Question about Radio Shack Radio Communications
NEED A MANUAL FOR 63-903
Vox clock 2
How do I program a HT1000 to have VOX capability?
Vox isnt part of the HT1000 you need the C6000 PTT-VOX Adapter Bodyswitch
Aug 13, 2014 | Motorola HT1000, MTS2000, MTX8000/9000...
I am having trouble programing VOX to work on motorola rdu 2020 2-way radios
Here is a link to the user guide: http://www.twowayradiosfor.com/pdf/RDX-Non-Display-manual.pdf
Instructions for setting the VOX sensitivity are on page 33.
According to the manual you program the VOX using the CPS (software). Three things which usually cause end-user problems are:
1) Failing to set the sensitivity to a number 1, 2, or 3.
2) Failing to have the radio shut off when plugging in the audio device (headset or earpiece)
3) Failing to use a VOX capable audio device. (Not all headsets and earpieces are VOX capable. Many with inline PTTs are not.)
If these items or instructions do not help, stop by your local Motorola dealer to discuss the problem.
Best regards.
Sep 22, 2010 | Motorola RDU2020 Two Way Radio
Have it on cannel 4 04 but VOX is in the upper left corner. can hear but can't send.
The manual isn't specific, but your VOX feature likely works only with an optional external mic. To turn this feature off for normal use,
- Press MENU four times (display will show VOX)
- Select oF by pressing the up or down arrow key
- Push the PTT button to confirm and return to normal operation
Dec 22, 2009 | Midland LXT310 2-Way Radio
Forgot how to get the VOX working on AXU4100
The AX series did not have VOX capabilties. Here is a link to the Owners Manual for the Motorola AX series two-way radio.
http://www.hitechwireless.com/pdf/AXSeriesManual.pdf
Mar 29, 2009 | Motorola AXU4100 (10 Channels) 2-Way Radio
Have no info booklet need to get rid of feed back
To select the VOX level:
1) Enter the Menu. Advance through the Menu until
the vox icon appears on the display. The current
level (OFF, 1-3) will be indicated. Level oF (OFF)
disables VOX, while levels - set the
sensitivity of the VOX circuit.
2) Press either the up arrow or down arrow key to the desired VOX
sensitivity level. Use level 1 for increased
sensitivity to voice in normally quiet
environments, and use a higher level to reduce
undesired activation in very noisy environments.
3) Exit the Menu.
Feb 27, 2009 | Uniden GMR-325/2 2-Way Radio Walkie Talkie...
Okay on my 2 way radio i turn wox on and then turn the radio off plug the headphone in turn the radio back on and then the vox is turn off again
you miss to save your last program,after you turn to vox mode you must to save ,or the mode will back to before you change
Feb 27, 2009 | Motorola Talkabout SX700 2-Way Radio
How do I set my sx700 radio to work with hands-free headsets? Any assistance would be appreciated.
Hands-Free Use With Accessories (VOX)
You can transmit hands-free with the use of optional accessories. Once
VOX is turned on, the radio detects your voice and transmits when you
speak.
1. Turn the radio off and plug the VOX accessory into the accessory
port.
2. Turn the radio on. VOX shows on the display.
3. Adjust the volume appropriately by rotating the volume knob . Lower the volume
before placing the accessory on your head or in your ear.
4. To turn off, simply remove accessory.
Note: There is a short delay between the time you start talking and
when the radio transmits. There is a short delay before the
transmission is completed.
Owners Manual: http://www.motorola.com/mdirect/manuals/SX700_userguide.pdf
You must be using a VOX capable accessory. Generally this is an accessory without an in-line PTT.
Dec 03, 2008 | Motorola Talkabout SX700 2-Way Radio
Operating Manual
To turn off sound activation press the menu button 3 times to enter VOX mode. The VOX icon should be flashing, then press the down button till the number of bars dissappear. Press the menu button to confirm the VOX off mode. You also can adjust the sensitivity of the VOX mode by how many bars are displayed, less bars equal less sensitivity. No bars and voice command is deactivated. Hope this helps. Ed
Dec 11, 2007 | BellSouth 2250BK (22 Channels) 2-Way Radio
Unwired UFRBS10 2-way radio
I tried to find the user manual but no results mostly of the FRS radios, has a menu wich incluides the Vox feature, please tell me if you have a little face icon, this could be the Vox field to turn on or off. Or tell me what icons you have on it in the menu
Mar 01, 2007 | Unwired UFRBS10 (14 Channels) 2-Way Radio
Radio Communications Logo
Top Radio Shack Radio Communications Experts
John
John
Greg Cann
Greg Cann
Jason
Are you a Radio Shack Radio Communication Expert? Answer questions, earn points and help others
