Question about HSM ShredStar X5 Shredder
Machine will not turn on
Nothing is jammed, and it is plugged in and the switch is on
Brother PC-420 sewing machine wont switch on at all.
Take off the slide plate and reseat the bobbin case. Can you turn the handwheel by hand now? If not, you may have a thread jam that seized the machine causing the security device to activate to prevent further damage. This doesn't seem like a situation that would fry a board, but if it moves freely, but still won't turn on; take it to a technician or return it.
Sep 04, 2016 | Brother PC420-PRW Project Runway...
Samsung front load washer. What is causing E3 code?
My error code database says:
Error: E3,
Machine: Washing Machine,
Type: Samsung,
Fault: Too much water in machine. Check pressure chamber for blockage,check pressure switch and air hose for leaks, check solenoid for sticking or jammed valve.
Dec 26, 2015 | Washing Machines
Rec paper jam is shown on the machine but we can't find a paper jam any where. Our machine is a Canon Laser Class 8500. Any suggestions?
Open and close all doors and trays, making sure that there are no jams, and that nothing is caught in the paper feeder. Unplug the machine, and press the power switch for at least 5 seconds. Plug the machine back in and power up.
May 31, 2011 | Canon Laser Class 8500 Printer
How to realign drive axle with brew unit after a jam? Brew unit was jammed in Magic De Luxe, had to disassemble brew unit to extract it from machine. Now drive axle will turn 1+ full revolution when unit...
You can do it quite easily if nothing is wrong with the machine by tricking the switches.
Put small plastic hose or flat screwdriver where the brewunit latches in (a small slot in the machine careful not to push away the switch lever), and similar action with the door switch. Insert the dreg draw and turn on the machine. IT will perform the selftesting and the gear will return to the neutral position.
If the gear turns very slowly there is a problem with the power card and service center job.
Jul 08, 2010 | Saeco Magic De Luxe Espresso Machine
I cannot turn off my printer. all lights are
Unplug it, wait about 1 minute and plug it back in.
May 28, 2010 | Epson Stylus Photo 870 InkJet Printer
My machine show c 210
Please specify the machine model,in the Ricoh 1035 not exist the C210 error code.
If your machine show CC201=When the paper jam condition is not reset for 10 minutes the code is automatically generated.For reset please enter in the SP mode turn main switch OFF,unplugged and wait 10 sec.Plugged and turn ON the power switch.
Sep 05, 2009 | Ricoh Aficio 1035 Copier
Showing paper jam at master disposal NOTHING THERE
Remove the power cable from power source for few minutes. If its a temporary software issue it will get sorted out. Pull out master roll and reinsert it. Check wether you have properly inserted the master disposal tray or not. If these don't work ask for further assistance.
Jul 17, 2009 | Riso RZ220 Duplicator
Won't run
If "won't run" meaning; "does not tumble/spin" this can be a couple things;
1. Defective Drive Belt (Likely): Broken or jammed (not properly attached to motor/pulley). Nothing will happen when pressing start; unit will not heat or rotate/tumble. "Normal ware and tear"
2. Defective Door Switch (Very likely) - Very common due to constant "slamming" of door. The door switch enables power to be passed through-out machine when door closes for safety purposes. Switch located at door area and can be tested for continuity. "Nothing will happen when pressing start; unit will not heat or tumble/turn". * Fairly easy to replace; two mounting screws.
3. Defective/Jammed Motor (Rare, but possible): You may hear a "humming noise" and burning smell. Also, excessive lint in blower housing may jam the motor from rotating. "Does not come on; does not tumble/turn"
Remember to disconnect power from unit before servicing.
Jan 27, 2009 | Kenmore 659 Electric Dryer
Says paper jam, but none jammed
It is probably jammed in the back door of the fax. Check that and see if you find anything.
May 07, 2008 | Brother IntelliFAX 4750 Plain Paper Laser...
HSM ShredStar X5 Shredder Logo
Top HSM Office Equipment & Supplies Experts
Andrew Taylor
Andrew Taylor
ray gallant
Tom Chichester
Are you a HSM Office Equipment and Supply Expert? Answer questions, earn points and help others
