Question about Jet 3 Ultra Power Chair
Where is the fuse on a jet 3 - Jet 3 Ultra Power Chair
  • 37 Answers
There are 2 fuses on a Jet 3. The first is a 50amp fuse located right behind the foot step casing. to get to this. take the pin on the bottom of the foot step, this will expose the batteries and the 50amp fuse. The 2nd fuse is an inline fuse for the Meter on the side. that you will have to take the outer casing off around the chair. Its a 25amp inline fuse.
Posted on Jun 23, 2009
How do I change the in-line fuse on the Jet 3 ( not ultra)
the 7.5 amp fuse is for the controller power. The power chair inline fuse is either a 40~50 amp circuit breaker, a fuse link or a fuse. If any of these fuses are bad, then you will not have power. Remember that if the fuse is blown there is a problem, you need to get it checked out by a tech. A blown fuse usually alerts you of a bigger problem.
Jan 26, 2015 | Jet Health & Beauty
I changed the batteries in the jet 3 ultra. Chair will work but batteries will not charge
Wall outlet bad? Charger not turned on/plugged in right? Something disconnected? Bad battery connection? Blown fuse in chair or charger? Bad battery or batteries?
Aug 09, 2014 | Jet 3 Ultra Power Chair
When plugged in lights indicate full charge,when I pull plug all lights go off,won't move this is a jet 3
Something between the batteries and the motors and joystick is interrupted. Recheck fuses and connections.
Aug 08, 2014 | Jet 3 Ultra Power Chair
Control system trip on jet 3 ultra
A flashing lite is an indicator of a fault condition. Is it steady or flashing?
Nov 19, 2012 | Jet 3 Ultra Power Chair
Circuit fuse
There is a meter on the back panel that indicates the rate of charge and it has an in-line fuse connected to one of the terminals inside. Remove the main cover and seat and look for a black boot and 2 wires. One wire will go to the meter and the other to the charger harness. Pop off the boot and inspect the fuse. If it is burnt open replace it with a same ampere rating fuse of the same color. Check the AC charger cord and all connections to make sure they are tight. Check all the plugs under the main cover and make sure they are plugged in and tight. Hope this helps.
Jul 03, 2012 | Jet 3 Ultra Power Chair
The ammeter on my jet 3 does not move at all when chair is plugged in.
If your ammeter does not move when the chair is plugged in...
You may have a burnt fuse ,check your fuse link connected to your ammeter..
You may have a bad charger, volt test your on board charger..
Good luck I hope i was helpful
Jan 16, 2011 | Jet 3 Ultra Power Chair
Pride Jet 2 power chair with with 3 red and 3 yellow lights flashing. Batteries checked ok under load, all connections have been checked. I moved the chair and it would not move again. Just that quick.
Hi. The fault code you have is called the "Inhibit active".
It can be caused by a blown charger fuse, which causes the charger inhibit to activate.
Also if the 3-pin charger inhibit connector is not plugged in properly, or the connector is faulty, then the charger inhibit feature will activate.
Hope this helps. Neil.
Jun 22, 2010 | Jet 3 Ultra Power Chair
I have the jet 3 power chair. It was turned on and will not turn off. Just makes a beeping noise. Any idea what this could be and how I fix it?
Try a few things. First, push the reset button located on the bottom of chair right next to the foot rest. If that doesnt work, take the back outer covering of the chair and disconenct the battery connector and wait a few minutes then reconnect it. Also check the 50 amp fuse located behing the foot rest, take the pin off the bottom of the foot rest and expose the batteris and you will see the fuse.
May 29, 2009 | Jet 3 Ultra Power Chair
Electrics
sounds like a blown fuse. check all your fuses, one by one. :)
Oct 10, 2008 | 2001 Volkswagen Golf
Jet 3 Ultra won't charge
Check the fuses may have a Blown fuse
Regards; Aaron
Sep 16, 2008 | Jet 3 Ultra Power Chair
Jet 3 Ultra Power Chair Logo
934 people viewed this question
Top Jet Health & Beauty Experts
Colin Taylor
wcdoc1953
wcdoc1953
Louis Smith
Are you a Jet Health and Beauty Expert? Answer questions, earn points and help others
