Question about Vizio CA24T-A4 all-in-one desktop
Add ram to a CA24T-A4
How to open case to add ram.
How to add memory to xplore ix104c2
To begin with, the maximum RAM that the Ix104c2 can operate on is 1gb. Secondly, If you have little to no experience working on laptops, then I would suggest having a computer repair business or a friend who has the knowledge of doing so install the RAM. The inside of the ix104c2 is rather complex and upgrades/repairs should not be attempted by a novice.
Dec 06, 2012 | Xplore Technologies Xplore iX104C2 Tablet...
Chassy intrusion error on asus motherboard
> chassis intrusion
There can be a sensor inside the case, that is "tripped" whenver the side-panel of the case is opened, i.e., somebody has removed the side-panel, in order to remove some components, e.g., RAM, or add-in adapter card. So, if it was a "thief" (an "intruder") that opened the case, to expose the "insides", check that nothing was stolen. But, if it was you that opened the case, then enter BIOS SETUP, and "clear" that "chassis intrusion" status.
Jun 26, 2011 | Computers & Internet
My memory at present is 512 mb I need to add more memory. Where do i buy it? where do i fix it?
www.newegg.com
There go to computer hardware, memory, and choose the memory configurator. It's usuall on the lower left of the page. There you can plug in your pc or motherboard model number and it will give you compatible memory for your setup.
Mar 21, 2011 | Computers & Internet
I already have 512 ddr2 667 ram .So now I want to add an extra 256 ddr2 533 ram to my Intel D102ggc2 motherboard .So can I able to do this .
Open your computer's case and check for a free slot on the motherboard. If there is any, then you can add another memory module, no problem with that.
Jan 08, 2011 | Intel D102GGC2 Motherboard
I want to add memory, how do i open the case?
First make sure that he memory u r going to add has the same capability as the memory that is already in the motherboard.
Open the case and u can find the Memory slots next to the processor. place the Ram in the additional slot
Oct 26, 2010 | HP Pavilion 753n (P9852AR#ABA) PC Desktop
I want to increase ram, what do I get
First, you have to find out the max of ram that you can add to your pc. Then go to the website crucial.com and run a test where it will tell you what memory and how much you can add. If you decide to purchase the memory and after you recieved , open the case and locate the empty slop where the memory is going to be install. It should be the small slots not the white big ones. Then carefully open the case from the memory and then put i on the slot of the pc. Turn the pc on and then see if it recognize it
May 24, 2010 | Systemax Tiger (SYXS-DC-1000) PC Desktop
I'm looking add transmisson oil on my audi a4 1996 auto can i can't seem to find to fill spot
Special car needs special procedure done at dealer or qualified shop.
Mar 14, 2010 | 1997 Audi A4
How to add memory to my pc gm5472
You need to open the case and see how many sticks of memory are in the slots. Your machine should come with 2GB. (probably 2 1-GB sticks)
If you are running a 32-bit system, it's useless to increase the memory above 3 GB, as the system will not see it. For a 64 bit system, you can add a lot more.
Sep 25, 2009 | Gateway GM5472 PC Desktop
Adding memory to Toshiba A75-S211
you buy the memory here for a great price or anywhere online instructions are on the page
it replaces the 512
http://cgi.ebay.com/1GB-DDR-333-for-Toshiba-Satellite-A75-S211-Memory-RAM_W0QQitemZ250353026446QQihZ015QQcategoryZ158897QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
  • Memory Card for Toshiba Satellite A75-S211 Memory RAM- Designed and Optimized
  • Toshiba Satellite A75-S211 Memory RAM Memory Upgrade -Easily installed
  • More Memory Equals - More Speed for your APPS
  • The Toshiba Satellite A75-S211 Memory RAM has a memory card slot or slots, that allows you to add more memory to your Toshiba Satellite A75-S211 Memory RAM, giving you enhanced performance and speed. You will see the Immediate speed increase in your computers performance.
    Stop waiting for programs, and functions to happen, STOP WAITING!!! Start enjoying technology as you should.
    We work directly with our memory card manufacturer to insure perfect compatibility with the Toshiba Satellite A75-S211 Memory RAM. Only using the highest quality memory chipsets for our memory cards, so you are assured compatibility and performance. All of our memory cards are Designed and Optimized for Toshiba Satellite A75-S211 Memory RAM . Technical specialists have personally verified our memory cards compatibility with the Toshiba Satellite A75-S211 Memory RAM.
    Worry Free Installation: Just Follow these Steps Desktop and Laptop instructions below.
    Desktops
    1. Unplug Power cable
    2. Remove Case
    3. Slide memory card in Open slots- the memory card will only fit in one way
    4. Snap the side clips in place
    5. Close Case and Power Up
    6. You are ready to go.
    Laptop
    1. unplug and remove Battery from laptop
    2. Open memory compartment on bottom using Philips screw driver
    3. inset memory in open slot, if no open slot remove current memory by pinching metal clasp on side of memory
    4. Close compartment and power up you are off and running.
    Jan 26, 2009 | Toshiba Satellite A75-S211 Notebook
    Vizio CA24T-A4 all-in-one desktop Logo
    Top Vizio Computers & Internet Experts
    Jessi Singh
    Level 1 Expert
    ray gallant
    Are you a Vizio Computer and Internet Expert? Answer questions, earn points and help others
