Question about Cradlepoint IBR600LE-VZ Cor Ibr600 Lte / 3g Evdo Router Wl M2m Mobile
No internet connection
Router is hooked up but can not get connected
Is there a way i can hook up internet to 2 desktops with 1 modem/router?
That is exactly what a router is for.
If your modem doesn't have multiple ethernet connections, then go out and buy a generic router (like linksys or belkin or cicso or netgear, etc.) and hook the WAN port of the router to the modem's ethernet connection, and then hook the computers into the multiple ethernet connections on the router.
Aug 24, 2011 | Computers & Internet
My router is not detecting an internet connection when hooked up to my cable modem. However, when my modem is hooked directly to the computer there is an internet connection
Try power cycling the router.
Disconnect the router from all computers and devices.
Power off the router. Power on the router. Reconnect the router to all computers and devices. Check the Internet connectivity.
Mar 01, 2011 | NetGear WNDR3300 - RangeMax Dual Band...
I have 2 desk top computers hooked up to one internet source and they are hooked up to a box which my old linksys router was hooked to. I now have a lynksys wireless router G. i unplugged the internet...
Are you trying to set up the router.
You can do it manually without the CD.
Make sure that your computer is able to go online
through the modem.
If your computer is able to go online through the
modem
Then you need to connect the computer to the
router and the modem to the router.
open the set up page of the router and change the
settings of the router according to the ISP.
Click Here for step by step by instructions
Feb 11, 2010 | Linksys WRT54G2 Wireless Router
Hooked up arris modem with lynksys G series router
You have to set seting from routers menu. To use it hold 15 second router restart button, that restore factory setings, then go browser http://192.168.1.1/ , and use username "admin" and password "admin" in default. There you can set setting by your connection.
Aug 12, 2009 | Arris Touchstone 450a (CM450) Modem
Router Won't connect to internet
The cable modem sometimes register the hardware MAC address of the connected device. So your PC may be registered and it won't accept the router now. Connect the WAN port of the router to your cable modem and power the modem off and on again. It should re-register the connected device and now your router should work.
Jul 30, 2009 | Dell TrueMobile 2300 Router (000001)
Cannot share my cable modem connection
You need to connect a router to the cable modem.  The router then gets an IP address from Comcast and provides a gateway between the computers connected to the router.
The modem expects to communicate with a single Ethernet device, and provides an IP address to the first device that provides a piece of data called a MAC address.  By placing a router in-between, the router gets the IP address that lets you communicate on the Internet.  It provides local IP addresses to the equipment connected to the local Ethernet and "routes" those to the Internet.  You can either hook your two devices into the router if it has enough ports, or hook you switch to the router and hook your PC and PS3 into the switch.
May 05, 2009 | Linksys EtherFast EZXS16W 16-Port Ethernet...
Router isnt working
Check the network connection physically, if your connected properly then nothing happened? check the lights of the router? if the link lights of the router is not lit you needing to get an another router.
Mar 25, 2009 | Computers & Internet
Router problem
Hi .
First who is your service provider?
Can you connect to the internet if you directly hook your modem to your computer.
1>If so connect your Modem to your router on the colour code slot on the router which says modem
2>Connect a cable from the router to your computer
3>The lan light on the router should be turned on
4>Check wether your lan says connected . To check that click start-> control pannel -> network connections
5>If it says connected try internet explorer settings
6>If it says limited or no connectivity
Click start ->run -> cmd->ipconfig
7>It should say ip address as : 169.254.x.x.
8>If so type ipconfig/release
9>It shoul say ip address: 0.0.0.0
10>Type ipconfig/renew on command promt
12>Disable and enable lan
Let me know if this helped and also if you dont what kind of messages you get .
Mar 02, 2009 | Linksys BEFSR41 Cable/DSL Router W/4 Port...
How do i hook up a westell router to a moterola comcast modem?
Okay, well something is obviously wrong.
This is how it should be connected. Internet to modem, then with an Ethernet cable, connect the modem to the router (jack1) then with another Ethernet cable, connect the router (jack2) to the computer.
If you are still having problems, then contact your company to see if they could walk you through it, or if they needed to set things up.
Also, where are you connecting your laptop from? Is it very far from the router? Perhaps your router's signal strength isn't great enough? (This would mean getting a new, more powerful router.)
Jun 13, 2008 | Westell Wirespeed VersaLink...
Blitzz BWA611 Router
a router shouldnt need to dial for a connection, go to open your internet browser and go to tools, then internet options, then click connections tab and select never dial a connection so as to stop internet explorer looking for a modem connection
Aug 30, 2007 | Blitzz Technology (BWA611) Router
Cradlepoint IBR600LE-VZ Cor Ibr600 Lte / 3g Evdo Router Wl M2m Mobile Logo
43 people viewed this question
Top Cradlepoint Computers & Internet Experts
S. Pankratz
Level 1 Expert
Prashant M
Prashant M
Are you a Cradlepoint Computer and Internet Expert? Answer questions, earn points and help others
