Question about JBL OnBeat Xtreme Speaker
OnBeat Xtreme docking port part
Connection to ipad
Won't reload on my ipad
Connect to wall outlet Uses the USB power adapter and USB cable included with the device. If it is a third-party accessory, check to see if it is Apple Certified . Then follow these steps:
  1. Connect the iPhone, iPad or iPod touch to the Lightning to USB connector cable or the 30-pin to USB connector cable .
  2. Connect it to one of three power sources:
Wall outlet
Connect the charging cable to a USB AC adapter and connect the USB AC adapter to the wall outlet.
Computer
Connect the charging cable to a USB 2.0 or 3.0 port on a computer that is not in sleep mode. Do not use the USB ports on the keyboard.
Power supply
Connect the cable to a powered USB hub, docking station, or other Apple-certified accessory.
When the device is charging, you will see a lightning bolt next to the battery icon in the status bar or a large battery icon on the lock screen.
Aug 12, 2017 | Tablets & eReaders
Tip
How To Connect Your iPhone, iPad, or iPod To The TV
The following devices have support for TV out:
  • iPhone
  • iPad
  • iPod touch
  • iPod nano (3rd generation and later)
  • iPod classic, iPod (5th generation), and iPod photo
Note: Other iPod models may support viewing of photos or slideshows on the iPod display but do not support TV out.
The following docks support TV out when used with an iPod model or iPhone that supports TV out:
  • Apple Universal Dock (requires either the Apple Composite AV Cable or the Apple Component AV Cable-will not work with the iPod AV Cable). Search the store for part number MB125G.
  • iPod Universal Dock or iPod with color display dock (iPod photo dock)
Important: The iPhone dock does not support TV out.
iPod models that support TV out can support viewing on a television in several ways. Use the tables below to see which cables and docks can be used with each iPod model. Check the documentation that came with the cable or iPod for information on how to connect and enable TV out.
Note: If you choose to use a third-party cable, make sure it has the "Works with iPhone" or "Made for iPod" label. Learn more about iPod and iPhone accessories.
All you need to get TV out is a compatible iPhone, iPad, or iPod and the correct cable. If your device works with the component and composite cables, then the choice depends on the TV(s) you will be connecting to.
  • Apple Composite AV Cable (part number MB129LL) will connect any iPhone, iPad, or iPod to your TV using RCA Cables.
  • Apple Component AV Cable (part number MB128LL) will connect any iPhone, iPad, or iPod (except iPod with color display (iPod photo), and iPod (5th generation)) to your TV using Component Cables.
A dock can be a welcome addition if you're going to keep your cables connected to the TV. The Apple Universal Dock includes an Apple Remote so you can pause and adjust the volume from a distance. The docks and cables are sold separately.
on Feb 21, 2011 | Apple iPhone Smartphone
How do you connect ipad to computer
To help you connect your ipad to the computer, please follow the step-by-step instructions given below:
- Turn both the computer and iPad ON before connecting.
- Plug the iPad's docking port into the appropriate end of the dock connector-to-USB cable.
- Plug the USB end of the iPad's dock connector-to-USB cable into an open USB port on your desktop. If iTunes doesn't open automatically, open the program to sync files and apps between the devices.
- Do not disconnect while the iPad is syncing or the sync won't complete.
- Remove either end of the cable to disconnect your iPad from the PC.
- After the first connection, you may choose to connect the two via Wi-Fi so you don't need to use the cable.
- Using iTunes, you can sync your audio, video, photos, apps and documents. This lets you transfer important files and apps you use for your business between your iPad and computer.
GuruAid.com
May 15, 2016 | Tablets & eReaders
How to open up the JBL onbeat rumble?
The power connection on my JBL Onbeat Rumble stopped working also. I could usually jiggle it to get it going but this wasn't a reliable solution. I note there were a few people online that have complained about this but no solutions or disassembly guides. With nothing to lose I set about pulling the unit apart to fix it... here's hoping it will help others:
1. Under the orange base rubber there are five screws. You need to carefully peel off the rubber to get to the screws. Also under the sticker on the input/output section there are two screws to undo.
2. See photo for positioning of rear clips. You might be able to use an appropriate tool to undo them. I used brute force to open the case and the rear clips didn't break.
3. There are two more clips and two screws at the front of the unit.
I don't know how to get to the screws - possibly you need to unclip the front of the unit and grille. I just used additional brute force which undid the clips and snapped the screw mounts. The unit was then completely opened up into two halves.
4. You can now get to the input/output section. There are four screws to undo before you can lift it out. In my case I could see a cracked solder joint on the power input so I re-soldered it as best I could and confirmed the unit was now being powered up reliably.
5. To reassemble, reseat the input/output board, clip the unit back together, re-insert the 5 base screws + 2 input/output screws, then glue the rubber back on (it might be sticky enough not to need additional glue). The snapped screw mounts don't seem to matter as the remaining clips are strong. Just shake out any plastic pieces to avoid rattles.
Jun 13, 2015 | JBL OnBeat Rumble Wireless Speaker Dock...
My JBL Onbeat Extreme has blown a speaker - I want to repair it but cant work out how to open it... there must be clips or screws somewhere
First you have to remove all of the bottom rubber feet, don't worry they are glued to the bottom, then with a sharp knife, remove the plasticdecal where the USB, AC and video plugs are. Pry it off from one corner then work your way all around, there you will find three more screws that will release the board. Good Luck!!!
Dec 20, 2014 | JBL OnBeat Xtreme Speaker
Badrul001
1. Turn off iPad
2. Turn on computer and launch iTunes (make sure you have the latest version of iTune)
3. Plug USB cable into computer's USB port
4. Hold Home button down and plug the other end of cable into docking port.
DO NOT RELEASE BUTTON until you see picture of iTunes and plug
5. Release Home button.
ON COMPUTER
6. iTunes has detected iPad in recovery mode. You must restore this iPad before it can be used with iTunes.
7. Select "Restore iPad"...
Note:
1. Data will be lost if you do not have backup
2. You must follow step 1 to step 4 VERY CLOSELY.
Jan 30, 2014 | Apple iPad 2 Wifi 16GB
My new JBL onbeat xTreme when connected to my MacBook by Bluetooth and playing streaming from Spotify, keeps goimg into stand-by every ten minutes. It seems that it doesn't recognise that it is c
Same here. Streaming from Spotify from iPhone5..... every 10 minutes enters sleep mode. WTF? No idea how to get around it. Only FW upgrade I guess, if there any...
Dec 06, 2012 | JBL OnBeat Xtreme Speaker
I can't get my iPad to connect to it. it wants a password but i don't think i ever set one up.
make sure you are connecting to your wireless network.
connect to your dlink from a computer to locate your password by opening your browser to
192.168.0.1
the default login/pass is admin/admin
click on setup and choose wireless settings
on the bottom you will see wireless security and the passphase which you will use your ipad to connect to your network.
May 26, 2011 | D-Link DIR-815 Xtreme N Wireless 802.11N...
IPad connects but if I turn it back on,IPad can't find the D-link router.If I unplug the router and plug it back in. Ipad will then connect. any possible solutions why this happens?
p.p1 {margin: 0.0px 0.0px 0.0px 0.0px; font: 15.0px Arial} p.p2 {margin: 0.0px 0.0px 0.0px 0.0px; font: 16.0px Arial; min-height: 18.0px} p.p3 {margin: 0.0px 0.0px 0.0px 0.0px; line-height: 18.0px; font: 14.0px Arial}
iPad wifi is "n" mode (faster) and this router is capable of both 10 Mb and 100 Mb (the latter, "g"mode). Have you already tried to configure it to work only in the "g" mode (and not in both modes as preconfigured).
Briefly, connect a cable from your PC to your router using one of the computer ports (not the cable modem port). Then, in your web browser, type the address http://192.168.0.1 (as you did), which should be the router address. You'll be prompted to enter the user (which is "admin"); leave the passed field blank (unless someone else have configured it differently). Now, run the wizard and you should be done. Additional configuration steps involve creation of WPA/WEP security in your WIFI network (usually, very relevant).
Jan 09, 2011 | D-Link AirPlus Xtreme G DI-624 Wireless...
JBL OnBeat Xtreme Speaker Logo
87 people viewed this question
Top JBL Audio Players & Recorders Experts
Michael Edwards
Michael Edwards
Level 1 Expert
 Grubhead
Grubhead
Are you a JBL Audio Player and Recorder Expert? Answer questions, earn points and help others
