Fn is locked (pressed-down) until you press another key. Use this when pressing difficult key combinations. • Popup menu icon on/off Start up the Hotkey Settings. Click [start] - [All Programs] - [Panasonic] - [Hotkey Settings]. Make the settings. [Use Fn key lock] When using an Fn key combination Press Fn once.
**Press the Navigtion Key
**Scroll to settings and Press the Navigation key.
**Scroll to security and press the navigation key
**Scroll to Call Barring service and press the Navigation key
**Scroll to cancel all barrings and press the Navigation key.
**Scroll to Activate and press the Navigation key.
**Select setting, press the Navigation key.
**Exit, press disconnect to return to standby mode.
The function key, labeled "Fn" and located in the lower-left corner of your keyboard, is a useful feature. By pressing "Fn" along with one of the numbered function keys at the top of the keyboard (F1 through F12), you can adjust your screen brightness, enable and disable your touchpad or wireless modem, lock your computer and complete a variety of other tasks. These keys will not work if the "Fn" key is not pressed along with them. While the "Fn" key itself does not turn on and off, there are settings that can make it behave differently, or seem to be disabled.
Click "Start," then "All programs" or "Programs," then "Toshiba." Select "Utilities," then "Accessibility." Place a checkmark in the box to make sure the "Fn" key will work whether you press it simultaneously with the F1 through F12 keys or immediately before pressing those keys. Customize the other options on the screen, then click "OK." Test your "Fn" key. One of the easiest ways to do this is by pressing "Fn" and "Esc" at the same time. This toggles the sound on your computer on and off, and will show a speaker icon on your screen if it works. Press "Fn" and "Num lock" at the same time if the "Fn" key still does not work. Use the "F11" key if your laptop has no "Num Lock" key. Test the "Fn" key again, using the same method as in Step 4. Locate a licensed repair technician if the key still is not working. A hardware issue may be at fault. Hope this helps.
FN (Function Key) that is usually located near the bottom left on the keyboard is not a key that you press by itself to do anything. The FN key works in combination with the (F1 thru F12) and any other key that has the same symbol or color as the FN Key. You have to Press and HOLD the FN key while pressing another key.
If the FN key is Blue and for example your F8 key has a (white F8 on it and a Blue battery icon on it) then to see your battery metor (how much charge it has left) you would Press the FN and hold it then press the F8 key. The F8 that is white does not require you to press the Blue FN.
Sometimes the FN key might have a white square on it, then the keys that work with the FN key will also have a symbol with a white square around it.
Sometimes the FN
i suspect your f11 key does work, try opening a web browser and while it is open press the f11 key if your browser goes full screen the f11 key works just press f11 again to return it to normal. Try pressing and holding the fn key and then press f11 that will switch your wireless on and off
IT WORKED!!!! The manual on my 99 ML430 to "Resynching Remote Key" was just written weird.
It says "Turn the key in the ignition to 2nd position then back to 0.
Press and hold the lock key for 15 seconds... now press the unlock key 5
times"... which I held down the lock button for 15 seconds, released
it, then pressed the unlock key 5 times. NOTHING!
The newer manuals say press and hold the lock key and press the unlock key 5 times (with the lock key still held down).
After you replace developer, press #, interrupt, c , interrupt keys in that order. Display will go off, press 42 print 01 print for developer reset. Press Interrupt key twice and press 20 print 01 print for serviceman reset. Press CA key .
This is the method for a very similar model and should work with yours. You must have the remote to do it, It will not work without the remote.
If this works for you I would really appreciate a "FixYa", if it does not work let me know and I will look up your model on Kenwoods service site tomorrow
The first step is not easy to understand. Press the display key first and keep it pressed in while you press the track up key at the same time and hold them both for 3 or more seconds. If that does not work, press the track up key first and then the display key
Simplified method of clearing the security
code (K, E Type only)
1. While the code entry is requested, press and hold the
TRACK UP key for 3 seconds while holding the DISP key
pressed. (This should turn "----" off.)
2. Enter “KCAR “from the remote.
• Press the 5 key on the remote twice, and then press the
Track Up key. (This enters "K".)
• Press the 2 key on the remote 3 times, and then press
the Track Up key. (This enters "C".)
• Press the 2 key on the remote once, and then press the
Track Up key. (This enters "A".)
• Press the 7 key on the remote twice, and then press the
Track Up key. (This enters "R".)
3. The security code is cleared and the unit enters the ALL
OFF mode.
4. If you commit a mistake in the code entry, the unit enters
the code request mode again.
