Question about Uniden BC340CRS Base Scanner
Howtogetfreecodesformyscanner needfreecodesforfirepolice/marine
I need an electrical drawing of a Mercury Marine harness p/n 896537t15 also p/n892990T01. I'm replacing engines and trying to get my ducks in a row.
I can usually find most things to do with marine engines, but your is a problem with just a part number to the harness.
The correct search would be something like
19696 Mercruiser sterndrive wiring harness, or schematic or wiring diagram or workshop manual.
Personally, I would say it is a job for a marine engineer who has the manuals. You could also try Mercury Marine direct. Sorry to not to be more help.
Wire Harness For Sale
Mercury Marine harness 896537t15 schematic Google Search
From my own contact with Mercury Marine over a warranty repair, they seem to genuinely care about the customer.
Mercury Marine
Aug 01, 2017 | Mercury Boating
Do non Marines get offended by the term ex marine?
Most non Marines are unaware that there are NO EX Marines, only FORMER Marines.
Those that know this, like Sailors, respect them and use the correct term.
Jan 04, 2017 | Military
What are the main manufacturers of gasoline engines for boats?
The main manufacturers of gasoline engines for boats are: Crusader Engines, Flagship Marine, Ilmor, Indmar Marine, Marine Power, Mercury Marine, PCM Marine Engines, Teague Custom Marine, and Vovlo Penta. For more information on these manufactures, check out this website: http://marinefuel.com/marine-engine-manufacturers-gas-or-gasoline/ and http://www.discoverboating.com/buying/types/engines.aspx?id=79
Feb 06, 2013 | Boating
IC-M302 VHF Marine Radio: need to have wiring schematic coming out the back ...
Blue: Speaker (+)
Gray: Speaker ( -)
Yellow: NMEA IN (+)
Green: NMEA IN (- )
May 17, 2010 | Icom IC-M302 VHF Marine Radio
What is best way to clean and restore a 50' X 50 amp marine power cord? Should be yellow. Is now black!
West Marine (and many marine stores) carries a shore power cord cleaner that works quite well.
Sep 20, 2009 | Hubbell Shore Power 50' Cable Set #6awg...
Which antennae to use with a Uniden Oceanus radio?
Marine two way radios operate on 156 MGZ. You have to use an antenna desinated for that purpose. Type marine vhf antenna on google search and it will pop-up lots of web sites.good luck
Jul 21, 2009 | Uniden Solara DSC VHF Marine Radio
Replace alternator on 2005 mercury mariner
change alternator on a 2005 mercury mariner 2wd with a v6
Nov 16, 2008 | 2005 Mercury Mariner
Uniden BC340CRS Base Scanner Logo
Top Uniden Radio Communications Experts
Jason
John
John
AnyMHz.com
AnyMHz.com
Are you an Uniden Radio Communication Expert? Answer questions, earn points and help others
