Question about FocalPrice MX Google Android 4.2.2 Cortex-A9 Dual-Core 1.5GHz HD TV Box with RJ45 LAN Port, Built-in WIFI N Module 8G Black
Screen display connect your charger - FocalPrice MX Google Android 4.2.2 Cortex-A9 Dual-Core 1.5GHz HD TV Box with RJ45 LAN Port, Built-in WIFI N Module 8G Black
How do I change the display to make it brighter on my Uniden D1361 cordless phone?
There is a bulb behind the display it is for backlighting the lcd, likely it is burnt out or bad connection from the board
Dec 05, 2014 | Uniden Cordless Phone
Why does my acer aspire one not boot with a hard drive besides the screen going white when connecting the charger?
If you can plug an external monitor into the laptop, and if it works ok, the video on the laptop is going bad (chip or cable). If an external monitor works, I recommend you back up your data asap, if possible to an external hard drive. No way of telling how long before other things go wrong, and the price of fixing it might cost more than getting a new laptop.
Jul 19, 2014 | Acer Aspire Computers & Internet
How to have the battery life show on the screen ?
The battery indicator will only show on the screen in the upper right-hand corner of the screen when the unit is NOT connected to an external charger. When the charger is connected, the unit is running off of external power. The unit has to be running on battery power in order to display the battery status icon.
May 27, 2014 | Garmin nuvi 1450 GPS Receiver
Every minute or so the screen flickers and kind of rolls for minute or so. if you hold laptop hard or hit it then stops flickering
Nice to know. So what is the problem?
OH I'M JUST KIDDING!
See if the Display Cable has a loose connection.
The Display Cable is inside the Display Assembly, and comes out by one of the hinges, then plugs into the motherboard of the laptop.
The Display Assembly consists of the Top Cover, Bezel, LCD Screen assembly, Inverter, Display cable, and often the Wireless Antenna, and it's connecting cable.
Usual method is to remove all power to the laptop, AC adapter (Charger) and Battery.
Then remove the LED Display Cover, (Under the LCD screen, and in front of the Keyboard)
Then some have to have the Keyboard removed.
Check that connection.
Also remove the Bezel, (Frame going around the LCD screen on the inside), and check the LCD screen to Inverter connection.
If it all checks fine suspect the Inverter.
If I knew the laptop's manufacturer Name, and Model Number, I could give you more than the generic prattle above. (It's on the bottom of the laptop. Post in a Comment)
Oct 30, 2010 | Computers & Internet
When power charger is connected, screen goes darker instead of brighter.
You could have the battery settings wrong.
Go to Control Panel, Change Battery Settings, then Change Plan Settings of whichever plan is selected. Once there, set your display brightness for when the charger is connected to maximum with the slider. While there, you can also set the display brightness for when the battery is connected.
Good Luck.
May 02, 2009 | Acer Aspire 5920-6335 Laptop
New phone won't turn on just has "Hellomoto" screen
hi.there...don't worry.. what happens with your new cellphone..is normal..why? when your battery is low and there a pop up screen at the display "battery low...please recharge" that's mean you must charge the battery soon.
when connect your phone to charger adapter and your battery is very low / weak condition the display only showing "hellomotto" and nothing else. but it's normal! diplay need more power from you battery to showing all information.after the battery reach the minimum power to display it ( usually after 15-20' charging) try to push red bottom at your keypad phone and the display will showing again..good luck..
Feb 02, 2009 | Motorola Mobility RAZR V3
FocalPrice MX Google Android 4.2.2 Cortex-A9 Dual-Core 1.5GHz HD TV Box with RJ45 LAN Port, Built-in WIFI N Module 8G Black Logo
208 people viewed this question
Top FocalPrice Televison & Video Experts
john o grady
ray gallant
Are you a FocalPrice Televison and Video Expert? Answer questions, earn points and help others
