Question about Golds Gym StrideTrainer 380 Elliptical
Electronics won't come on with new batteries - Golds Gym StrideTrainer 380 Elliptical
My 2001 Acura CL Type S won't start. It has been
You said that you replaced the battery so in either case of new or another battery have a load test done as what you describe indicates a failing cell in the battery or loose t/dirty terminals.
Sep 22, 2013 | Cars & Trucks
2005 Kia Rio - sometimes won't start, but has a new battery
I once had a chvy lumina car that had a similar problem. I ended up replacing the alternator that was not charging up the battery. The battery was replaced first and then the alternator. In addition, the electronic motherboard was replaced underneath the coil pack. I did all the work myself. No more electronic problems. If they did a diagnostic test on your car and it showed a bad battery then the battery should be tested by Autozone. Go to Oreilly's too for test.
Jan 20, 2018 | 2005 Kia Rio
Have new battery will not hold charge and car wont run with car running disconnect
Never disconnect the battery when car is running. I know that used to be the old way to check if alternator was working, but that was before electronics became the norm on vehicles. On today's vehicles, or any with a computer in it, disconnecting the battery with key on, or engine running, there is too great a chance you could fry the delicate electronic circuits that the computer requires. Always turn key off before disconnecting the battery.
Okay, enough soap-boxing. You need a new alternator, if the car won't run with battery disconnected. Next time, use a volt meter.
Jun 14, 2012 | Ford Thunderbird Cars & Trucks
Won't work or re-set
i remember holding a paperclip in the reset button for about 30secs it should introduce its self then
Jan 04, 2012 | Tiger Electronics FURBY Interactive...
When I install new batteries it won't stop 'squealing'...what could be the problem? Ugh - I can't even use it like that!! thanks!
It was a Garrison - I've since learned that the problem was it was screwed a little too tight and was pushing against the circuit board. I took the back off (where the batteries are) and loosened the screws a little and the squealing stopped!
(Posted to clear the "unanswered questions" and share with the community)
Nov 25, 2011 | Deadbolt ELECTRONIC DEADBOLT KEYLESS ENTRY...
Have New battery and Alternator, battery still won't stay charged.
Since you are having a new battery and alternator the charging circuit of the electronic charging unit is a possible suspect.
All what is required is to check the charging voltage when the engine is started, if there is no increment of voltage when the engine runs the alternator then the connection from the alternator must be checked. Check the output from alternator, check the relay box which contains the charging unit. It can be a failure of the rectification or the stabilising circuit, the unit must be replaced.
Sep 21, 2011 | 1993 Buick Park Avenue
Golds Gym StrideTrainer 380 Elliptical Logo
56 people viewed this question
Top Golds Gym Exercise & Fitness Experts
 Atlanta Fitness
Atlanta Fitness
Level 1 Expert
Propulsive
Level 1 Expert
Are you a Golds Gym Exercise and Fitnes Expert? Answer questions, earn points and help others
