby mode, and does not wake up with the remote, either the remote is faulty (did you check the remote batteries?) or the TV is. Inexpensive current TVs do not have manual buttons on the TV, they depend on the remote for everything.
Jul 30, 2014 | Panasonic Televison & Video
Apex at2002 tv stuck in standby mode
A universal remote control might not work with this set properly. You should try to buy its original one.
Jul 27, 2013 | Apex Digital Televison & Video
My tv is stuck in stand by,and my remote does't switch on the tv
Television is not the main remote control from behind or the side
Feb 15, 2013 | LG MKJ42519615 Remote Control
Olevia 437-S11 stuck in standby mode
My classroom TV seems to be stuck in standby mode. Blue light is on but TV won't turn on either by push button or remote.
Oct 24, 2008 | Olevia LT37HVS 37 in. LCD HDTV
Tv stuck in standby
If you can not turn on TV set with the power button on the TV its not a standby problem as this would by pass the standby. Theres most likly, on a set of this age, top have a poiwer regulator problem and is going to need a trained tech to assist you in this repair.
Sep 10, 2006 | Sony KV-32S42 32" TV
Skyworth SLC1369A 13" LCD TV/DVD Combo with 13.3" LED Back Light Panel Logo
Top Skyworth Televison & Video Experts
Are you a Skyworth Televison and Video Expert? Answer questions, earn points and help others
