Question about Sanford Corporation Mimio Teach Interactive System
Mimio teach calibrate button will not work
When I try to calibrate the mimio teach it will not recognize the computer. The mimio appears to be on but will not communicate with the mimio hub
The touch screen of my Bernina 580 stopped working today and it was perfectly OK yesterday. Is there a way to fix it on my own or should I look for help?
Calibrate the diplay
The Display calibration can be opened as follows:
- turn off the sewing-/embroidery computer
- touch the two needle positioning buttons on the front panel and keep them pressed
- turn on the sewing-/embroidery computer and release the buttons as soon as the Display appears
- touch the calibration icon
- touch the center of the cross using the touch pen
-- the cross moves to the next position
- repeat this until all three positions shown are calibrated
-- the Display is closed
-- the adjustment is saved
Apr 13, 2014 | Bernina Artista 180
Question mark appears on screen when I put a game inside of it.
  • Try calibrating the screen
  1. Turn the Leap Pad off.
  2. Now hold the question mark button for two seconds and then power the until on while still holding the question mark button down.
  3. The unit will power on and when you see the "calibration Screen" you can release the question mark button.
  4. Touch the crosshairs with the stylus and a large crosshair icon will appear in the middle of the screen.
  5. Touch this icon with the stylus and this will bring up the screen calibration procedure.
  6. Touch all 5 crosshairs as the appear.
  7. Press the "B" button to exit after completing the calibration.
Regards, Tony
May 11, 2011 | Leapster Learning System
I recalibrated the leapster2. It recognizes the stylus on the calibration screen. When I reboot it still doesn't recognize the stylus at all. Please help.
If your Leapster does not respond to the stylus pen, it needs to be calibrated.
The following are instructions below on how to recalibrate the leapster.
1. Insert a cartridge, turn the unit on and wait for the sign-in screen to appear.
2. Hold down the Home, Hint and B buttons simultaneously.
3. When the screen changes, press the A button.
4. Using the Stylus, touch the center of the targets.
Thanks for using Fixya.
Feb 06, 2011 | LeapFrog Leapster Electronic Book:...
Leapster will not recognize the pen ...first it was stuck at the Canada/USA screen...now at the name screen? When I try and get to the Calibration screen I press ? and the on button but when it gets to the...
Answer If your Leapster2 does not respond to the stylus pen, it needs to be calibrated. Calibrating the Leapster2 is easy:
1) Ensure that a cartridge is not inserted 2) Hold down the Hint (?) button while turning the unit on. Continue to hold the Hint button down until the LEAPSTER menu appears. 3) When the LEAPSTER menu screen appears, press the A button 4) Touch each of the crosshairs that appear with the stylus 5) Restart unit
Oct 02, 2009 | Leapster Learning System
My Computer and iTunes does not recognize my iPod Touch
Try resetting it while it is connected. Press and hold the Sleep/Wake button and the Home button at the same time for at least ten seconds, until the Apple logo appears.
If you have not already tried, I would also try the other ports on the computer.
Are you running iTunes 8?
And what kind of computer do you have?
Jun 01, 2009 | Apple iPod touch
HP 6180 Printing Problems
Are you getting the paper mismatch error message?
If yes, see below...
I will ignore the normal solutions to a "paper mismatch" error such as your settings not matching your printing media. Obviously, check these first:
http://h10025.www1.hp.com
If your problem is not solved with the above steps, you have an issue with your "spot sensor" and it needs to be calibrated. Instructions:
1. Press * and # at the same time, and then release both keys.
The display reads "Enter Special Key Combo".
2. Press 3, 2, and then 9, releasing each key before pressing the next.
The display window should read "Service: R0622M" with a revision number.
3. Press the right arrow button once.
The display should read "System Configuration".
4. Press Enter or OK.
5. You will be prompted to enter serial number. Do not enter any information
on the unit.
Press the right arrow button until "media sense calibration" appears in the
display.
6. Load Paper into the unit and then press Enter or OK.
7. Media Sense Calibration process will take place.
Dec 31, 2008 | HP Photosmart C6180 All-In-One InkJet...
Mimio pens stick
I have had this problem with new pens that I bought separately, but not with the original ones that came with the Mimio. There are sites like this one:
http://www.independentproducts.co.uk/ip_mimio_xi_pens_4_pack_pens.htm
that sell (expensive) pens with the name 'Mimio' on that are specifically stated to be Mimio-compatible so they are probably OK. My original pens say 'Expo' on them and have bullet-shaped tips, and they work fine. The first lot of replacements that I bought also say 'Expo' and have square tips and slightly fatter bodies, and they stick.
Nov 26, 2008 | Virtual Ink Mimio Collaborate Meeting...
Leapster not recognizing the pen??
Press the ? button and hold it while turning unit on.
Press the "a" button to select touch calibration
Press each + with the stylus
Restart machine
Nov 25, 2008 | LeapFrog Leapster Electronic Book:...
Zebra 140Xill problem
Whenever you open the printhead, the Pause led will light.
If you hit the Pause button, the printer should go back on-line and resume printing (if you didn't turn it off).
If that doesn't work, try the calibration button (labels will feed out), then the Pause button, then the Feed button.
If you don't want to toss too many labels when you calibrate, the "maximum label length" (or some name like that) can be adjusted through the front panel.
Label_Guy
Sep 14, 2008 | Zebra Printer 140-751-00000
Sanford Corporation Mimio Teach Interactive System Logo
Top Sanford Corporation Computers & Internet Experts
David Payne
David Payne
Are you a Sanford Corporation Computer and Internet Expert? Answer questions, earn points and help others
