Question about Epson Ex5210 Multimedia Projector
Video image contain vertical blue lines, distracting, how can I eliminate this?
Lap top connected to projector produces a clear video image, I would like the projector to produce the same clear video image,
marsrover
  • 682 Answers
SOURCE: epson 5500 projector
befor you go deeper:- clean lens-miror in optical system check with another vga cable.if it is fixed ok. if not pass it service center.
Posted on Mar 14, 2008
zabolyx
  • 38 Answers
SOURCE: images has a blue color across the center
Wow, 3 in a row. As described on 2 other projector issues this is very similar to those others. I'll repeat the info here.
I assume this is an LCD. I don't remember the s4 being a DLP projector.
This sounds like the LCD panel used for the blue color has gone out. The image is made up of red, green and blue images layered upon the screen. If the blue panel has gone out then there is nothing filtering out the red light in the image.
It looks like yours has just a secone of the panel dying or comming loose from it's connector.
It could be a simple open and reconnect fix. I personally have never opened a projector, so I'm not going to walk you through it as I do not know how hard it would be to tinker with. It should eb a cheap fix for a true repair man though.
Posted on Apr 01, 2009
tigertail
  • 163 Answers
SOURCE: need a user manual EPSON EMP-S1H video projector
Download manuals and more from the Epson support site:
http://esupport.epson-europe.com/ProductHome.aspx?lng=en-GB&data=LU002F6+tHSi27I9oFxwHVsLoITwhVX36eh+
Please take a moment to rate this solution, thanks.
Posted on Apr 11, 2009
  • 63 Answers
SOURCE: Scanning slides produces black images. Slide
Make sure the white document matt from uner the lid has been removed. Also in Epson scan make sure you have changed the document type from reflective to Film and Colour positive.
Posted on Feb 09, 2010
chiefmecha
  • 600 Answers
SOURCE: My Epson TW1000 projector recently
First, try using other cables you are using from the source, for example, if you are using a laptop or PC and you are using VGA cable, try using another one. This also applies to any other cable such as S-video, or the simple Video In RCA cable.
You may also want to check the plugs or the port connector, specially with the VGA or D-Sub on some models, look for obstruction or bent pins. Loose or obstructed or even corroded terminals and ports contribute to such "streaks" or even worse poor image quality.
Another thing to consider, specially if you are using a PC or Laptop, is to check the setting on the OS,(Graphics Properties). Be sure to set it according to, or as stated, or required resolution depth.
Lastly, if the lines you are referring seems to grow, or multiply as the projector heats up.Or, the lines seems to be "rolling" or "moving"- try one of these simple steps;
-- try other cables -- try locating the "SOURCE" away from the projector, put them separated, away from each other -- if you are using HDMI cable try using a new one -- if you have plugged in the projectors power cord "along" with other electronics, in the same SOCKET, or extension, consider re-locating on of them, if possible, let the projector have it on "solo" -- if your projector's Power Plug being a three prong, try plugging it in a three prong socket, or you can buy a 3-to-2 plug adapter
If none of those mentioned steps the following could be a possible fault;
-- LENS or the projector -- the board or its components, IC'S etc
wherein any of them could be costly, firstly, the availability of parts, specially that being a digital equipment,thus, its quite hard to pinpoint the "real" fault, without actually trying to test with instrument or another replacement part.
But as for my experience on our ACER projector, the Plug relocation just did the trick, somewhat an interference caused by the grounding (improper).And making the projector "solo" on an extension or wall socket.
Hope this helps.
Thank you for using Fixya.com
Posted on Nov 13, 2010
My projector has lines on the screen. new bulb didn't help
If this projector is connected by Component Video (3 or 5 wires) instead of HDMI, the most common color related problems are caused by having one of the 3 video cables (Red, Blue or Green) with a bad connector. If everyone is a green smurf the problem is with the red cable. If everyone is a red smurf the problem is the blue cable. If the green was bad you wouldn't see anything.
Another possibility is if the green is plugged into the yellow jack instead of green jack on the projector, you could see what you are describing.
If everything checks out, take the projector to a repair facility.
If you are connected by an HDMI cable, (combined with the fact you mentioned vertical lines not horizontal) then take the projector to a repair facility.
All of this assumes that you don't just have a bad Cable Box or Blu-ray player or Home Theater Receiver. (The source)
Oct 01, 2014 | Dell 1210S Projector
Dell 2300 MP Verticle lines distorted image
light engine or bulb is gettingbad ok how many hours on bulb fans clean ect thx nick
Feb 11, 2008 | Dell 2300MP Multimedia Projector
My satellite lap top has 3 vertical lines on the
there is already a problem with the video card.. for most laptop, they have built in video cards.. so you need to have your laptop checked by a computer technician.. or it would be best to bring it to the manufacturer, so they can install the right drivers for the video card after being fixed..
Sep 24, 2009 | Toshiba Satellite P105-S6197 Laptop
How to connect laptop to projector?
Data projectors have a video cable and you connect it to the 15pin blue video connector on the laptop. Then you power up the projector and then power up the laptop. The laptop should automatically dirvert the video information to the data projector.
If the image produced from the projector is not clear, then you will need to reduce the screen resolution on your laptop using Control Panel - Display - Settings.
Mar 30, 2009 | Fujitsu LifeBook A6110 Notebook
In focus x3 projects computer start up screen, then just searches
the resolution may have changed. reselect the computer or auto-image.
Jan 20, 2009 | InFocus LP640 Projector Multimedia...
How to hook up BenQ PB6100 Digital Projector to a lap top?
Use a standard "video cable" that is used to connect a desktop to a monitor. Your lap-top will also have a similar video out - this is a blue colored outlet jack on your ap-top with three rows of 5-pin holes. The BenQ also has a similar blue receptor jack almost next to the place where you plug in the mains power cable on the rear of the unit.
Dec 20, 2008 | BenQ PB6100 Multimedia Projector
Thin vertical line appears on projector
I have found that vertical lines that suddenly appear from projectors are due to poorly connected cables. Sut off your projector and wait for the fan to go off. Then unplug the connectors from the computer to the projector and secure them again, making sure to go all the way. Hope this helps.
Nov 25, 2008 | Office Equipment & Supplies
Horizontal lines
it is due to electrolytic capacitor failure in vertical output section.
just get it replaced.
it very very common & minor problem.
good luck.
Oct 17, 2007 | Toshiba 27AF43 27" TV
Vertical lines all over image after few minutes turn on
Well i think we have the same problem i with our proscreen 4700 and the only thing i found out so far is that the rca and svideo jack on the projector have gone bad. Tried the data connector and the video was perfect. Tested the rca jack with new cables and another dvd player and it was still mesed up. So it is the hardware that controls the input for the rca and s vidoe jacks but still have not found a way to get the case open to see if some thing can be fixed from the inside.
Oct 13, 2007 | Philips ProScreen 4600 Impact Multimedia...
Epson Ex5210 Multimedia Projector Logo
94 people viewed this question
Top Epson Office Equipment & Supplies Experts
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
