Question about Fitness Quest Eclipse 1100 Hr/A Elliptical
Grinding noise when using eliptical
Noise is at wheel. Bearings
Noise coming from one wheel - sort of a grinding noise but not consistemt
Can be three things
worn wheel bearings
stone in the brakes (most likely)
worn or incorrectly fitted pads
Jack the car up, spin and look.
Jul 10, 2016 | 2004 Hyundai Santa Fe
Steering wheel column noise
Steering Wheels & Grinding Noises (with Pictures) ' eHow
www.ehow.com > Cars
The typical cause of grinding noises when turning the steering wheel is low power... Worn bearings inside the steering column may create a grinding noise, but .
Sep 12, 2015 | Cars & Trucks
99 dodge stratus real bad grinding noise in front end and its not the breaks
Only thin left is the wheel bearings failed or if front wheel drive then a failed cv /s joint. IF the bearings are faulty the grinding noise will be the disc rotor grinding on the caliper . Check out the front end and look for failed ball joints in the suspension.
Aug 17, 2013 | 2001 Pontiac Sunfire
Grinding noise when turning left
Wheel bearings, brake pads or head bearings. Check brakes first then wheel. The head bearing would make a grinding noise on both left and right turns.
Jun 27, 2013 | Harley Davidson Motorcycles
My differential on my ford falcon au series 2 is making a grinding noise at a certain rotation, there is plenty of oil so it maybe the axels, i have it up on stands and when its running the hubs look like...
Check the wheel bearings, if its not the wheel bearings then its your axles. A grinding noise would be a sign of bad wheel bearings. If the rear end is off the ground grab the top and bottom of the tire. Can you wiggle it REALLY good? If so bad wheel bearings.
Jun 20, 2011 | Ford Futura Cars & Trucks
2000 windstar has grinding noise when running about 45 to 50 mph and let off acc -- gets a grinding noise up front
BAD WHEEL BEARINGS OR FRONT BRAKE SHOES WORN UNTIL FRONT SHOES GRINDING ON BRAKE ROTORS CAUSING GRINDING NOISE.
Mar 07, 2010 | 1998 Ford Windstar
When turning hard right or left a noise occurs not sure if it is awheel bearing or 4-wheel drive u-joint
Raise wehicle and use long handle prybar and try to lift the wheel straight up. If it is play then you have bad bearings. Please Note that wheel bearings will make grinding noise igf they are bad on any speed above 25Mph no matter that you turning your steering whel or not. Grinding noise from turning your steerin wheel it is comming from sterring pump. Check your fluid.
Feb 19, 2010 | 2002 Ford F250 Super Duty SuperCab
Hear a grinding noise from the right front wheel when I make left turn (mostly). Noise has now progressed to anytime the wheel is in motion. Also hear squeeking sound (ball bearing possibly?). I've changed...
You should definitely pull the front wheel and check the bearings (they are roller bearings, not ball bearings). With the wheel off, you should be able to isolate where the noise is coming from, but I vote for the bearings. Check, replace and/or repack, and adjust properly. If you have noise, you should be able to feel the "play" in the bearings, or see the wear problem on the spindle and bearings. I hope this helps you.
Oct 30, 2009 | 2000 Nissan Maxima
Grinding noise in the left front wheel while turning right - gets more noticeable the harder the turn is. Checked tire clearance - no problem, but it's not a rubbing noise but a grinding noise. No problem...
grinding on front wheel is caused by 2 things. a bad or loose wheel bearing,or worn out brakes, have them both checked
You might also want to check the level of fluid in the power steering reservoir - low or lack of fluid will also cause a noise (although more of a whining than a grinding).
Jul 29, 2008 | 1999 Volkswagen Cabrio
Fitness Quest Eclipse 1100 Hr/A Elliptical Logo
Top Fitness Quest Sport & Outdoor - Others Experts
Joseph Mueller
Joseph Mueller
Dave Callender
Dave Callender
Rigger
Are you a Fitness Quest Sport and Outdoor - Other Expert? Answer questions, earn points and help others
