Question about BOSS AUDIO SYSTEMS BV8975B Car Video Player
I need the SYSTEMS BV8975B connector
Missing part
I dont think iv put my dvd rw in proply i think
Yes, you will need a small audio cable that runs to your sound card or motherboard. Many computer repair shops will have a bunch laying around. Or eBay PC sound card to CD DVD drives internal audio cable 3 connectors 64cm...
Sep 10, 2014 | Computers & Internet
Have misplaced owner's manual and lost several essential wire connectors
Here is a manual for the Soundspace 9, it should be basically the same: http://www.eserviceinfo.com/download.php?fileid=25052
Aug 08, 2007 | Nakamichi SoundSpace 8 System
How do i increase my graphics card performance?
Instruction:
To troubleshoot video issues, follow these steps and test your video after performing each one:
  1. Check the video signal cable connector for bent or missing pins. Check the cable for cuts.
  2. Check to see if moving the monitor connections slightly causes color changes. Tighten loose connections.
  3. In the case of systems with multiple video output connections, verify that the correct connection is being used.Some systems ship with two video connectors on the back, however only one is enabled.
Feb 25, 2011 | Computers & Internet
Can i change the screen picture when i play a cd instead of it having the boos logo on it
Yes you could but you need to go either menu or setting and find another inmage instead.
Also you can bring your onw picture if you have USB Aux.
Dec 29, 2010 | BOSS AUDIO SYSTEMS BV8975B Car Video...
How do I bypass the brake safety feature on a boss bv8975b?
  1. Install a toggle switch in your car.
  2. Run 1 wire to the Brake Wire coming out of your Head Unit Wiring Terminal.
  3. Run the other wire to a ground.
  4. Turn on the vehicle, insert a DVD, and then flip the switch after the warning comes on the screen.
Jul 24, 2010 | BOSS AUDIO SYSTEMS BV8975B Car Video...
I am missing the AM loop antenna connector. What
http://supcontent.gateway.com/support.gateway.com/s/HomeTheater/7004678/700467843.jpg
looks like that
but you dont have to get one mde my the same company as your cd player you can get any generic am loop antenna from ebay
Jan 06, 2010 | RCA RS2533 CD Shelf System
I need the wiring diagram for the RBC #32 battery cartridge
https://www.batterysharks.com/APC-RBC32-p/apc_rbc32_ups12-7_x2.htm
Dec 27, 2009 | APC (br800) UPS System
Orignal c d missed
Depending on your OS & UPS you maynot need a driver.
If the UPS has a USB connector just try plugging it in. Windows 2003, XP & Vista support most common UPS by default. If it doesn't work goto the vendors website and see if they can download it.
Jan 24, 2008 | Computers & Internet
BOSS AUDIO SYSTEMS BV8975B Car Video Player Logo
35 people viewed this question
Top BOSS AUDIO SYSTEMS Car Audio & Video Experts
Jose Velazquez
Jose Velazquez
Jerry Umali
Steve Sweetleaf
Steve Sweetleaf
Are you a BOSS AUDIO SYSTEMS Car Audio and Video Expert? Answer questions, earn points and help others
