Question about Ashton Digital (WRCB-1011R) Wireless Adapter
WRCB 1011r own card for 3 yrs worked great, now after booting up I lose connection after 10 min or so. I remove card and re insert then it connects and then I lose connection again. Is the card toast?
  • 2 more comments
  • david65 Oct 30, 2007
    nothing changed to my knowlege. I don't know much about drivers or how to look for them. How do I look or update? Is there a support line for this product? Will you help me?
    this is my only wireless device, I did look at what was available and put in wep key again. The problem is system doesn't see any wireless devices when it goes down, there lies the problem and should tell us the answer.
    to be more clear, when pc disconnects the lights on the card are not lit and when I open there are no available wireless networks available. Should be lit, the card lites and I useually show 2 networks available. ???
    then as you pull the card and reinsert it connects, then 5 minutes disconnects and again we pull card and reinsert... over and over
  • 537 Answers
It is possible that the card is failing. Think about anything that has changed in your network setup. Have you changed wireless routers, or changed any settings. Have you recently updated the drivers for this card. Do you use the wireless adapter at other access points or only a single one?  One thing you could try is to uninstall the device, then reinstall it. Also look for newer drivers if they are available.
Posted on Oct 30, 2007
  • Mike McWhinney Oct 30, 2007
    Look at this link:
New display detected vista
Boot-up in safe mode; add the MSI video drivers and re-boot normally
Mar 07, 2014 | MSI Computers & Internet
I keep losing my wifi connection
try reseating the wireless card or airport card. if that doesnt work. turn off your wireless router and your macbook. leave off for 10 mins then turn on the router first then macbook. try to connect and see if that fixes the problem.
Dec 19, 2012 | Apple MacBook Air
Remove the case cover from your desktop computer.
Remove a cover strip from a PCI expansion slot.
Insert the Dynex network card into this PCI slot and secure it with a screw.
Replace the cover on the desktop computer.
Boot up the computer and when Windows has booted up then insert the Dynex installation CD into the CD drive then install the LAN driver.
Connect a LAN cable from the Dynex LAN card to your modem or router etc.
Mar 11, 2012 | Computers & Internet
Please Insert Smart Card
open slat and re insert the sim card .also check your setting
Apr 10, 2011 | HP Compaq nc6230 Notebook
Always restarting
Hi Reynaldo,
Please find the below steps to resolve this issue
Step 1: Turn on the mobile
Step 2: After 2 to 3 mins, switch it off
Step 3: Now remove the battery
Step 4: Remove the Memory Card
Step 5: Remove the Sim Card
Step 6: Now hold the Turn on/off button for 10 secs
Step 7: Take the hand from the button and insert the sim and battery to the mobile, please dont insert the Memory Card
Step 8: Now hold the Turn on/off button for 5 secs continuously
Step 9: Take the hand from the Turn on/off button
Step 10: Leave the mobile, for 10 to 15 mins, after that please insert the Memory Card
Step 11: Now check the status of the Mobile
Thanks for contacting Fixya
Apr 02, 2011 | Nokia 5530 XpressMusic Smartphone
On my Craftsman Riding Lawn Mower the engine stalls after say about 10 minutes - I leave it for say 5 or 10 mins and I can start it again. I changed the sparkplug and it's not bad gas as my other mower...
The problem is more than likely the coil. The coil is nothing more than a coil of copper wire. When the coil gets hot the wire expands causing the coil to open or lose connection. When it loses connection then the spark plug quits firing.
PLEASE RATE! Click on the 4 thumbs ups!
Thanks! Have a GREAT DAY!
Oct 19, 2010 | Garden
I have had the monitor for over a year .computer stoped working added new input signal using 5450 512 mb graphic card computer starts to boot monitor is on dispaly no input signal message or...
check the connections on the backside of ur computer.. are the connections inserted properly.. if they are still try to remove and reinsert the connections properly and tighten up the screws properly.. 2) there is a possibility that the graphic card is not seated properly.. so remove the graphic card and reinsert it once again to check that.. 3) still no go then .. remove the graphic card and try to boot computer with onboard graphics.. if the computer boots up there can be a problem with the graphic card.. check compatibility of the graphic card with ur computer.. let me know if this resolves ur issue regards, guru
May 05, 2010 | HP w1907 LCD Monitor
Change of encryption key
Connect a cable from the router LAN port to the ethernet port on the system.
Check whether the internet is working.If yes
Click on start RUN & type in cmd
Then type in the dos windows the following command ipconfig.
Look for the IP address something like 192.168.x.x or internet explorer & type the IP address from the above step in the address bar without the http or www . it will open the router GUI .It can ask you for the username & password depending upon the router model.Please let me know.It could be anything .try some of these.admin blank,blank means leaving it blank,or blank admin,or admin password ,If it opens try finding the wireless settings(advanced)Look for key 1 : That will be the key which you need to put in .Let me know if it works.All d best
Jun 01, 2008 | Ashton Digital (WRCB-1011R) Wireless...
Dear Arbinder,
You can download the driver from this URL:
but first you have to register on this site, registration is free.
Driver size is 3.8 mb.
Be happy always
Feb 27, 2008 | Ashton Digital (WRCB-1011R) Wireless...
Ashton Digital (WRCB-1011R) Wireless Adapter Logo
134 people viewed this question
Top Ashton Digital Computers & Internet Experts
David Payne
David Payne
Masood Rasool
Level 1 Expert
Are you an Ashton Digital Computer and Internet Expert? Answer questions, earn points and help others
