Question about Dell 1409X DLP Projector
Remote will not advance slides eveything else works
How do I forward the slides of a powerpoint presentation using the remote?
Make sure that you connect a cable (usually the USB cable is supplied with the projector ) from the computer to the projector. Once communication is established, normal PPT slide advancing is done by pressing the up/down arrow keys (depending on the remote control layout)
Dec 18, 2013 | Epson Projector Remote Controller...
Buttons will not advance carousel
Hardrocko is correct with his analysis. I have attached an image from one of my Service Manuals that may assist you when performing the repair. Good Luck !! Jim
Dec 02, 2013 | Kodak Carousel 4400 Slide Projector
Kodak 650 slide projector that won't advance the slides with remote
Don, Does the projector still cycle from the side (on-board projector) buttons?? If it does, then you have a bad remote (parts are still available from: www.micro-tools.com). If it will not cycle from either the remote or the side buttons, then chances are that you have a broken solenoid link. If you are not familar with the projector & proper disassembly, I'd contact a dealer. Again, you can still get the necessary parts from micro-tools. Good Luck !!
Jim
Apr 02, 2012 | Kodak Office Equipment & Supplies
On our Kodak 650 the remote will not advance the slides
Don, If the remote doesn't work & the projector cycle buttons do, then the problem is your remote. If neither the remote or side buttons work, then it is the LINK that connects the cycle solenoid the the cycle lever. Parts are still available from: www.micro-tools.com Good Luck !!
Jim
We have a Kodak Carousel 650A projector. (140 slide carousel) Cannot advance the slides using the remote or the select bar. Putting in the individual slides with the carousel off the select bar will eject...
The purpose of the "SELECT BAR" on a Carousel 650H is to eject the slide. If you press & hold the select bar it allows you to rotate the tray to the slide you want (or Zero & remove the tray). If you can not advance or reverse the slide tray using either the remote buttons or the buttons on the side of the projector, then chances are you have a broken part in the slide change mechanism. The possibilities are numerous, and really requires a trained tech to analyze your specific failure. Sorry the news isn't better (or simpler!).
Jun 20, 2010 | Office Equipment & Supplies
How do i advance my slides with the remote?
I HAVE THE SAME DUMB PROBLEM!! Everything works EXEPT moving the slides forward! Anyone have a solution????
Jul 08, 2009 | Epson (V12H007T06) Remote Control
Slide/tray advancement
http://www.fixya.com/support/t1564949-slides_advance_continusly
This link talks specifically about a Kodak slide projector. However the faulty mechanism in your Telex works in a similar way if you feel up to taking it apart. If you do, mark every screw and piece you remove, in a diagram. Though your symptom is sporadic advancing and the other link is continuous advancing, it's essentially the same cause, as sticking trigger mechanism in the clutch release.
Jan 27, 2009 | Telex 3280 Caramate 80 Slides Rotary...
Cannot get my Sharp Notevision remote to advance slides
you need an infrared receiver that plugs into your laptop to receive the signal ...honestly they arn't very reliable...go buy a targus presentation remote at staples for 39-69 bucks if you want areceiver i think i have one left
Nov 13, 2008 | Sharp Notevision XG-P10XU Multimedia...
Remote control problem
Yes, the computer won't advance the slides unless connected via the USB cable to the projector.
Mar 24, 2008 | Sony VPL CX11 Multimedia Projector
Dell 1409X DLP Projector Logo
Top Dell Office Equipment & Supplies Experts
Electro Med Services...
color wheel light...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
