Question about MI-T M Corp Chore Master 2400 P.s.i. Pressure Washer
Briggs and stratton pressure washer wont make pressure
Makes no pressure, hose pressure out of nozzle
Excell pressure washer wont start
check gas, off/on switch,spark plug and magneto for spark
Oct 14, 2012 | Briggs & Stratton Pressure Washer...
My pressure washer will not mix with detergent
First you need to see if you have to utilize a soap nozzle normally black in color and with a large orifice that should create low pressure and or a selective change over nozzle with a spray pattern of 65 degrees.If so then you may have a clogged port where the chemical line connects to pump inside there is a check valve with a ball bearing that may be stuck from previous use without rinsing,free the ball by letting water flow with no trigger gun connected just water coming out of hose engine off and insert a nail or pin long enough to push the ball that is in the barb carefully til you hear ******* good luck.
Sep 15, 2011 | Briggs & Stratton Briggs Stratton 1800...
I have a Briggs & Stratton Pressure Washer it was just working Fine THEN the water stopped coming out of the wand? Any Suggestion
Remove the tip and pull the wand trigger without the tip in. If water comes out then your tip is clogged. Clean the tip and reinstall. Or try a different tip.
Its also possible that there is a kink in the supply hose to the unit.
Try these first, it should solve the problem about 90% of the time
Jul 02, 2011 | Briggs & Stratton Pressure Washer...
When using the sweep nozzle (yellow tip), the pressure starts and stops but the machine works fine when using the circluar nozzle(red)
usually when the power washer pressure stops the machine is running out of water. the sweep function uses a little more water than the round wash tip. Make sure there are no leaks in the supply hose and that the supply faucet is turned on all the way and has plenty of "flow". also make sure the water connection at the washer is not leaking. use a new rubber washer to make a good seal on the supply hose on both ends. if either end leaks or can **** air, just a little bit of air into the pressure washer will cause it to loose pressure.
Apr 20, 2011 | Briggs & Stratton Briggs Stratton 1800...
No pressure
This can be one of a few different issues
  1. Check the inlet screen to make sure it is clean and free of depris,(this is located where the water hose connects)
  2. Check the spray tip to make sure that it is not clogged
  3. If the above all check out to be good the the pump seals are bad or the entire pump itself is bad.
Aug 17, 2010 | Briggs & Stratton Pressure Washer...
Do you put the clear hose in the bucket with the cleaner to get it to come out of the spray nozzel? If you dont use the low pressure attachment will the cleaner still come out or not? I cannot find an...
You must use the lowest pressure nozzle with the clear hose in the solution or you will not get soap. Make sure you use only the solutions approved for your pressure washer!.
Jul 02, 2010 | Briggs & Stratton Pressure Washer...
Briggs and Stratton pressure washer will not spray water. The engine is fine but water does not flow.
The nozzle on the end of the spray wand has a very small hole in it that can be easily clogged by any sort of debris that comes through the water supply.If the nozzle can be removed, just take a pin & clear the hole from the outside & rinse it off. If the nozzle can't be removed, then take the wand apart at the connector in the middle and do the same thing.
Jan 30, 2010 | Briggs & Stratton Pressure Washer...
Pressure washer with no pressure
Are you priming the water lines before you switch on the power?
i.e. with power OFF, hook up hose and turn hose on (doesn't need to have much hose pressure), then take your spray gun or attachment and pull the trigger and allow water to flow through the system (at hose pressure obviously). You might need to gravity feed it if its not flowing through...
But you will generally only get pressure once all the air is removed from the lines and the pump is pushing water only... Once you have water flow and lines are primed, switch on pump and see if that solves it.
Mar 17, 2009 | Briggs & Stratton Pressure Washer...
MI-T M Corp Chore Master 2400 P.s.i. Pressure Washer Logo
37 people viewed this question
Top MI-T M Corp Garden Experts
Dennis Key
Dennis Key
roeb
john h
Are you a MI-T M Corp Garden Expert? Answer questions, earn points and help others
