Question about Bose TRIPORT® Headphones
The foam around the earpieces are worn out
Where is can I send them to have replaced or can I repair them myself
Hi! Where I can get a foam earpiece replacement?
You could look around in your town/city in the dollar store.
they sometime sell some there OR even if you don't feel like searching to much . Buy a cheap pair of Headset at the dollar store and remove the foam piece from it and put it on you headset
Sep 02, 2011 | Genius HS-02B Headset
Is there anyway to repair the foam earpiece on denon ah-d210 over the ear headphones?
Have a look at my tip on headphone problems just click my user name to find it, you will find an answer at the bottom of it.
May 24, 2011 | Denon Audio Players & Recorders
1 of the earcups/earpieces won't work. can i fix this myself?
You could disassemble them and try to figure out whats wrong, and you may even be able to repair them, but headphones are fiddly and you'll need a multimeter and soldering iron at least.
A quick look on eBay shows a number of respectable looking sellers for around $15.
What is your time worth to you?
Jan 28, 2011 | Sony MDR-V150 Professional Headphones
My Motorola S305 stereo bluetooth headphones' foam pads on one of the ears is falling off. I've tried using something like a credit card to pinch the foam back into the game where it seems to be held in,...
Hey, this might be too late to help you, but I figured I'd share in case anyone else came across this while looking for help (as I did).
There's a small inner ring that the edge of the foam ear pads wraps around, but you can't really fit it under there while it's attached to the earpiece. The solution? I used something thin (specifically a nail file) to remove this "ring". It actually seems designed to pop on and off. I was then able to easily wrap the foam ear pad around the ring, then re-attach the ring to the rest of the earpiece.
Hope that helps!
Sep 28, 2010 | Motorola Stereo Bluetooth Headphones
Nokia 6233 - Earpiece Problem (No Sound)
ok first of all you should open your mobile and claen it carefuly.then re pack it care fully.thats it if problem not away then tell agian me i have seen tha pic also but it is for the tecnicians if mobiles.ie mobile repairer
Apr 03, 2010 | Nokia 6233 Cellular Phone
I HAVE A ROCKFORD FOSGATE PUNCH 12" UNGLUED AROUND EDGE THE THICK PAPER RING IS SORD OF WORN OFF SPEAKER IS IN WORKING CONDITION, WHAT WILL IT COST TO REGLUE?
This can't be glued. common problem.
You will have to find a speaker repairer who can replace the foam surround or just buy a new sub.
Jul 25, 2008 | Rockford Fosgate Punch Stage P110 S4 Car...
Strawberry Chocolate low volume
if you have tried raising the volume while on a call and you still have the same trouble then I'm afraid your earpiece has failed and you will need to take it to a tech and have the earpiece replaced
Nov 21, 2007 | LG CHOCOLATE VX8500 Cellular Phone
Bose TRIPORT® Headphones Logo
Top Bose Audio Players & Recorders Experts
jjcicala
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
