Question about Gateway DX4300-03 Desktop PC
Dx4870 gateway getting video but no audio from hdmi port
Getting video but no audio from HDMI port what should i do?
  • 39 Answers
Ensure the monitor is set to HDMI input. Sometimes you can bump the wrong button on the monitor and it sets to VGA.
If this does not work, Check the sound out, ensure it is set to speakers.
Posted on Apr 22, 2014
SOURCE: HDMI port isn't working for multiple monitors
Thats a hdmi audio port not video.
Posted on Jul 12, 2010
SOURCE: I have HDMI port on back of Gateway. I plugged a
Hello, I have a Gateway DX4300,For the HDMI to be detected you need to power on the device it's conncted to
Posted on Dec 11, 2010
SOURCE: I can't get a signal from my desktop to my hdtv
First, make sure the computer port is working in the computer by going to the device management ICON in control panel.
Once you check that, make sure you have set up your preferences in the TV to allow "INPUT" from the HDMI port. If you have more than one HDMI ports make sure you have the correct number listed. This is a common error. It would be the same if you are running a DVR with an HDMI cable, you need to set up the TV. Normally you hit the "INPUT" button on the remote control and a list pops up. Scroll over with the arrows to the correct HDMI port. You will likely need to do this again to get back to the cable input once you are finished with the computer connection.
Posted on Feb 10, 2011
  • 910 Answers
SOURCE: what is the second hdmi
I presume by second HDMI that you've got an additional Video Card in one of the expension slots (Item 10 at the link below) with another HDMI output
http://support.gateway.com/s/desktop/2010/gateway/dx/dx4840/DX4840rv.shtml
The HDMI surrounded by orange is an ouput but if you've got and additional Video Card then this build in HDMI would normally be deactivated.
Sometimes the problem relates to the screen resolution you've got your computer set to as this needs to match your Monitors HDMI Input i.e.1280x720 or 1920x1080 as detailed at the link below.
http://hd.engadget.com/2006/02/08/how-to-connect-your-pc-to-your-hdtv/
Posted on Jul 26, 2011
bronk50
  • 27725 Answers
SOURCE: I can't get past the initial login screen for my Gateway dx4870. when i enter the password it says incorrect password
Reboot the computer As the computer is booting repeatadly press the F8 key as the computer is booting
If done properly the user should get to a screen similar to the below screen.
Select the option for Safe mode command prompt only
Windows Advanced Options Menu
Please select an option:
Safe Mode
Safe Mode with Networking
Safe Mode with Command Prompt
Enable Boot Logging
Enable VGA mode
Last Known Good Configuration (your most recent settings that worked)
Directory Services Restore Mode (Windows domain controllers only)
Debugging Mode
Start Windows Normally
Reboot
Return to OS Choices Menu
Use the up and down arrow keys to move the highlight to your choice
select safe mode with command prompt
Click start run type cmd press Enter
black screen should open DOS mode
this will vary depending on your operating system
type in net user username
For eg. If you want to change administrator password , type net user Administrator
it will prompt you to enter the new password
enter the new password and the password is changed
hope this helps
Posted on Jul 17, 2012
How can i connect my hp pavillion s5610y to my bravia tv
This is a bit complicated since there is no HDMI output capability to the PC, only VGA and DVI. First, check to see if the Bravia has one of its HDMI ports listed as DVI capable. If it does, it should have accompanying audio jacks (red/white) for it. What you would need to get is two different cables for interface. The first is a DVI-to HDMI cable to run from the PC DVI port to the Bravia DVI-compatible HDMI port. You cannot run the DVI to a regular HDMI port because if you do you will get only picture and no sound. DVI outputs, unlike HDMI outputs, do not carry the audio signal. A DVI-compatible HDMI port on a TV set will connect the video from the HDMI port and the audio from the reserved audio port accompanying it. The second cable you need will be a mini stereo audio plug to RCA jacks. This will connect between the PC audio out (green), and the DVI audio plugs on the set. See pictures for cables below
Once you have this done, selecting the appropriate HDMI port on the set should result in audio and video getting to the unit. If you only need the video (you are going to use the PC speakers), then you don't need the audio cable and you can use any HDMI port, but you cannot control the volume using the TV set remote. You would need to use the PC volume settings. (Just as an afterthought if the set has no DVI-compatible HDMI port).
Jan 26, 2016 | HP Computers & Internet
How to fix my gateway DX4870-UB20P that overheats
The best that you can do is to make certain that all of the fans turn and are clear of dust, cat hair and other blockages.
Also the case is designed for air to flow thru it with the covers in place.
You may wish to add an additional fan to blow into the case.
Jul 02, 2014 | Gateway DX4870-UB20P Core i3-2120 3.3GHz...
Three beeps, pause, three beeps
I have the same problem. The motherboard is bad. Looking for a replacement now.
Mar 24, 2014 | Gateway DX4870-UB20P Core i3-2120 3.3GHz...
Dx4870-ur3d no audio from hdmi port
It may be your system does not support sound over HDMI, as some computers don't. I would double check this is a feature your system supports.
Mar 18, 2014 | Gateway Computers & Internet
I can not get 7.1 HDMI audio output on my Gateway GM5664 running Windows 7.
While DVI and HDMI offer compatible video lines, the DVI connection offers support for two analog audio channels only and cannot transport data packets required for digital audio. You will not get anything beyond 2.1 audio across the dongle.
If you have a HDMI connector on your graphics board and your external hardware, try to use a proper HDMI cable.
Mar 14, 2014 | Gateway GM5664 Desktop PC
I bought a new computer case and I want to use my mobo from my current pc. Gateway DX4870-ub318. I can't tell which pins to use for the power.
You will get better help at a computer repair shop than a component sales outlet. The same problem with two monitors suggests either bad cables or motherboard trouble.
Feb 26, 2014 | Computers & Internet
How can I get my Gateway desktop to recognize my Projector?
it has to be set up as an additional monitor/display. so, there are settings to set up the displays as either twins, unique seperate or something like that. have not had to do it. but i know that the graphics have to be able to recognize what format the signal is. pc settings change and graphics setttings change. have you done both? the projector should have had instructions? if not look for the manual online.
Aug 23, 2012 | Gateway Computers & Internet
Just set up RX-A700 two things seem wrong. 1. HDMI 1 won't show video if HDMI is plugged in, once plug on HDMI is removed from receiver HDMI 1 works perfectly. 2. HDMI output needs to be held tight or else...
sounds to me like a bad HDMI cable. Just replace it.
If HDMI still wont show, move to another HDMI port. But based on having to hold HDMI cable with hand to steady the connection, it is either a bad HDMI cable, or a bad HDMI port on the receiver. Good luck
Jan 23, 2011 | Yamaha RXA700 Receiver
is the card your using able to put out 2 feeds?
Jun 01, 2010 | Gateway DX4300-03 Desktop PC
No sound on DVR HDMI port, but does work on other HDMI port
Not all HDMI ports support Audio or they do but only one way Audio out or Audio In. If you have an optical connection you can try that.
Apr 04, 2010 | Yamaha HTR-6130 Receiver
Gateway DX4300-03 Desktop PC  Logo
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
