Question about Chevrolet 2009 2010 Chevrolet Suburban Silver 1/43
After market wheel spacers
Ltz
How can I clear Disc Error message in CD player or how can I get it to play a CD?
take it to a chevy dealership, you have an internal problem with the radio. or you can just yank it out and replace it with an after market radio.
Nov 29, 2014 | 2010 Chevrolet Impala LTZ
The order of spacers on the rear wheel startering from the brake side
With the larger outside diameter on the outboard side hold the external spacer between the belt sprocket and the rear swingarm and then slide the axle through left side of the swingarm, the external spacer and the belt sprocket into wheel hub and then when the axle emerges from the hub on the brake disc side of the wheel, push the axle through the short external spacer, the brake caliper bracket and the right side of the rear swingarm.
Jul 10, 2014 | 2005 Harley Davidson FLHTCUI Electra Glide...
How to change a wheel on a roller-skate?
To change a wheel on your roller skate please do the following:
Unscrew and remove the axle bolts from the front wheel with an Allen wrench. Pull the front wheel out of the wheel frame. Remove the bearings and spacer from the wheel. All components should slip out together. Place the spacer and bearings into the new wheel. Place the new wheel on the wheel frame. Replace the axle and tighten it using the Allen wrench. If your spacer is aluminum, tighten the axle as far as it will go. If your spacer is plastic, tighten the axle almost as far as it will go, then loosen it slightly. Spin the wheel to see how easily it rolls. If it doesn't spin freely, loosen the axle. If the wheel wobbles, tighten the axle. Repeat the previous steps for the remaining wheels.
Jan 13, 2013 | Sport & Outdoor - Others
I've recently had new tyres fitted, I think one of the front wheel spacers must have fallen out as I've only got the one on the left of the wheel. Am I right in thinking there should be a spacer on the...
hi, i am fairly sure that only 1 spacer is fitted to the 1098r and the righthand side spacer is infact part of the wheel spindle, you could insert the spindle in the forks all the way, including the spacer on the left hand side and measure the gap between the spacer and the spindle end on the r/hand side, then insert a screwdriver or a length of wire through the wheel to measure the width at this point, from the 2 measurements you will work out if infact you need a spacer, hope this helps, paul
Dec 19, 2010 | 2008 Ducati 1098 R
I need to know rear wheel spacer placement. also where to rreference to align the rear wheel. it seems i have un equal space between the wheel and fender. i have a total of three spacers two on the pulley...
The wheel not being equally spaced under the fender is typical of all Softail motorcycles. They have an "offset" wheel stance. I don't know exactly why but they are designed this way.
The three spacers you are talking about is actually one spacer and two seal races. The two seal races go into the wheel bearing seals on either side of the wheel. This provides a smooth finish for the wheel bearing seals to ride on. The other "spacer" is a bit larger and goes on the belt side of the wheel and the rear brake caliper bracket acts as the spacer on the other side. Anytime you take the wheels off your bike, always mark and make a drawing of the positions of the spacers.
Good Luck
Steve
Oct 12, 2010 | 2003 Harley Davidson FLSTFI Fat Boy
Front wheel question
My 2002 and 2003 both only had one. While sitting on the bike the spacer is installed on the right side of the front wheel. The spacer goes on the side where the axle nut installs
Nov 10, 2008 | 2003 ATK 125 2-stroke
Nov 10, 2008 | 1992 Aprilia Europe 125
Chevrolet 2009 2010 Chevrolet Suburban Silver 1/43 Logo
13 people viewed this question
Top Chevrolet Toys Experts
Electric Dime
Electric Dime
Maxumized
jogp98
Are you a Chevrolet Toy Expert? Answer questions, earn points and help others
