Question about 2002 Ford F350 Truck Super Duty Crew Cab Power Window Regulator wit
2002 F 350 super duty cuts off and won't start
Replaced IPR sensor, still cutting off after driving short distance
    Genius:
  • 1A Auto Parts Master
  • 2,494 Answers
Check coil ,module crank sensor chec if it has a strong spark at the plug wire or coil pack if fitted.
Posted on Mar 17, 2016
Why does my suzuki bandit 1200 cuts out after a traveling a short distance but engine starts straightening away after cutting out
Not sure why it's cutting out. A good thing to try if you haven't already is to put an bottle of seafoam in it then fill it with Super gas. I always ran super in mine, an added a bottle of octane boost to when I wanted to pep it up . 98 Bandit stage 2 Holesot jet kit, 2 degree timing advance. Slip On Performance exhaust.
Mar 01, 2015 | 2006 Suzuki GSF 1200 Bandit
I have a 2001 ford powerstroke. When temperature outside gets hot truck looses power when you step on throttle. Getting codes p1211, p1249, p1282. Just had ipr and ipc sensors replaced by ford. Replaced...
The icp sensor connector is a weak link in this mess. Check and make sure that it is not broken or has loose wires or wires that are broken inside the insulation.
Sep 01, 2013 | 2000 Ford F350 Super Duty Super Cab
Have a Ford f250 super duty that will start then cut off
Check mass air sensor, clean it. make sure intake tube is attached. Mine fell off one time and did the same thing.
Aug 28, 2013 | 2002 Ford F250 Super Duty SuperCab
F350 super duty, after running for an hour wont restart for a couple hours runs fine once you getted started
sounds like ipr valve
located under turbo 2 wire 1 conectorwire clip on
1 3/8 wrench to removed after turbo and air system been pulled off
get your new valve at your local international dealer
ask for ipr valve for vt365 engine bet you it's half price and same part
make sure that screen at end of valve came out with valve use small pick hook to remove if not
good luck
Feb 28, 2011 | 2006 Ford F 350 Super Duty
6.0 f250 2005 turns but not start
If it is a standard clutch saftey may be bad if automatic nuetral saftey,
Try auto in nuetral and wiggle shifter while turning key
Apr 28, 2010 | 2005 Ford F 250 Super Duty
2001 F250 power stroke 7.3 liter turns over but won't start
did it start up easily right away?
Has it happened more than once?
Apr 15, 2009 | 2001 Ford F250 Super Duty Super Cab
WHERE IS THE IPR LOCATED ON THE ENGINE ?
The "IPR" is and Injector Pressure Regulator. It is a Solenoid used to control the oil pressure created by the High Pressure Oil Pump. The IPR is capable of regulating oil pressure from 0 to 5000 psi. On an 05 6.0l the IPR is located in rear, top, center of the engine in the High pressure oil pump. It can be identified by its gold color. It sticks out of the side of the pump pointing toward the driver side of the truck. It has a 2 wire plug that is held on by a metal clip. usually the ipr and plug are protected in a heat shield so you may not be able to see it right away. Some people mistake and IPR for and ICP. The ICP is a sensor that tells the PCM what the High oil pressure is. ICP stands for Injector Control Pressure. This sensor is located in the passenger side valve cover on and 04, 05 6.0l and in the top of the High pressure oil pump on an 03 6.0l.
Nov 06, 2008 | 2006 Ford F-250 Super Duty
F350 super duty,engine cuts out without warning
Check to see if your truck was recalled for a faulty cam shaft sensor. Some sensors develop hair line cracks which allow contaminants to get in and the sensor becomes intermittent. The symptoms can include sudden shutdown of the engine so a recall was issued.
Jun 25, 2008 | 2000 Ford F350 Super Duty Super Cab
2002 Ford F350 Truck Super Duty Crew Cab Power Window Regulator wit Logo
Top 1A Auto Parts Vehicle Parts & Accessories Experts
Tom
Mike Stager
Mike Stager
Are you a 1A Auto Parts Vehicle Part and Accessory Expert? Answer questions, earn points and help others
