Question about Texas Instruments TI 880 Matrix Printer
RESTORE DEFAULT SETTINGS ON TI880
I NEED THE PROCEDURE TO RESTORE FACTORY DEFAULT SETTINGS.
How do I restore my router to the factory setting? I have no Wi-Fi service.
Restoring the Default Configuration and Password
  • Use the restore factory settings button on the rear panel of the router. Use this method for cases when the administration password or IP address is not known.
  • This is how to restore the factory default configuration settings that reset the router's user name to admin, the password to password, and the IP address to 192.168.1.1.
  • To use the restore settings button:
    1. Locate the restore factory settings button on the rear panel of the router.
    2. Use a sharp object such as a pen or a paper clip to press and hold the restore factory settings button for about 5 seconds, until the Power light begins to blink.
    3. Release the restore factory settings button, and wait for the router to restart, and for the Power light to stop blinking and become solid green.
    4. The factory default settings will be restored so that you can access the router from your Web browser using the factory defaults.
      Then you can go through the setup procedures to setup your wireless
      Here is the link to the documentation so you can set it up again
    WNR2000 Manual Table of Contents
    hope it works for you
    Sep 10, 2014 | NetGear WNR2000 Wireless Router
    How to reset to factory default
    Restore the factory-set defaults
    CAUTION:Restoring the factory-set defaults returns all of the product and network settings to the
    factory defaults. The procedure then automatically restarts the product.
    1.
    On the product control panel, press (X451 Series) or touch (X551 Series) the Setup
    button.
    2.Scroll to and press or touch the Tools menu button.
    3.Scroll to and press or touch the Restore Factory Defaults button, and then touch the OK button.
    The product automatically restarts
    Jul 22, 2014 | HP Officejet Pro X451dn Printer
    Need to restore to factory settings on a Eee PC 1005/1001 series
    if you don't have the recovery disc, just keep pressing F9 on boot up and recovery software will be prompted to you. choose factory default settings then let it run and follow procedures. remember this will only be applied if your computer still have the recovery partition on you HDD.
    thanks..
    Apr 02, 2014 | Acer Computers & Internet
    HOW TO UNLOCK MY WIRELESS ROUTER TL-WR740N
    You should restore the Factory Defaults to get full access to the router. Be aware that all custom settings will be undone with this procedure.
    This can be achieved this way:
    * Choose menu "System Tools ? Factory Defaults", and you can restore the configurations of the Router to factory defaults on the following screen
    * Click the Restore button to reset all configuration settings to their default values.
    * The default User Name: admin
    * The default Password: admin
    * The default IP Address: 192.168.1.1
    Aug 23, 2011 | AGPtek TPLink TLWR740N IEEE 80211bgn...
    I cant log onto the web site or ip 192 thing to change my password,i cant remember my password and want to change it, but the site is always down or an empty page.... why cant they just make these things...
    Here is the procedure to reset the system to factory default:
    Here is the link to download the manual.
    Best of luck, Jim
    May 01, 2011 | NetGear WNR2000 Wireless Router
    I am trying to change color laserjet 2600n back to English and need some assistance. can you help?
    Restoring the factory-set defaults returns all of the settings to the factory defaults.
    To restore the factory-set defaults
    1 (LEFT ARROW) or the (RIGHT ARROW) button to select Service, and then press
    Use the
    (SELECT).
    2 (LEFT ARROW) or the (RIGHT ARROW) button to select Restore defaults, and then
    Use the
    press (SELECT).
    The device automatically restarts.
    Then you need to change the default settings back to what they were.
    Oct 19, 2010 | HP Color LaserJet 2600n Printer
    How do i reboot my laptop back to factory settings
    To reboot to factory setting you need to have the restore disk from the computer, put it in the drive and restart with the cd in the drive, if the startup screen does not start right away you need to type f11 or f6 to change startup order to cd first the the restore screen will startup and click restore factory settings
    Jun 04, 2010 | eMachines eMD620-5133 Notebook
    How to restore both drives C: and D: to factory settings
    C: is your operating system. That is all your recovery will restore. Once restored you can boot and reformat D: through Computer Management.
    Is it necessary to restore D? Another way is to copy the data to another drive, and rebuild the drive after breaking the partition with an OS disk. You'll need some computer savy to do this.
    Mar 13, 2009 | Acer Aspire 5633WLMi Notebook
    Forgot password to acess< and or its still default setting. could you tell me what the wireless 700 routers default password is
    Restore Factory Default Settings When you restore factory default settings to the base station, you clear your Internet connection settings and any special base station configurations that you have established. After the restore is complete, you will need to reconfigure your base station settings or restore these settings from a backup file. You should restore the original factory default settings only under the following circumstances: O You are experiencing serious problems with your base station, and resetting the base station does not fix the problem. O You cannot remember your base station password. In this situation, you must restore the factory default settings by using the Restore button on the base station, and then use the default password admin to log on to the Base Station Management Tool. To restore factory default settings 1. Open the Base Station Management Tool, and then click Management. 2. On the Management menu, click Back Up and Restore Settings. 3. Under Restore factory default settings, click Restore Factory Default Settings. While the original factory default settings are being restored to the base station, the Power light on the base station turns orange. When the light is solid green, the settings have been restored. If you want to open the Base Station Management Tool after the settings have been restored, type admin as the password on the Logon page. Do not attempt to log on to the base station until the settings are restored and the Power light on the base station is solid green. After you restore the factory default settings to the base station, you should navigate to each page of the Base Station Management Tool and reestablish the network settings you want, or restore the base station settings by using a backup file. For information about creating a backup file of your settings, see the following section. Be sure to establish your unique base station password as soon as possible after restoring the factory default settings to prevent unauthorized users from logging on. For more information, see “Change the Base Station Password.” please rate this answer, thanks
    Jan 30, 2009 | Microsoft MN-700 Wireless Router
    Printing issue
    In order to proceed with the solution to your problem, we'll need to save the current settings on your Crown printer and then restore the printer to its original factory settings as shipped. Your current settings will be saved, and can be restored after we finish this troubleshooting session. You will need to access the printers front panel in order to perform the following settings.
    Procedure to save your current printer settings
    Procedure to restore printers original factory settings
    Procedure to restore your saved printer settings
    1. Make sure the Online light is lit and that the display reads Idle.
    2. Press the Online/Offline button to take your printer offline.
    3. Press the Menu button once. The display should read Operator Control.
    4. Press the Right Arrow button once. The display should read Administration.
    5. Press the Select button once. The display should read Communications.
    6. Press the Left Arrow button until you see Miscellaneous in the display.
    7. Press the Select button once. The display should read Save Defaults.
    8. Press the Select button again. The display should read No.
    9. Press the Left Arrow button once. The display should read Yes.
    10. Press the Select button.
    11. A few seconds should pass until the display reads Yes Is Selected.
    12. Press the Online button twice to take the printer online while the display reads Idle. Your current printer settings are now saved and you are ready to proceed with returning the printer to its original factory settings.
    6. Press the Left Arrow button until you read Miscellaneous in the display.
    8. Press the Right Arrow button. The display should read Restore Defaults.
    9. Press the Select button once. The display should read Factory Defaults.
    10. Press the Select button again. The display should read No.
    11. Press the Left Arrow button once. The display should read Yes.
    12. Press the Select button. Yes Is Selected will appear in the display.
    13. A few seconds will pass and the printers display should read Disk And Flash Sys Loader.
    14. Your printer will reboot with the original factory settings and return to Idle.
    Try a test print. Does the problem still exist?
    10. Press the Right Arrow button. The display should read Custom Defaults.
    11. Press the Select button. The display should read NO.
    12. Press the Left Arrow button once. The display should read Yes.
    13. Press the Select button. Yes Is Selected will appear in the display.
    14. A few seconds will pass and the printers display should read Disk And Flash Sys Loader. Your printer settings are now restored to their original saved settings
    Try a test print, does the problem still exist?
    Sep 24, 2008 | Minolta magicolor 3100 Laser Printer
    42 people viewed this question
    Top Texas Instruments Office Equipment & Supplies Experts
    k24674
    Stevan Milanovic
    Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
