Question about First Degree Fitness Viking AR Fluid Water Rower
I have a Viking AR rower brand new in box but its missing the seat rail, I have tried the email address for the manufactuer withiout sucess anybody ordered parts for these machines???
Seat rail needed for Viking AR rowing machine
I entered the wrong email address to access my iCloud account and need to know how to change it.
your original email address is your iCloud acct email, unless you changed the acct info. if you just mistyped, then retype because you could not get into a mistyped email address and get in. or is it a locked acct your are trying to break into?
May 26, 2016 | Apple - iPad Air 2 Wi-Fi 64GB
Scan to Email Configuration, Step by Step
Just set up email as normal, scan doc to pc,check docs or scan folder on pc for scanned doc, open new email and click the attach icon, navigate to scanned doc folder, highlight and press ok, then type address and send.
Feb 22, 2015 | Konica Minolta Minolta BIZHUB 3320 BRAND...
Setting up a new toshiba laptop and the account name I have entered is incorrect. I put in a new email address but it's wrong. How do I fix this?
if you change the laptop name it should make no difference to your old email address being used. you can open your emails on almost anybody's laptop as long as you know your email address and password, do not save the settings for your email on anybody else's pc. you can set up many different email accounts as you want within reason.
Sep 20, 2013 | Toshiba Computers & Internet
Missing my AR 5316 Driver CD. Pleass Send this Driver software my email address.
Drivers for Sharp AR-5316 are available at Sharp Official Support site. Make selection as under: -
Select
AR5316 > Windows (XP, Vista, Windows 7 etc) Depending upon the OS you have.
Good Luck!
Appreciate generously, if the solution could have been of any help!
CreativeTECH
Jan 10, 2011 | Sharp AR-5316 Advanced Digital Imager...
How to add email address to AR-BC320 copier
Hello connie_durha, Thank you for the clarification. Try the following:
  1. Type the ip address into your web browser and press enter.
  2. A printer information page will appear for your Sharp printer.
  3. There should be a section for email (it might be labeled "sender").
  4. A login box may popup- login name is admin / password is Sharp
  5. Once you are in click "add."
  6. Fill in the required boxes and optional if necessary.
  7. Once everything is filled in click "submit."
  8. Your email address should now be added to the printer.
Please post a reply with any issues. Hopefully this helps. Thank you for using FixYa! Edward
Aug 24, 2010 | Sharp AR-BC320 All-In-One Led Printer
Problem with Viking stove griddle knob shaft
Abalos, we will be happy to assist you with your parts for the Viking griddle knob.
We provide free diagnostic information when you tell us what brand and model number you are having issues with.
We are available from 7 AM – 7 PM CST. We also provide part removal/installation instructions for our customers when parts are purchased through us.
It is our goal to get you back up and running again ASAP, so please contact us when you need us to help you.
We look forward to hearing you and hope that you have a terrific day. Thank you, Ella
http://www.fixya.com/repair/d499389-accurate_appliance_repair_service
Mar 08, 2010 | Viking VGIC485-6G Gas Kitchen Range
Nordic Rower replacement wheel
Nordic Rowers were made by Water Rowers, which still exists and sells parts.
Aug 18, 2009 | Nordic Track Exercise & Fitness
Lost instructions for Rober Black cross trainer
Hi, I have bought a second hand roger black silver cross trainer and I do not have any instructions, also the bolt that holds the front post together is missing and the tension dial does not seem to work can I adjust the tension in side the front post! Please can you help. Kind Regards Janet
Feb 01, 2009 | Exercise & Fitness
First Degree Fitness Viking AR Fluid Water Rower Logo
Top First Degree Fitness Exercise & Fitness Experts
Electro Med Services...
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you a First Degree Fitness Exercise and Fitnes Expert? Answer questions, earn points and help others
