Question about Robot Coupe R2Dice Ultra Food Processor
Replace bearings on R6VN
How to replace bearings in R6VN
How do I remove my cracked support bearing on my Kitchenaid food processor 1333?+
Do you mean the bearing on the motor shaft within that circular plastic ring that moves up and down when moving the slicing thickness lever? If yes then a couple of screwdrivers under it one on each side to lever it up. At the same time it will force the black shaft sleeve up and off the motor shaft.
Oct 13, 2016 | KitchenAid Food Processors
Can I get replacement jars for my Bullet
You can Linda
  • magic bullet replacement parts ' eBay www.ebay.ca > Search > magic bullet replacement parts Find great deals on eBay for magic bullet replacement parts and magic bullet ... 1 Cross Blade Assemly with Seal Ring Gasket For Magic Bullet Replacement Part. C ...
  • Magic Bullet Cups and Lids ' eBay www.ebay.ca > Search > Magic Bullet Cups and Lids Magic Bullet Replacement Cups Blade Juicer Strainer Pusher Pitcher Lids . ... 19 Magic Bullet Replacement Parts 8 Jars Various Sizes 5 lids 4 Rings Strainer .
  • Magic Bullet Blender Cross Replacement Blade w ... - eBay www.ebay.ca > Search > Magic Bullet Blender Cross Replacement Blade w Gasket Find best value and selection for your Magic Bullet Blender Cross Replacement Blade w ... MAGIC BULLET Extractor Cross ... Magic Bullet Replacement Parts Tall ...
  • Magic Bullet Replacement Parts ' eBay 2q== www.ebay.com/bhp/magic-bullet-replacement-parts Find great deals on eBay for Magic Bullet Replacement Parts in Blenders ... you can find Magic Bullet replacement parts, including the Magic Bullet ...
  • Canadian Tire Magic Bullet Magic Bullet Single Shot, 12-pc ... answers.canadiantire.ca > ... > Kitchen Q & A > Small Appliances Q & A Canadian Tire customers questions and answers for Magic Bullet Magic Bullet Single ... Is there anywhere in Canada where you can buy/order replacement blades? (see ...
  • Amazon.com: nutribullet replacement jar www.amazon.com > Search > nutribullet replacement jar ... nutribullet replacement jar. Just 6 days until Prime Day! Amazon Try Prime All Go. Departments. Hello. Sign in Your Account Sign in Your Account ... by Nutri Bullet.
  • 2x Magic Bullet Flip Top Lids Replacement Part Original ... https://www.amazon.ca/Magic-Bullet-Flip-Replacement-Original/dp/B... 2x Magic Bullet Flip Top Lids Replacement Part Original Fits all Mugs ... YESURPRISE Replacement Seal Lid for Magic Bullet Blender ... Ball Jar Crystal Jelly Jars ...
  • Homemade Magic Bullet: Using a Mason Jar with Your Blender www.primermagazine.com/2011/learn/homemade-magic-bullet-using-a... Video embedded · Homemade Magic Bullet: Using a Mason Jar with Your Blender ... For $.79 each I picked up a bunch of mason jars and now have an easy ... Homemade Magic Bullet...
  • Replacement jar for Magic Bullet? ' Yahoo Answers ph.answers.yahoo.com > ... > Other - Electronics > Next
    • RESOLVED
    • 3 POSTS
    • 2 TOTAL ANSWERS
    2009-07-23 · Anyone successful at buying replacement jars for the Magic Bullet blender? No luck @ www.buythebullet.com or by phone to customer services. No ...
  • Magic Bullet Blenders and Accessories ' eBay www.ebay.com/bhp/magic-bullet Find great deals on eBay for Magic Bullet ... Cook in style with eBay's huge selection of Magic Bullets, ... What you receive:2 Magic Bullet Replacement Tall ...
  • Aug 10, 2016 | Food Processors
    We got a Kenwood Chef mod a901 as a gift but no service manual. This mixer has seen a lot of usage during its lifetime and I don't know whether it has been serviced regularly. Does it need regular...
    The parts that may require service after a very long tim would be the gear box which would require a clean out and refill with grease and the output shafts which can be wiped clean and given a touch if grease as well. The motor bearings could do with the same treatment and all this calls for a strip down of the mixer. However, if there is no perceptable play in the drives and no strange noises, the unit is possibly best left alone with just the minimum lubrication being applied as you intimate.
    Jul 12, 2011 | Kenwood Food Processors
    Need replacement blade for hamilton beach food processor replacement blade model 70450
    need replacement blade for hamilton beach food processor replacement model 70450
    Nov 03, 2010 | Hamilton Beach 70450 Food Processor
    Im trying to put a belt on a hobart 84146
    I'll do my best to recall all the steps, I haven't done it in a while. Read instructions fully before starting, as step three may not be necessary, although if performed you'll have much more room for your hands during the remainder of the process.
    1. Lay machine on side/back (so that the knife shaft is standing vertically) to access the bottom.
    2. Remove bottom cover panel.
    3. Remove motor. Two nuts are easy to access, the other two are quite difficult to reach. This step might not be necessary if only changing a belt because you should be able to slip the old belt off and the new one on without completely removing the knife shaft. If the knife shaft must be removed for some reason, the motor must come out to give you room to fit a puller onto the knife shaft (in order to remove the lower knife shaft bearing and lift out the shaft).
    4. Take note of the knife shaft pulley. Notice how close to the casting the pulley is. When re-assembling, you'll need to position the pulley at approximately the same location for the black belt to track properly). Loosen two set screws securing pulley onto knife shaft and slide pulley down (don't lose the key for the pulley when you slide the pully down).
    5. On the "outside" of the machine, remove the plastic cover where the knife shaft enters the casting.
    6. Now visible is a special locknut and special lockwasher (sorry, don't know their names). One of the tabs of the lockwasher is likely bent upward into one of the slots of the locknut. Use a hammer & punch to bend the tab out of the locknut's slot, allowing the nut to turn.
    7. Using a hammer and punch, position the punch in one of the slots on the locknut and spin the nut counter-clockwise with sharp blows with the hammer & punch. Have an assistant hold the shaft to offer some resistance to the shaft spinning if you're having difficulty. This may also be easier with the motor and belts still in position, using the motor to partially hold the shaft from rotating while driving the locknut loose.
    8. With the locknut removed, spin it back onto the shaft a few threads with the flat side of the nut towards the casting (upside down compared to it's original, installed position). Don't spin it all the way on, you need room to fit a prybar under the flat edge of the nut.
    9. Using two prybars, one directly opposite the other, under the now upside-down locknut, pry up evenly on each side of the locknut, and the shaft usually pops out fairly easily.
    10. Back on the bottom side of the machine, slip off the belts and replace with new belts and reassemble machine.
    11. Be sure to turn the locknut back around to it's proper orientation and be sure to tighten it with a hammer and punch just as during disassembly (special wrenches exist for those nuts, I don't know their name) and bend one of the lockwasher tabs into one of the locknut slots (even if you need to turn the locknut backwards slightly from it's fully tight position).
    When everything is reasembled, be sure the flat black belt tracks properly, that is, make sure it doesn't walk off the pulley as the motor runs (just spin the shaft by hand at first to observe if the belt tracks properly.
    Good Luck!
    May 15, 2010 | Hobart 84145 Food Processor
    Table top grinder makes noise
    these grinder usually all have a gear system see if you have any grease in the gear case or you may have motor bearing problems
    Aug 08, 2009 | Food Processors
    How to put new shaft on cuisinart food processor model DLC-7E
    Initial disclaimer: I am not recommending this course of action - my recommendation is to buy a new food processor. These units weren't designed for DIY repair, so this is going to be a difficult task. The final product probably isn't even going to be pretty. You are well out-of-warranty, or I wouldn't even consider posting this. First, make sure you have a DLC-7E shaft - the only way to get one at this point would be to buy a DLC-7E base from eBay or an after-market seller, as all of these were manufactured well over 20 years ago. I don't currently see any eBay listings for one, but they do crop up from time-to-time. Make sure the DLC-7E you are repairing and the old one from which you are wrenching the old shaft are unplugged and have been unplugged for an hour or longer just to be on the safe side. Unscrew the four screws on the bottom of the base on both units. If the bottom base does not come off after this, carefully pry out the four feet and unscrew any hidden screws that might be hidden underneath the feet (Careful - original feet cannot be ordered by normal means, and damage will only add to your total repair cost). Take note of the guts on the inside of both food processor bases - if you have to unscrew the motor body (4 screws that sit just underneath the top of the base), take note of everything that you are taking out so that you can put it back in its proper place when done. Wear leather gloves for safety. Please be aware that even an unplugged unit still has the potential to send several volts of electricity through your body - this is a potentially hazardous task. Once the motor body has been unscrewed and removed slightly (don't disconnect any wires or cables - just get the motor body out of your way), you will notice the old shaft that you intend on replacing. Look for any damage to the gears/bearing that surround this shaft. Try dabbing a small amount of USP-grade mineral oil on any bearings - clear away any dust or debris that may be obstructing the shaft from turning. Don't overapply the oil, or the wetness will seep into other electronic components in the motor and cause them to fail. Put your food processor back together, turn it on, and press the button/buttons on top of the base of the food processor with a pen with the food processor plugged in. If the shaft still won't turn, you definitely need to replace the old shaft (you can disregard some of these previous steps if your problem is that the spindle on the old shaft is worn).
    Remove the screws and disassemble the processor base as described above. Since there is a layer of paint/coating surrounding the old motor shaft, removing the old shaft may cause paint flecking. Take the shaft from the one food processor base and insert it in the food processor you are trying to repair. Strip away any excess paint/coating from the new shaft. Make sure no paint flakes remain in the body of the food processor, or they will later cause more serious problems that will permanently damage your food processor - potential fire hazard as well. You will probably notice that the new shaft does not look as pretty as your original shaft, since the paint/coating will almost invariably get damaged in this process. Reassemble the base of the food processor, making sure no wires, etc. were knocked out of place in the process. This paint flecking will add to the cost of the repair - you may need to buy appliance body paint that dries to almost a rubbery consistency to make the final project look nice. All of the materials listed above could cost you $40 or more.
    Like I said, I don't reccomend this course of action, but there's your answer.
    Mar 11, 2009 | Cuisinart Food Processors
    Ultimate chopper replacement parts
    Yes, ultimate chopper parts are available, and the can be found easily on amazon, click here: Amazon com Ultimate chopper replacement parts, and take a look. Wish you best of luck. Cheers
    Jul 09, 2008 | Ultimate Chopper Food Processor
    Robot Coupe R2Dice Ultra Food Processor Logo
    Top Robot Coupe Food Processors Experts
    ray gallant
    Tom Chichester
    Are you a Robot Coupe Food Processor Expert? Answer questions, earn points and help others
