Question about Kenwood KVT-512 Car DVD Player
Ken wood with DVD receiver kvt518
Turn by turn direction incorrect turns given.
My ken wood will keep my radio stations, but it won't keep anything else. Demo mode pops up every time i turn on the radio, and i don't know how to make it stay off. I turn it off, but when i turn my
Try, looking a code to activate alot radios have a code to take them out of demo mode, i would consult the owners manual for a code of some sort
Jul 29, 2014 | Kenwood Car Audio & Video
How do i turn off demo mode deh-x6500bt
that sounds like it was wired incorrectly, if your accessory power is 'off' (key off) the head unit should not be receiving power, and should not stay on, you might have power coming directly from the battery instead of accessory power.
Feb 27, 2013 | Pioneer DEH-X6500BT MP3/USB A2DP Bluetooth...
My stereo screen goes blank when I touch any control nob is there a way to stop this from happening. My unit is a ken wood excelon kdc-x996.
You have to go into the menu for the different functions, The display probaly is turn off, It will show display options,
Nov 05, 2012 | Televison & Video
Why doesn't it say the NAME OF THE STREET that you are to turn on? It will tell you how far ahead the turn is and then tell you to turn R or L but it doesn't give the name. Also, there have been several...
I have a tomtom 920, it will say the street name to turn on if set to do so & only then if using computer voices, not human voices. Tuning the wrong direction could be its wrong or its trying to take the fast route via a highway, longer route but get there faster
Jun 22, 2010 | Garmin nuvi 255W GPS Receiver
The sub-woofer output on the receiver is not working. I have tested the sub-woofer (speaker) and it works. And I have tested the cables and they work. The problem lies within the receiver. How can I fix...
I don't have the manual, but if YOU do, crack it open and find the part where you tell the receiver it HAS a subwoofer and any other settings that direct bass toward it.
Apr 18, 2010 | Sherwood RVD-8090R Receiver
No audio from Harman Kardon AVR 7000
Incorrect polarity between receiver and speaker will not damage receiver however unmatched impedance speakers can damage amplifier section of receiver.
Please check connection cables in receiver and if receiver does not shut off in protection mode then it could be connection cable broken or some dry / cold solder joints on circuit boards in receiver.
Re-soldering of cold solder joints is job of qualified tech.
Sep 14, 2009 | Harman Kardon AVR 7000
Please help
try resetting the unit if that dont work you may have contact ken wood for the security code for that model unit --hope that help you in the rite direction
Jul 01, 2009 | Kenwood KVT-512 Car DVD Player
Onkyo htr 330 universal remote codes
I have the HT-R570 Receiver and here's what I ended up doing to use the Verizon FIOS DVR remote to turn the receiver on and off with volume control. Know that Onkyo uses 2 codes 1 for on and 1 for off so use the AUX for ON with Volume control and the DVD for OFF. (I rarely use my DVD and when I do I use the DVD remote that came with the DVD)
Use the AUX and codes 1347 or 1558 to turn the receiver on with volume control. Press AUX and OK together and release. Enter the code. it should now turn the receiver ON with volume control.
To use the DVD button to turn the Receiver OFF, you have to use the search method to capture the code. Tried every code I could find on the internet and their is no universal code for OFF and ON.) With the receiver ON, push down DVD and OK together and release (should get 2 flashes of all component keys) enter 922 and with remote pointing at the receiver press the >" (forward/pause button) then press and release the >> (fast forward button) until the receiver turns off. If you go too fast and go past it, quickly turn receiver back on (within 20 seconds) and press-release the <<(backwards button) slowly until it turns off again. Then press the OK button to store the OFF code in the DVD function button. Any questions...E-Mail me at MrBlueOcean@verizon.net Lots of Luck!
Nov 30, 2008 | Onkyo HTR500 Receiver
Unit will not turn on
Hello sympleman,
What you are describing may very well be a result of the battery going bad. The internal battery in your GPS receiver does have a limited lifespan. It is normal for the amount of operating time between charges to gradually decrease until eventually the battery pack does fail.
Unfortunately the battery does not appear to be replaceable by the user. To get the battery pack replaced you can contact Garmin directly. Their website is http://www.garmin.com.
Best Regards,
Ken
"Go Ahead. Use Us."
Jun 23, 2008 | Garmin Quest 2 GPS Receiver
Pioneer media receiver pdp-r04u
try testing dvd player direct to tv dont use uvsal remote go to tv turn it on and change inpput to dvd see it works
Feb 06, 2008 | Pioneer PureVision PDP-4340HD 43 in....
Kenwood KVT-512 Car DVD Player Logo
42 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
