Question about Acer Extensa 5420-5687 Notebook
South bridge over hearing
Shuts down
I have toshiba satellite l645 I was going to bed and I put it into hibernation mode like I always do then the next day I get home I go to turn it on and it turns on but the screen stayed black. The power...
There are some problems which may cause that:
1. Memory defect.
2. South bridge defect.
3. Bios Defect.
Try this one to find out which one is your problem:
1. Remove your battery and plug the external monitor via VGA or HDMI port and turn your laptop on with the AC cord attached to the outlet. When you can see its welcome screen via external monitor then it has a problem in its LVDS driver. But when you see nothing then try the second step.
2. Unplug the Cmos battery located under the palm rest on the left side of the touch pad, wait for about 2 minutes and then you can try to turn it on. When nothing appears on the screen then the problems may cause by your south bridge defect. To know this problem just touch your south bridge while it is turned off, when it is warm then your south bridge is working but something wrong with its pin. When it is cold then your south bridge has a problem in it.
When you see the two above step yield nothing then better for you to bring it to a service centre.
Good luck
Aug 30, 2017 | Toshiba Satellite L645D-S4056 laptop
Motherboard south bridge solution my compaq laptop
HP/Compaq web site should have all the drivers you need for your computer.
Nov 05, 2013 | Computers & Internet
Usb drivers problems
try to install drivers from Acer support website, also you can enroll to earler system configuration using windows recovery points, if they works befor. Also it may be hardware problem like bad soldering of south bridge, in this case you need to reball south bridge , if it is not solve a problem then you need to replase south bridge.
Nov 15, 2012 | Acer Aspire 5100 3010 Notebook
What is south bridge on acer 5103
it is on the board and you can not fix that i would just buy a new board or see if it is under warnt. it is a big chip on board not worth the problems myself,
Nov 23, 2011 | Computers & Internet
Hardisk some time diduction some un deduct
Make sure you plug hard disk firmly.Then also not working
It could be the problem of south bridge, the south bridge controls hdd.
Jun 17, 2011 | Intel 845GE Motherboard
Dell XPS 600 just dies. Power shuts off with no messages.
This could be one of Three different things:
1) Your PC is overheating. Clean out the dust around the processor fan and intake vents. Make sure that your fan is working. Make sure that the North and South Bridge chips are not overheating either (the two other large chips on the motherboard)
2) Your Motherboard has defective Capacitors. Once your Capacitors start bulging or leaking, the board will need to be replaced.
3) Your Power supply is failing. Not dead yet, but enough of a pause in power distribution to cause the entire system to go down. Power supply can be replaced as well.
Aug 11, 2010 | Dell XPS 600 PC Desktop
The south chipset bridge of my Asus k8n-vm motherbard heats up
85 to 95 is ok. Anything higher than100 is pushing it. If possible add a fan to the side of the system case (Best choice) or you can buy a south bridge fan. You're MB doesn't have holes in the MB to attach a chipset fan but you can still attach a cooler on to the chipset. Like this fan; http://www.newegg.com/Product/Product.aspx?Item=N82E16835103155
And you'll need this as well for a good bond; http://www.outletpc.com/c2019.html
Enjoy!
Mike
Jun 12, 2010 | ASUS K8N-VM Motherboard
South bridge bursted out
Unfixable, the entire motherboard must be replaced.
Jun 02, 2010 | HP Compaq Motherboard
Find north and south bridge for asua maximus 2 mother board
I do not the north bridge of this motherboard is different from others. mainly ram ports and Graphics card pord is called north bridge. read it for more. ( click here )
May 24, 2009 | ASUS Maximus Formula Motherboard - 45nm...
Acer Extensa 5420-5687 Notebook Logo
18 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
