Question about HSM 125.2hs Shredder
Looks like paper is jammed but won't come out
Some sort of paper is jammed and won't come out, how can I fix this?
Jammed paper shredder motor stopped won't start
Had this sort of thing happen to me also; sort of. Did you check to see if the shredded paper level alarm has been triggered in the pull-out catch area? Sometimes it forms a pile that trips the alarm before the catch is full. Sounds simple, but check it out. Also check to make sure it's plugged in! I've done that several times, even to the point of calling for help! Did you know the technical help desk always asks if the machine is plugged in first!
Feb 20, 2013 | Office Equipment & Supplies
Canon Inkjet, Not Printing?
Hi Rosa,
There was a paper jam and you cleared the jam, however you missed out to do one other thing. Cleaning the Rollers.
If the Paper Feed Roller is dirty or paper powder is attached to it, paper may not be fed properly.
In this case, clean the Paper Feed Roller. Cleaning will wear out the Paper Feed Roller, so perform this only when necessary.
You need to prepare: three sheets of A4 or Letter-sized plain paper
1.Make sure that the power is turned on, and remove any paper from the Rear Tray.
2.Open the Paper Output Tray gently, and open the Output Tray Extension.
3.Clean the Paper Feed Roller without paper.
(1) Press the g0081065_tcm14-774017.jpg (Maintenance) button repeatedly until b appears.
(2) Press the Black or Color button.
The Paper Feed Roller will rotate as it is cleaned.
4.Clean the Paper Feed Roller with paper.
(1) Make sure that the Paper Feed Roller has stopped rotating, and load three sheets of A4 or Letter-sized plain paper in the Rear Tray.
(2) Make sure that b appears on the LED, then press the Black or Color button.
The machine starts cleaning. The cleaning will be completed after the paper is ejected.
This should fix the issue
Regards,Suhail
Nov 03, 2011 | Canon PIXMA MP495 InkJet Printer
...Still "paper jam". I did
This article in the Lexmark website on How to Troubleshoot a Paper Jam or Misfeed on the Lexmark P4350/P4330 Photo All-In-One will help you fix the paper jam problem. However, if problem continues, there could be some sort of foreign objects that fell into the paper feed system. Grab a flashlight and look into the feeder for any foreign objects that's in the paper path or, if you are capable and willing, carefully lift your printer upside down so the foreign object will freely roll out from the feeder.
Apr 03, 2011 | Lexmark P4350 All-In-One InkJet Printer
My kodak All-in-one printer ESP9 goes instantly in paper jam. Checked for a paper jam and found no paper jam or any paper anywhere inside machine. Pressed down on "OK" button and printer...
Had same issue with my ESP 9, called up the kodak support lines and spoke to them over the phone, getting a replacement sent out free of charge and I've owned this for 1 year and 4 months and only had one prior printer jam which righted itself in the past. Seems like ESP 9's are prone to the unfixable printer jam.
Best bet call kodak and get it sorted.
Jan 12, 2011 | Kodak Office Equipment & Supplies
Paper jam display
open machine look for an upright lever at the paper in side.... it is called a paper detection switch its function is to detect the position of the paper movement through the machine, if the paper does not trip the switch at the right time the machine will indicate a paper jam and shut down, most machines have this sort of detection system
Dec 21, 2008 | Toshiba Office Equipment & Supplies
Paper getting jammed when rotate sort
To clarify LT and LT-R are both 8 1/2" x 11", most models of Toshiba will ask what size paper are in the drawer when they are open and shut,. if you have LT paper (landscape) in a drawer, but tell the machine it is LT-R (portrait) when it tries to feed it will jam because it "senses" you are missing 2 1/2" of paper. So make sure your settings are correct, in my experience this is 90% of the jamming issues on Toshibas. Rotate sort uses both drawers to interleave the LT & LT-R into "stacks" so they must be opposite directions but corresponding to correct direction (portrait, landscape)
Oct 23, 2008 | Office Equipment & Supplies
Phantom paper jam
Same problem here. I'm googling around looking for ideas.
Sep 07, 2007 | Brother MFC-8640D Printer
Fake paper jam
I had the very same problem unitl a moment ago!! I found some A4 card and forced it through the printer. I tried to print a document as usual, as the rollers (inside the printer) lifted, i pushed the card through in an attempt to clear any blockage which wasn't visible to me. It cleared the block and is now working perfectly again !! give it a go.
Aug 16, 2007 | Epson Stylus Photo R300 InkJet Printer
HSM 125.2hs Shredder Logo
67 people viewed this question
Top HSM Office Equipment & Supplies Experts
Andrew Taylor
Andrew Taylor
ray gallant
ka4iup
ka4iup
Are you a HSM Office Equipment and Supply Expert? Answer questions, earn points and help others
