Question about Jade RJDO3003A Stainless Steel Double Oven
Oven shuts off with Error Code 4d21
Tried starting either top or bottom oven and intermittently, but more frequently now, the error code 4d21 appears and the oven shuts off. Occasionally, the oven has just shut down without an error code.
    New Friend:
I had the same problem for a Jenn wall oven I purchased in 2007. I finally purchased a tangential fan and replaced it. Had to turn off electricity at the circuit breaker, pull the oven out of wall, disconnect the hard-wire connection in the lower cabinet, unscrew the top metal cover (lots of screws) and disconnect the old grimy tangential fan (~3 pull out plug-type wires) and then put it back together. It's been about a week now and so far it's working like it should!
Posted on Oct 09, 2014
  • 356 Answers
This problem points to the controller card not functioning properly. It will need to be replaced. Here is a link so you can get the owner's manual:
http://www.manualslib.com/products/Jade-Range-Rjdo3003a-2904090.html
Check it out, it may help you figure it out.
Posted on Mar 19, 2014
Testimonial: "Thanks for your input Robert, but I already have the manual and there is no in depth information. It just suggests calling the office, but Jade stopped producing these ovens before I bought it. Their toll free number directs me to Whirlpool who know nothing about the product."
Why my whirlpool GBD307 double oven top oven will not cut on, but the bottom one will. but after heating up, the oven starts blinking the start? button but it will not cut off, it shows a error code F
that's a bad touch panel or key panel,the number you sent isn't the full model number off of the oven so when you call to order the part you will need that.if you try to fix this yourself make sure the power is off.good luck
Nov 07, 2017 | Whirlpool GBD307PDS Electric Double Oven
Error Code 4D21
Somewhere the control is not reading fan rotation could be encoders harness or control had this error once reset oven till I could return with control error never returned replaced control anyway
Feb 08, 2014 | Jenn-Air Electric Double Oven
My oven is flashing a F10 code and the door is locked. This happened while the oven was in self cleaning mode
more than likely the tco thermal cutout fuse has opened during cleaning and now the ovens latch motor cant get power to open,its under the top cover where the surface elements are located its a frequent thing with all ovens/stoves
Jan 12, 2013 | Kenmore 40494 / 40495 / 40499 Electric...
Oven shuts off after being on for short period of time and f3 or f2 code appears. also the display sometimes goes off and on model # che9830bcb ser # 24430972qw
F3 error code usually means a faulty oven temperature sensor, a fairly easy part to replace.
However, with an intermittent display problem as well this could mean a bad connection or relay in the oven control unit, which a bit more complicated.
Jan 19, 2010 | Maytag Ovens
F2 and F3 error codes in GE electric wall oven
Call GE answer center 1-800-626-2000 ask for tech help, Have you Model # off you data plate ready.
May 09, 2009 | GE JRP15 Electric Single Oven
GE oven only heats up to 300 then shuts off
just a thought but maby the
tempature sensure has gone bad
Jan 21, 2009 | GE Profile JTP18 Electric Single Oven
F2 and F3 code appearing along with annoying beeping
i think f3 error code has something to do with the temp probe maybe it is the problem. the temp probe is located if you open the door directly in the back wall. it looks like a prong. should read 1100ohms the f2 error code though usually has something to do with the keypad i would check all the connections maybe they are loose.
Jan 04, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Electric oven model 790.47892601
F7-E1 - Common Switch Wire Is Defective - This error occurs when common wire to latch switch and door switch is shorted.
Check all connections at control board and at the latch switch and door switch.
If connections are ok, then check individual switches as outlined for the F5 error code.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Oct 28, 2007 | Kenmore 47834 / 47832 / 47839 Electric...
PROBLEMS WITH FR ERROR MESSAGE APPEARING
Mewood What part did you call "thermostat"? If you?re talking about the device which operates the oven temperature, your oven does not have such thermostats. It has two oven temperature sensors (one in each oven) and a control board (ERC). An error code "F4" will be displayed along with a beeping sound if the ERC determines an open oven temperature sensor circuit. It can be the sensor itself or the wires that connect the sensor to the ERC. The F4 message will not be displayed in the time of day mode. To get access to an oven sensor and wires, the oven has to be removed from the cabinet. Then you have to remove the rear cover. Then unplug the oven sensor and check the resistance across the oven sensor. It?s supposed to be about 1100 ohms at room temperature. If the resistance is incorrect, the sensor is bad and needs to be replaced. If not, check all the wires from the oven sensor to the ERC. If it is not the sensor and wires, you have to replace the ERC, but most likely the problem is with the wires and/or connections. Part number for ERC is 62965, part number for oven sensor is 62593. Gendos....post back.
Dec 14, 2006 | Dacor ECS230 Epicure Stainless Steel...
Jade RJDO3003A Stainless Steel Double Oven Logo
410 people viewed this question
Top Jade Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you a Jade Oven Expert? Answer questions, earn points and help others
