Question about Citizen Skyhawk Eco-Drive JR306059F Wrist Watch
I have citizen balck eagle c-652, do i need to replace the battery
Hello I've had my citizen Eco drive skyhawk watch for at least ten years now. I remember reading in my manual years ago that a battery needed to be replaced even though it's solar powered. My watch went...
There could be other issues beside the battery. My best solution would be to take back to where you bought the watch, or any other authorized Citizen watch retailer for repair.
This is Citizens web site:
http://www.citizenwatches.com.au/
Best regards,
Mar 16, 2011 | Citizen Skyhawk Eco-Drive JR306059F Wrist...
Have fitted a new battery but no joy, any tips I can try?
mcdevito75 here, Some quartz watches and I believe Citizen is on of which need the exact factory number battery installed / replaced. if you did use the exact battery number and the new battery is not working, remove the battery and carefully clean the battery contacts with a Q-tip and rubbibg alchohol do not soak the battery contacts just clean them. Also your new battery could be dead, who knows how long it was on the store shelf. Alaso wipe off any oil from your fingers on the new battery before you install it in the watch, make sure the battery is seated correctly in the watch, the back cover may also have to be installed back onto the watch to complete the battery circut for the watch to work. If all this fails you can try to contact Citizen online, Contact CitizenWatch.com and get their recommended battery size for your watch, OR, look for a small watch repair shop in your area. One Last thing, Your Citizen watches Quartz mechanism could also have gone bad, in this case you"ll need a new watch.
Feb 11, 2011 | Citizen Watches
Change battery on citizens WR 50 watch
Take your Citizens watch to a jeweler who will open it and replace the battery.
Dec 02, 2010 | Citizen Watches
Had battery replaced
Click on my profile (escapement), then click on Tips and Tricks. There you will find link to all CITIZEN watch manuals. Rate me, please .
Apr 08, 2010 | Citizen Eco-Drive Calibre 8700 Wrist Watch
Citizen solar watch will not keep time if removed from light
If your watch is light powered, it does not have battery. However, there is a capacitor which needs replacement. New capacitor usually revokes light powered watches and makes them work as new. Rate me,plz.
Feb 02, 2010 | Citizen Eco-Drive BL006056H Wrist Watch
Hi i have a citizen 100m chronograph watch and i have broken the stem trying to replace the battey how do i repair it or do i have to take it to be repaired.thanks karen
You have to take it to your nearest Citizen dealer, as you won't be able to replace stem yourself. Note: You do not need to remove or to do anything with the stem for replacing battery.
Jan 24, 2010 | Citizen Eco-Drive BL006056H Wrist Watch
Citizen eco drive watch doesn't work
My Citizen Red Arrow wristwatch which I purchased last Christmas has a blank display and won't reset . Any ideas would be appreciated
Nov 07, 2009 | Citizen Eco-Drive Modern Watch
Hello. I let a Citizen Black Eagle Skyhawk run completely. Even after charging it for 24 hours, the watch will not run. What is my course of action? Send it in?
After charging the Skyhawk/Black Eagle watch, you need to reset it.
Here's how to do it:
Turn the crown (knob) until it's in chronograph mode (CHR), then pull it out to TWO clicks. Push both buttons at the same time and the display should turn on. The push the crown back in to complete the reset.
If that does not work and you are 100% positive it should've charged...take it in for service. It could be a bad battery (rare).
Aug 16, 2009 | Citizen Skyhawk Eco-Drive JR306059F Wrist...
Set New city time-Citizen Blak eagle -c652
Follow this link and see the setting for yourself:
http://www.citizenwatch.com/COA/English/settings_int.asp?caliber=C650&interactive=C650
Rate me, please.
Mar 14, 2009 | Citizen Skyhawk Eco-Drive JR306059F Wrist...
Citizen Skyhawk Eco-Drive JR306059F Wrist Watch Logo
Top Citizen Watches Experts
Jimmy Accardi
Ansel Alberto
Ansel Alberto
Are you a Citizen Watch Expert? Answer questions, earn points and help others
