Question about Delfield DEL-SSR3S Spec Line 3 door refrigerator
The refrigerator has been running since we plugged
We recently purchased a used Delfield SSR3-S. The refrigerator has been running since we plugged it in. The temperature is down to between 35 and 40 degrees as measured by a refrigerator thermometer but the exterior thermometer is flashing random numbers instead of the actual interior temperature reading.
Is there any way to reset the thermostat, or will I need to replace it?
  • Delfield Master
  • 1,262 Answers
I think it needs replacing. In some cases, the thermometer is actually the front of the controller of the unit. This could be why it runs constantly. I would also look at the condenser coils and make sure they are really clean.
let's start there. let me know if I can help further.
Posted on Jun 07, 2010
What should be my pressure on a Delfield 404A refrigerator
As a general rule of thumb, pressure on low side should equal a temperature of about 17-18 degrees if the box is not hot and a high side of ambient plus 30. Again, this is a general rule of thumb that usually gets you close enough to get a unit working providing all other things are right.
May 20, 2014 | Continental Manufacturing Company...
Hello. The company I work for recently purcahsed an F13BR36-C ice cream cabinet with remote condensor unit. I've installed the condensor unit; however, there is no temperature control for the cabinet and...
You need to install a thermostat to cut off control power to condenser contactor at a set temperature that you will have to set, let's say; 5 degrees for example. You should be able to purchase a thermostat at any A/C & refrigeration store. If you are familiar with control, this should an easy job.
Good Luck!
Dec 17, 2010 | Delfield Refrigerators
We have a Delfield 407 freezer that will freeze when initially plugged in, fan running, gets nicely down to zero. After the unit gets down to temperature, the fan does not kick in again and the unit...
You will need to replace the temperature assembly on the unit. If you can post the model number, I will be able to direct you to the parts you need. The model number will be something like "18648-BUC".
Regards,Richard
Nov 11, 2010 | Delfield Undercounter Freezer - 407
Does not hold temperature Delfield sandwich/salad 2 drawer unit. Is this a cold holding unit or a refrigeration unit capable of refrigerating 40-60 lbs of lunch meat loafs?
start with the basics. Make sure the door closes and seals on all sides. If so, check to see that the condenser coil is clean. On some units, you may have to 'Wash" them out and let dry prior to using. Start here and let me know if I can be of further help.
Jul 26, 2010 | Delfield STD4427N Stainless Steel...
Delfield freezer 6151-S keeps tripping GFCI
Try it in a normal plug. Freezers and refridgerators just pull too much to be used on a GFCI. The more a GFCI is used the eaiser it trips.
Aug 31, 2009 | Delfield Freezer 6151XLSR Stainless steel
Delfied Freezer6000XL freezing temps are not hold
Sounds like a refrigerant restriction in the system. Recover the refrigerant, replace the filter drier and pull a deep vacuum on the system before recgarging.
Mar 21, 2009 | Delfield Freezer 6151XLSR Stainless steel
Delfield model st4660n 2door cooler no cold air
sounds like the temperature control is not calling for the cooling unit to energize. I would start there. first.
Let me know if I can be of any further help
Dec 09, 2008 | Delfield 60 Refrigerated Work Top Model...
Delfield DEL-SSR3S Spec Line 3 door refrigerator Logo
88 people viewed this question
Top Delfield Refrigerators Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
Are you a Delfield Refrigerator Expert? Answer questions, earn points and help others
