Question about Hoshizaki Freezer Commercial Ice Machines - KM900MRH Commercial Ice Machine
Will not turn back on 3 beeps
Turned it on after being off for a week & it beeps 3 times but don't start at all.
  • 45 Answers
Remove the screw(s) and slide the cover towards the front (the cover over the control board near the wash/ice switch.) with the machine on carefully locate the reset button on top of the circuit board and push to reset..
Posted on May 22, 2014
Hi .my hoshizaki ice machine it till running but do not make ice . Can you tell me , what wrong with the machine ? Thank you
The machine, all in one, not indoor/outdoor split type, will make beeping sound when something is wrong and stops working until it is turned off and turned back on. Some times the machine needs to be reset with the power on, covers removed, reset button inside on electronic mother board.
The ice machine covers have instructions and information on beeping sounds.
Aug 27, 2017 | Hoshizaki Freezers
Ice maker not making ice. When pressing the test button will start to make some and then beep about 3 times, then does not produce anymore ice.
Do not use test button. It test the functions of the board only. You have another issue. Need to know the number of beeps. Usually beeps a certain number of times, then hesitates,then beeps again.
Jul 27, 2011 | Hoshizaki Freezer Commercial Ice Machines...
My power wen out and now my kenmore chest freezer high temp alarm is beeping and now it wont cool
I'd turn unit off...unplug it for a few minutes...plug it back in...and turn it back on setting the thermostat again.
Hopefully, you'll hear the compressor kick in and start cooling again.
Hope this helps...
Jul 23, 2011 | Freezers
The temperature alarm goes off randomly. It remained silent for 6-10 hours after I turned it on originally then started to sound. I shut the alarm off for 10-12 hours then turned it on again. Once more it...
If you just purchased the freezer 3 weeks ago, I would be calling the store and or the manufacturer, and have them send out a service man to fix it or replace it.
May 02, 2017 | Whirlpool 19.6 cu. ft. / 555 liter Upright...
The ice machine it beeping 3 time. I reset the little white button on the pc broad. It run for a while and the beeping sound come back. I know if I hit on the F/S with my crew driver it turn to diffrent...
sounds like you may have more than one issue. Tapping the float switch indicates that it is sticking. This will keep the water coming in and the unit will not go into it's freeze mode. Go to the Hoshizaki web site for how to remove and clean. It's really not that hard. If you can't find it, I'll walk you thru.
With the machine turned off, is there still water running? IF so, the water valve is also stuck in the open position and letting water in. This could cause it to have long freeze cycles and possibly freeze up.
Start there and let me know if you need any more help.
http://www.hoshizakiamerica.com/techsupport/tech.asp?
Feb 27, 2010 | Freezers
It beeps 3 times then pauses then beeps 3 times then pauses. Keeps this pattern
Unit was in the freeze cycle for 60 minutes and the freeze back up timer took over the process. In most all cases, either a stuck float switch or a leaking water valve.
Hope this helps.
Sep 25, 2009 | Hoshizaki Freezer Commercial Ice Machines...
New freezer not cooling - temp @ 25 degrees and food is defrosted
It is probably the control board and since it's new it's still under warranty so a certified Frigidaire repair man will fix it without charge. There should be a telephone number with the paperwork you received when you bought it.
Aug 29, 2009 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Beeps 3 times when turned on
3 beeps means the machine has ran two 1 hour cycles back to back to make ice an average timeframe for ice making is 25-30 min. Could be several issues, float switch dirty, water valve leaking by, dirty spray tubes, dirty evap., then go to refrigeration Expansion valve, compressor, charge, Hot gas valve leaking by,,,,,
Jun 23, 2009 | Hoshizaki Freezer Commercial Ice Machines...
My ice machine only harvest 2 time and start to 3 beep eveaperater very clean no scales inside because i descale every 2 weeks can u help me
In most cases, there is a chart on the inside of the front cover. It may also be located on the side of the box where the control circuit board is located. It will tell you what the 3 beeps mean. Hoshi has a great tech support. It's worth the wait.
Feb 02, 2009 | Hoshizaki Commercial Freezer KM-500MAH
Km 500 kae hoshizaki 3 beeps every 4 second compressor not coming on
put an amp probe on common wire at compressor and see what amps are when it tries to start. 40 to 60 is mechancially locked up compressor. kill power and test start and run capacitors. there is an thermal temp over load on the compressor that opens when comp gets hot from trying to start. gently remove and look for cracks or burned looking. . i saw one this week doing exact same and i have ordered the oem compressor start cap realy and run cap and drier and will put in all new gas. be sure to allow sufficient time when switched to ice for it to get to ref cycle, it may take 5 minutes starting with water purge, then fill, etc. good luck, call hoshizaki dist they are usually pretty helpful if you need a auth service rep in you area. i think they are three years warrantied!
Oct 25, 2008 | Hoshizaki Freezers
Hoshizaki Freezer Commercial Ice Machines - KM900MRH Commercial Ice Machine Logo
214 people viewed this question
Top Hoshizaki Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Hoshizaki Freezer Expert? Answer questions, earn points and help others
