Question about Texas Instruments TI-5032 SVC Calculator
Not right doesnt add up the right amount and sometimes - and + shows up
I have a sam4s ER-5200M. Today it started printing a 4 in front of all prices on the receipt. The screen says the correct amount.
http://cashregisterguys.com/files/Samsung_5200_40M_man.pdf
i saw this on page 116,it looks relevant,,,,,,,,,21.. Display add price of linked item? When Y, the customer display shows a total of the item and linked item. For example, if PLU is $1.00 and is linked to PLU2, which is $0.25, the display will show $1.25.
it doesnt add 40 dollars so that leads me to believe that there is an error with the printer,you might need to reset and start over or call the company,good luck.
Apr 21, 2015 | Retail Supplies
I have an hp2400 printer. all of a sudden it doesnt show up on my devices and printers. I have tried to add it back on, but it wont add. what do i do
Unplug it restart the computer and plug it. If the problem Continues try: -Start -Right click over My Computer -Properties -Hardware Tab -Device Manager -Right click in the name of your printer - Disable -Right click in the name of your printer - Enable
Hope that helps
Mar 21, 2011 | HP Deskjet D2445 InkJet Photo Printer
I do not have the manual. If I want to add or subtract do I put the total amount in and than hit the plus or minus key ? i.e., $128,000 -10000. do I hit the minus before the amount or after? -1500....
You can download the manual from
http://downloads.canon.com/cpr/software/calculator/P170-DH-(USA-HWB).pdf
128000 - 10000 then press = or chain the calculation by pressing + or - and the number you want to add or subtract.
Sep 30, 2010 | Canon P170-DH Calculator
Emachine won't connect to the internet. Ethernet cable, router and modem all work just fine. problem is with computer. Check network adapters in device manager and no problem noted there. Why won't it...
first try to check if your wireless can actually detect a network, if it can try to remove ALLthe network that you have on your wireless network and try to add your network again, if still doest work try to uninstall and re install your wireless driver, if it still doesnt work try to restart your router, if still doesnt work try to do system restore to the point where your wireless was workin fine, lastly if still doesnt work try to contact your ISP for some configuration.
Jun 02, 2010 | E-Machines eMachines Desktop PC
Fabric conditioner compartment doesnt empty properly. Ive tried cleaning out drawer but still no luck.
If you can remove the dispenser from the machine try soaking it in HOT water. The fabric softeners can cause a wax like build up that can clog the dispenser. If the dispenser will not come out of the machine then pour Hot water into it, cycle the machine and repeat. It took a long time to clog and will take a while to remove the clog(several cycles). This will work but will take time. Mix water with your softener to keep it from cloging again, it will thin the softener and stop the build up. If you add 50/50 water/conditioner shake well and use twice the normal amount so you are getting the full amount of softener/conditioner into the washer. This will help i had a similar problem with my front loading washer.
Oct 17, 2009 | Washing Machines
Adds extra minute
always put in one less minute and if it adds you'll be right but if not just send it back through for another minute
Aug 29, 2009 | Microwave Ovens
Engine light comes on, code says torqe converter lockup, doesnt shift right at times
do you have the right amount of oil in the box.With the car running and the box in neutral the dip stick should say full if not you need to add transmission fluid.
May 13, 2009 | 2000 Daewoo Nubira
Ps3 friends list
All of a sudden I had the same problem occur on my PS3 last night.
It took me hours of connecting, and reconnecting to the network to figure it out.......then I realised !!!
I had a comment on PSN ID. I deleted the comment, and then it all sorted itself out, literly within 5 seconds it all came back to life.
If you have a comment, try to delete it, and let me know how you get on.
Keith
Apr 09, 2009 | Sony Playstation 3 (PS3) Console
Mp3 wont play downloaded music
The device has 2 modes on it MSC and MTP, if you changed modes and uploaded songs in the other mode, they are only visible on the PC in that mode. But, the PC will show the total amount of free space on the device.
If this is not the issue, I would try formatting your device to remove everything and start over.
You can FORMAT thru My Computer>Device Name (e280)>Right Click and select FORMAT.
Best of Luck.
Please RATE my solution BELOW.
You can also add to this question for additional support.
Nov 22, 2007 | SanDisk Sansa E280 MP3 Player
Texas Instruments TI-5032 SVC Calculator Logo
12 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
