Audiovox d1998 DVD player was dropped and now will not load disc screen says it's loading but never does. Finally will say no disc. Everything else seems to be ok
The above is all info on back
4 Suggested Answers
SOURCE: Audiovox D1020 DVD player won't read DVD anymore
I have the same problem! The only way to fix this is to replace the motor that spins the DVD. if you take it apart and spin the DVD the movie will play. The motor is just wore out and has no torque to start the play process. I am still looking for a replacement motor for it and haven't found anyone that carries the motor required. Only Audiovox so far and they want 180 to send in and fix.
Posted on Jan 16, 2009
SOURCE: Audiovox D1998 portable DVD player will no long read disc.
This of course may not be the exact same thing, but mine did the same thing. Sounding like it was loading, but in fact pressing the open button it I could see the disc not spining at all (normally you would.) With the power off of course. I took all the bottom screws out (where ever the arrow points to a screw) including to the display. There is one ribbon cable easily disconnected. I lifted the mount the DVD sits on and reseated it. I put a disc in it, turned on the power and the disc turned. Great I thought. I reconnect the cable, put the screws back in - and its working.
Posted on Aug 19, 2009
  • 5 Answers
SOURCE: Audiovox D1998 Portable DVD Player will not load DVD
you need to clean the disc and make sure it fits in wright if that dose not work try another disc.
Posted on Sep 15, 2009
Won't complete the load disc process
Loading may mean it is not seeing the disc---A dirty or bad optical pickup is possible if you get this error with every disc.
Jun 06, 2012 | Audiovox D1812PKG 8 in. Portable DVD...
My daughter has an Audiovox D1998 model and isn't reading the disc. where can I go to have this fixed and what would be the approximate cost?
Try a CD disc lens cleaner (can be found at Radio Shack, Wal Mart, Best Buy). Is it still under warranty? If not try your local TV repair shop for an estimate. But beware most shops do charge a diagnostic fee to look at the equipment. Note: Since these units can be found on the net for about $100 you may come out better with getting a new one.
Oct 21, 2009 | Audiovox D1812 Portable DVD Player
Sep 15, 2009 | Audiovox D1917
Can this be fixed?
i have an audiovox dvd player model D1718 . i put the disc in and it says it is loading but then comes up no disc . how can i fix this problem?
Sep 11, 2009 | Audiovox D1708 Portable DVD Player
Apr 22, 2009 | Audiovox D1917
Audiovox D1210 DVD won't load to play. When we put in a DVD to play a movie, the screen displays "loading" for a while and then reads "no disc". Using a can of air (and sometimes jolting the player itself)...
Your DVD players may have slip out of calibration. You can try setting them back to factory specifications. To do this go to the set up menu main page. Highlight preferences and press enter.Next highlight defaults and press enter. This will reset the DVD player to the factory settings. This procedure is explained in the owners manual on page 26. If this does not solve your problem, you can try using a cleaning disc to clean the laser head and transport. This should restore the laser, and transport so that you can use it. If you are still experiencing problems with the DVD player, you can call Audiovox customer support at this telephone number. 1-800-645-4994. Give them the model number of you DVD player and tell them about the problem you are having with the DVD player. I hope this information helps you with your problem.
Feb 18, 2009 | Audiovox D1210 Portable DVD Player with...
Disc won't load
I made the same mistake and settled for the cheaper solution. Had nothing but problems with it check out: www.invisionindustries.com
Purchased the SL 7 for my wife’s Ford Edge and the Invision system is worth every penny! Best of luck.
Jan 12, 2009 | Audiovox ADV12 Portable DVD Player
Audiovox portable dvd player PVS3393
will not play dvd after loading the screen shows no disc
May 24, 2008 | Computers & Internet
Screen reads NO DISC
I had the same problem but I solved buying "Laser Lens Cleaner " Philips Magnavox after 3 attempts the DVD starts to work fine again. First only 3 min, then 10 min and now the entire CD cleaner and after I left the CD cleaner for 15 min I tried to play the DVD and WORKS!!! perfect!!!
Nov 08, 2007 | Audiovox D1420 Portable DVD Player
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
