Question about Zoeller Electrical Supplies
What heights should floats be set
Alternating dual vertical pumps
  • 3600 Answers
SOURCE: float height 1996 gsx r750T. Where exactly on the
you put it on the float base and allow the float to drop down and read the gauge where the float is read the top of the oppiste side where the float is hinged.
Posted on Aug 23, 2009
  • 83 Answers
SOURCE: just need the height setting for the floats the
YOU CAN ADJUST FLOATS WITHOUT SPECIAL TOOLS. ALL YOU NEED IS A FOOT LONG PIECE OF CLEAR TUBING, SIZED TO FIT THE BOWL DRAIN. SET FLOATS AS CLOSE TO WHAT THEY WERE WHEN YOU REPLACED IT. INSTALL THE BOWL AND PUT THE TUBE ON THE DRAIN. OPEN THE BOWL DRAIN SCREW WHILE HOLDING THE TUBE UP BESIDE THE CARB. WHEN YOU GET THE TUBE BESIDE THE CARB ASSY., THE GAS IN THE TUBE SHOWS YOU THE EXACT LEVEL OF FUEL IN THE BOWL. FROM THIS YOU CAN MAKE ANY ADJUSTMENTS NECESSARY FOR CORRECT LEVEL. THE LEVEL SHOULD BE RIGHT BELOW THE PLANE WHERE THE BOWL MEETS THE CARB BASE.
Posted on Oct 22, 2009
  • 14036 Answers
SOURCE: how to set the floats on 1980 honda fcivic
YOU CHECK FLOAT LEVEL LOOKING AT THE SIGHT GLASS ON THE RIGHT OF THE CARBURETOR.FUEL LEVEL SHOULD ALIGN WITH THE DOT ON THE SIGHT GLASS.IF THE LEVEL IS ABOVE OR UNDER THE DOT THE CARBURETOR HAS TO BE DISASSEMBLED.TO SET FLOATS REMOVE AND INVERT THE AIR HORN UNTIL THE FLOAT ARM JUST TOUCHES THE NEEDLEVALVE OR THERE IS ABOUT 0.1 mm OR 0.004 INCH CLEARANCE BETWEEN THEM.MEASURE THE DISTANCE BETWEEN THE BOTTOM OF THE AIR HORN GASKET INSTALLED.AND THE CENTER OF THE BOTTOM OF THE FLOAT.THE DISTANCE SHOULD MEASURE 36.4 mm 1.39 - 1.47 INCH. ADJUST BY TURNING THE NEEDLE VALVE SEAT.BE CAREFUL NOT TO ALLOW THE VALVE SEAT TO PROTRUDE FROM THE SEAT ATTACHING BOSS.WHICH WOULD ALLOW THE VALVE TO FALL.IF THIS IS THE CASE BEND THE FLOAT ARM SLIGHTLY UNTIL PROPER CLEARANCE CAN BE OBTAINED.WHEN CARBURETOR IS INSTALLED CHECK FLOAT LEVEL BY LOOKING INTO THE CARBURETOR FLOAT SIGHT GLASS I MENTION IN INFORMATION ABOVE.IF YOU HAVE A 1487cc AND 1600cc CVCC MODELS WITH THE KEIHIN 3 BARREL CARBURETOR.THIS WOULD DEALERSHIP JOB.THIS TYPE IS HARD TO ADJUST.
Posted on Jan 30, 2010
ckoira57
  • 267 Answers
SOURCE: floats not set
Float tabs come set flat to surrounding plate, bend up to decrease level and down to raise level. Raised level too much and you risk fuel overflow on sustained inclines and too low a level and you will lean out at high revs and damage valves/piston real quick. There is no set level to speak of, but better to err on the side of losing a bit of overflow. The overflow drains from the carby via a plastic hose from just above float bowl flange.
Cheers.
Posted on May 08, 2010
  • 10 Answers
SOURCE: Float height setting
Back firing is normally an electrical problem. The carb is sometimes adjustable but needless to say, it doesn't go out of allignment on its own, so bear that in mind when trying to eliminate the carb. If it is choking when ticking over, check the idle jet setting.
Good luck.
Posted on Dec 08, 2011
1983 Honda GL 650 float height
Hi, Henry for this scenario you will need your service, parts fiche, and owners manual if you can't find the best tool you ever bought for your Honda, despair not, for a mere zero $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Adjusting the Float Level
Setting the float height the easy way
http://www.cyclechaos.com/images/d/d6/Honda_GL500_GL650_Service_Manual.pdf
http://www.partsfish.com/page/oem-parts-for-honda
http://mybikemanuals.com/honda/honda-gl-owners-manuals
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Jul 12, 2017 | Honda Motorcycles
How do I adjust the float switch on a pz 19
Hi, Anonymous for more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
How to Set the Float Height on your PZ Carburetor
How to Set the Float Height on your Walbro PZ Carburetor
Float adjustment
Adjusting Carburetor Float Level
Keihin Carb Float adjustment trick
Oct 18, 2014 | Motorcycles
Have a monarch type a 1/2 hp model be-e50 effluent pump which runs constantly and will not **** off what are some of the reasons ?
If it is a submerged pump, it needs a "float switch", This is a (usually) a ball made of plastic that floats in the liquid and senses the level gets to a certain height it will allow the pump to run until the level is down below that height.
Aug 30, 2014 | Cars & Trucks
What should the Float Height in my carburetor be?
Floater height i have adjusted to 2/3 level of all carb reservoirs individually and to date it has been performing to the best. 23km/ltr dual carb GS450E.
Jul 29, 2014 | 1981 Suzuki Gs 550 L
I have a pacific hydrostar vertical float sump pump that will turn off, How do I adjust the float switch.
The Float Switch (2) automatically switches on and off at a water depth of approxi. mately 4 inches. The ON/OFF height can be manually changed by adjusting the Float Switch Lock.
Jan 28, 2011 | Plumbing
What is the float height on 1974 yamaha 175 enduro with needle closed and where do i measure
hi, looking in my manual for that year of bike, there is no mention of the float level, however normaly the float height of a constant depresion carburettor such as this is 27mm, this can be checked by holding the carburetor vertical with the air filter side facing up then slowly invert it until the float is just resting on the needle and not compressing,it.measure the distance between the gasket face of the carburettor and the bottom of the float. the fuel level can also be checked by using a lengthh of clear fuel pipe fitted to the drain at the bottom of the float chamber, undoing the drrain screw with the fuel pipe turned upwards toward the slide the fuel will climb up the pipe and show the present level,
Jan 19, 2011 | Yamaha DT 360 Motorcycles
1989 Honda CB 1 carburetor float height
Hi, Bryndynw for this scenario you will need your service manual, parts fiche, and owners manual if you can't find the best tool you ever bought for your Honda, despair not, for a mere zero $0 you can download another one.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
1989 Honda CB 1 carburetor float height Google Search
Need proper float height settings
1989 1990 Honda CB 1 CB400F NC27 Service Manual Moto Data Project
https://www.partsfish.com/page/oem-parts-for-honda
HONDA CB400F 1989 Owner Manual
Mar 19, 2010 | 1989 Honda CB 1
Just need the height setting for the floats the
Oct 22, 2009 | 2006 Yamaha V Star Classic
Electrical Supplies Logo
Top Zoeller Electrical Supplies Experts
Craig Butler
Craig Butler
TEKUSER
TEKUSER
Are you a Zoeller Electrical Supply Expert? Answer questions, earn points and help others
