Okidata error 615
Incompatible Toners
Oki c5550 INCOMPATIBLE YELLOW
Are you using factory or aftermarket toner?
Jan 07, 2014 | Oki Electric Industry Okidata C5550n MFP...
Incompatible toner cartridge ?
Sometimes printers are sensitive to only the origional make and brand of toners and will not accept third party toners.
Jun 17, 2010 | OKI C5650n LED Laser Printer
How do i clear an error alarm on my okidata 320? it wont do anything.
Power on then off, then unplug the unit for a few minutes. Then try it.
If this does not work post back.
Feb 05, 2010 | Matrix Okidata Microline 320 Printer
Fatal error : 144 on a Okidata
this is indicated when the toner feed switch error
or the toner locklever-open error occurs repeatedly when new toner is used.
it has to do with the yellow.
3 possible solutions.
Confirm that the lever is in position.
Replace the toner feed unit.
Replace the ID units.
Aug 28, 2009 | OKI C9600hdn Laser Printer
B4600, "Install Toner, Toner Missing" Error
I had a customer with that problem and the issue was the toner cartridge. If you take it out of the photoconductor unit and look on the end there should be a metal connector tab. If you look on the left side of the photo unit you will see metallic contact points that need to connect to the metal tab. Oki has several toners that will physically fit in the B4600 but they have to be the ones with the metal tab to work right or you get the error. The correct toner part numbers are: 43502301 or 43502001
Check your toner for the tab is that is not the problem, get back with me and we can go from there.
Buddy
Corporate Computer
www.ccl-la.com
Aug 07, 2009 | OKI B4600n Printer
Getting Fatal error 020 on my Okidata 7300 printer. How do I fix.
You could take the controller board and reseat the dimms. But the Rom Dimm is usually bad and needs to be replaced.
Apr 15, 2009 | Office Equipment & Supplies
Okidata C3200N
It would help if you said where the paper jam was. However the fact that it was ok until you cleared the jam indicates you have knocked something out of place. Its just possible one of the high voltage contact springs that touch the drums has stuck in and no longer makes contacts with one of the drums. Make sure all the semi circular springs move in and out freely. Also check the led heads in the top cover. Make sure all the cables are seated in the heads ok. Make sure all the heads are in the same position and one has not turned around. Retrace your steps as your drums seem to be problem.
Jun 25, 2017 | OKI C3200n Led Printer
Install toners in c5100n model
Here's the link for the manual; http://my.okidata.com/PP-C5100n.nsf?opendatabase if you need help with any of the procedures in there, please ask again. Hope this helps :)
Sep 03, 2007 | OKI C5100n Laser Printer
98 people viewed this question
k24674
