Question about Coby Usa Coby Electronics TFTV992 9 Inch Atsc Digital Portable Tv
Colby TV stopped working after cable connected to house.
How can I get Coby TV to work without cable connection box? I moved into a home and the Colby TV was working without cable. Verizon Fios signal was sent to home because tech had problems and then Colby no longer works. Please give step by step directions.
Going from cable to coby converter box
cONNECT A REGULAR OR DIGITAL ANTENNA TO THE rf INPUT ON THE coby..
Do one or both of following.:
Connect rf output from copy to rf input of TV. (set both units to channel 3, or 4 --must match)
or connect three RCA connectors (either three cables or single cable with Yellow-Red and White connectors) to the matching
connectors on TV and COBY.
This might involve DISCONNECTING some connection from cable box.... but you may decide to keep both connected ( one item to each option as described above. ) The signals from the RED WHITE and YELLOW systems will be available on the TV when you set the TV for LINE input ( there might be more than one choice of LINE-IN selections on some TVs.
May 11, 2014 | Coby DTV102 ATSC STANDARDDEFINITION TV...
My coby mp-c341 not turning on from power button. powering up normal
Never disconnect or connect cables on the Colby without turning it off first!
Jan 12, 2013 | Coby MPC341 256 MB MP3 Player
What do you need to do in order to hear the TV through the DVD-925 System?
For the best TV-related sound, connect the audio from the unnamed source (not necessarily the TV) directly to the Colby's Aux In.
If you believe the sound benfeits from the TV's electronics, run the unnamed TV's possible audio output to the AUX In and configure the TV to put out a Fixed level of audio so you can turn its volume down and not lose it to the Colby. (page 11)
Register and download the manual for free audio.manualsonline.com
http://audio.manualsonline.com/manuals/mfg/coby_electronics/coby_dvd_dvd925.html
Apr 24, 2011 | Coby DVD-925 System
I purchased a 32 inch flat screen coby tv on 11/2010. I am trying to advance the channels with the right up and down channel button on the remote, but it only goes to favorites. I only want to advance...
Are you using the cable box remote on the cable box or the coby remote on the cable box? or are you using the cable box remote on the TV or the coby remote on the TV? Try using the coby remote on the TV without the cable box connected first to see if the remote even works on the TV, replace the batteries and retry. then try the cable box remote on the TV to see if you have it set up correctly for that TV. Sometimes when you reprogram a remote to work other devices the buttons won't always end up working the commands that are labled on the remote, also there is more than 1 code that may work better than other codes or may match up with the labeled keys more closely. Low batteries will also make a remote act strangely.make sure the batteries also make good contact on the pins or metal pieces inside the remote. I guess I need more info on which remotes are being used for what purpose before I could give a more certain answer.
Dec 26, 2010 | LG Televison & Video
I CAN NOT GET ALL 5 SPEAKERS TO WORK
I know this is not the answer that you want to hear, but: That television is not capable of delivering audio output to all 5 speakers - it is a stereo-only TV, which only delivers 2 channels.
Furthermore, that Coby DVD-937 only has Digital Audio outputs rather than inputs, which is very strange and complicates our problem immensely. You will get 5-channels with DVD or radio play, but getting 5 channels for TV is not possible without additional equipment.
The manual for the Coby mentions a "Digital Decoder Amplifier," which would work. You would connect a digital audio cable from the area marked "Coaxial" on the back of the Coby to a digital audio IN on the back of an external amplifier. You would connect the speakers to this amplifier, instead of directly to the back of the Coby. Then you would need a cable or satellite box with digital audio outs (fairly common nowadays) to another digital audio IN on the back of the amplifier. The cable or sat box you may have already, but you may need to purchase such a "Digital Decoder Amplifier" or other digital amplifier with appropriate speaker wires and 2 digital audio input slots (not to mention two digital audio cables). Fairly complex. Possibly expensive.
-Tha Mp3 Doctor
Feb 20, 2009 | Coby DVD-937 5.1 Channel DVD...
No audio
You will only get stereo sound from that TV matched with that Coby instead of full surround sound, without purchasing additional equipment.
That Coby DVD-937 only has Digital Audio outputs rather than inputs, which is very strange and complicates our problem immensely. You will get 5-channels with DVD or radio play, but getting 5 channels for TV is not possible without additional equipment.
-Tha Mp3 Doctor
Feb 20, 2009 | RCA Audio Players & Recorders
Question: how do you connect to a cable box?
-Tha Mp3 Doctor
Jan 31, 2009 | Coby DVD-937 5.1 Channel DVD...
Connecting my DVD player to my widescreen TV
PRETTY SIMPLE, CONNECT YOUR 3 PRONG CABLE FROM VIDEO AND AUDIO OUTPUT ON THE COLBY DVD TO THE INPUT VIDEO/AUDIO ON THE TV.SWITCH AV INPUT ON THE TV TO VIDEO 1.
Dec 15, 2008 | Samsung LN-S4692D 46 in. LCD HDTV
Picture turns Blue-Gray after 30 min
cheak cables what cables uusing ? thx nick
Feb 07, 2008 | JVC TH-M65 System
Coby Usa Coby Electronics TFTV992 9 Inch Atsc Digital Portable Tv Logo
Top Coby Usa Televison & Video Experts
Electro Med Services...
Are you a Coby Usa Televison and Video Expert? Answer questions, earn points and help others
