Question about Bosch Classixx WFL 2066 Front Load Washer
My Bocsh WFL washing machine wont start any programmes
I had some washing in the machine this morning but it stopped with water in the drum, I could drain the water away, but not spin.
i have tried to use the other programmes but all i get is a click then nothing happens please help! lynn
  • 3,741 Answers
It doesn't spin If your washer won't spin, check these:
It doesn't pump or spin
It pumps, but doesn't spin
It spins only with the lid closed
It doesn't pump or spin If it doesn't pump water out or spin, check to see if the motor is running, then proceed as follows:
  • If the motor is running, your washer probably has a frozen pump pulley or a broken pump belt. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. If the pump belt is broken or looks quite worn, replace it--but be sure to check the pump pulley before you change the belt.
  • If the motor isn't running, the lid switch may be defective. If so, the washing machine can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
It pumps, but doesn't spin If your washer pumps out the water but doesn't spin, check these:
  • The lid switch may be defective. If it is, the washing machine doesn't spin. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
  • The motor coupler may be broken. Many Whirlpool®-manufactured washers use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. You may need to replace it.
  • A belt may be broken. Many washing machines have one or two belts. If a belt is broken or badly worn, you need to replace it with a genuine belt from the manufacturer. (Some washing machine belts are designed with special characteristics not found in automotive belts.)
  • The clutch may be worn. If your washer is a GE, it may use a clutch to come up to the proper spin speed. As the clutch wears out, it may prevent the unit from spinning well or at all. If the clutch is worn, you need to replace it. For this job, you probably want to hire a qualified appliance repair technician.
  • The drive motor may be defective. Many washer brands use a reversing motor. For agitation the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to burn out in one direction and continue to operate in the other. If this happens, you need to replace the entire motor.
  • The transmission may not be shifting properly. Older washers produced by Whirlpool® have a transmission with an electro-mechanical shifter. If the shifter becomes even partially defective, the unit may drain the water but not spin. This is a complex system, if your washer has a shifter problem, you may want to hire a qualified appliance repair technician to repair it.
  • The spin bearing or basket drive may be worn or seized. These components allow the inner tub to spin freely inside the outer tub. When this is the problem, you usually hear a loud sound during the spin cycle. Call a qualified appliance repair technician.
It spins only with the lid closed For safety, washing machines are made so that they spin only with the lid closed. The lid switch prevents the spinning action when the lid is up.
Posted on Oct 01, 2009
My washing machine has stopped with 1 minute left on theprogrammeand the key symbol showing. It will not complete and I cannot clear it. Can you advise what I cando. I have already tried switching it off...
hello. see if it will empty there a few reasons why this could have happend. if the pump and drain hose are blocked it wont go on to the next cycle. the belt could have snaped try and select another programme see if it moves if don't the programme has a fault also make sure you've got water comming in if it wont rinse properly it wont go to the next cycle hope it helps get back to me if don't work
regards
shaun
Jan 02, 2011 | Bosch Classixx WFL 2066 Front Load Washer
How do I remove the brushes from a bocsh washing Machine Clasixx 1400
You need to remove the motor from the washer, undo the 2 screws securing motor, unplug the motor lead, remove the earth wire, the brushes are located at the opposite end to the motor pulley.
Dec 02, 2010 | Bosch Classixx WFL 2462 Front Load Washer
My washing machine starts to fill with water then goes through the programme but the drum does not move with empty water but not spin either
Hello sue, welcome to Fixya.
Are you able to remove the back panel and check the belt ?
How much are you able to perform on your own I should say, check motor, wiring etc ?
Let me know, I'll watch for your reply and have a better understanding of how we can help you.
macmarkus :)
Jun 29, 2010 | Bosch Classixx WFL 2066 Front Load Washer
The water does not cutoff during rinse cycles on the rinse plus and normal wash programmes on my Bosch Maxx WFL 2060 but works fine on quick wash programme
pressure chamber blocked with soap depists scale etc will need removing for service and cleaning partial strip down required.
Feb 14, 2010 | Bosch Axxis WFL 2060 Front Load Washer
Element Needs changing Bosch WFO2466
you should never have to remove drum to replace element. not familiar with this machine take back off and have a look or it will be at the front of machine
Jun 23, 2009 | Bosch Classixx WFL 2066 Front Load Washer
Bosh washing machine won't do any programmes
If it fills then the next phase is to agitate.
To do that the motor must drive
Can you hear a whirring sound from the machine if you get close to it if so then the belt driving driving drum may have snapped.
If not then the motor brushes may have stuck or have worn out.
Does the machine programmer advance by itself or are you turning the dial
May 23, 2009 | Bosch Classixx WFL 2066 Front Load Washer
Bosch Maxx WFL 2061 motor starts running and then stops
Hi ! I have problem with my Bosch Washer wfl 2061 .. It was running till stoped to
realease drain water out... But no drain water come out.. I have checked drain water host... Nothing thaere.. Water was still in the drum Tank... Whoever knows this problem , please kindly suggest or help me to do something.. Thanks.. Peace pkurdnirund@hotmail.com , peacepattaya@gmail.com
Nov 28, 2008 | Bosch Axxis WFL 2060 Front Load Washer
Bosch Classixx WFL 2066 Front Load Washer Logo
277 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Marvin
Marvin
Craig Butler
Craig Butler
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
