Question about Coleman Mach III Air Conditioner
Coleman on a 1993 terry. fan and A/C don't respond. You can hear clicks when the thermostat is changed from one mode to the other but no responce from a/c.(the furnace works by the thermostat though) Unir worked for about an hour when we first bought the camper, last week. any ideas? Thanks
    Sergeant:
  • 340 Answers
Low on freon , low pressure control open.Tom
Posted on Jun 18, 2009
Coleman/ Evcon central electric furnace Eb15b thermostat on auto will not blow air out i hear a click u see and feel it heating up then i hear Another click dont see nor feel heat then but put thermostat...
check the thermostat setting on back for electric heat. sounds like it is on gas heat. the fan should turn on right away if it is electric or heat pump.
Nov 15, 2014 | Heating & Cooling
Coleman Evcon Eb15b we replaced thermostat last night so that wasn't it when. Put in auto for heat u can hear a click. See where and feel it heating up tgen u hear. Another. Click and nothing even the heat...
if you turn on heat and no fan comes on, the electric will over heat and trigger high limit switch. the switch either self resets after it cools for a while or needs manual reset. read directions on thermostat for electric heat. energizes fan at same time as heat on calling from stat.
Coleman 2ton Basement air does not respond to thermostat but will turn on and run fine after 6 to 36 hours
Check contactor in condensor,if it looks good check refrigerant levels if you're EPA liscensed.
May 25, 2014 | Coleman Mach III Air Conditioner
Location of thermostatic switch 1993 Buick Regal 3.8 motor fan motors don't run
The fans are controlled by the ECM and it uses the ECT sensor for temperature sensing, so if the check engine light isn't on the sensor is not the problem. You need to have an active test run on the fan system to see what code is returned. Have you tried powering up the fans at the relay?
Oct 26, 2012 | 1993 Buick Regal
My coleman evcon fan motor does not come on. I put the thermostat to on so the fan would run but it will not come on. The rest of the furnace runs properly.
Did you check to see if you have power or fuse blown? If it is a furnace/ air handler and you are comfortable with electricity. Turn
Power off, remove blower door. Find where thermostat wires come into the control board and remove them. If you can find a jumper wire or aligator clips, hook them between R and G. Put blower
door back on and turn on power,
Fan should come on right away, if it does you might have a thermostat problem. If nothing happens but you can hear it hum
or hear nothing at all. Then more than likely the capacitor is bad and or the motor is bad.
Aug 04, 2010 | Coleman Heating & Cooling
Air compreser not turning on. fans are blowing but when you turn to cool the a/c wont engage.
Either a problem with thermostat, or perhaps faulty start relay for compressor. Do you hear a "click" or a slight "hum" or both when switch to cool?
Apr 17, 2010 | Coleman Mach III Air Conditioner
Can hear furnace on but fan will not engage. I
This is probably the fan limit that is bad. It should be a black bow tie looking thing next to or near the blower.
Dec 09, 2009 | Coleman Propane Forced Air Heater...
Im at an rv park, approximately 90 degees in the sun, air was cool for about 2 hours, fan continued to run but no cold air. When I change the thermostat I can hear it click but nothing changes.
Take air filter off , look up inside & see if coils freezing/frosting up when starts to blow warm air.
Is this a new unit, and has it always done that or just recently?
Jul 21, 2009 | Coleman Mach 15 Air Conditioner
I have a 1993 yellowstone camper with a coleman wall thermostat. on the bottom of it- it has a heat/cool switch on one side and the other side has a low-high-fan switch. when we run it on low or high it...
These unit are set up for continuous fan operation when turned on. It does not have an automatic position on your thermostat such as in your house. Set the fan speed to what you are comfortable with and let the thermostat control the temperature.
Jul 21, 2008 | Coleman Heating & Cooling
Coleman Mach III Air Conditioner Logo
178 people viewed this question
Top Coleman Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Coleman Heating and Cooling Expert? Answer questions, earn points and help others
