Question about Dell Computers & Internet
Thermo=tech TT1022 will not turn on - Dell Computers & Internet
Tip
Gas Hot Water Tank Not Producing Hot Water Pilot will not stay lit Trying to...
Trying to light your pilot light and it keeps going out when you turn on you gas valve. This is a common problem when your thermo-couple goes out. The thermo-couple sends a small electrical charge to the gas valve to keep its self lit. When the unit calls for heat the pilot flame gets bigger producing more electric and tells the gas valve to open the main gas valve to the burner tubes. The thermo-couple is an easy item to change most of the time. You will need to follow these steps to change out your thermo-couple:
1. Turn off the gas (there is an inline shut off on the supply line before it reaches the gas valve, you need to turn this crossways to the pipe)
2. Locate the thermo-couple it will look like this and be attached to the gas valve
3. Unscrew the thermo-couple from the gas valve
4. Remove the other end of the thermo-couple from the pilot holder
5. Measure or take the old thermo-couple to the hardware or appliance store with you to get the proper length (there are many different lengths of thermo-couples)
6. Reinstall the bulb end at the pilot
7. Reinstall the threaded end on the Gas Valve (make sure not to cross thread the thermo-couple it should start by hand)
8. Turn the gas valve to the pilot position and hold down the red button wait a few seconds then turn off and do again (you will need to do this around 5 times in order to get the gas back up to the pilot light then try and light the pilot)
9. Try to ignite the pilot light.
10. Once you get the pilot light lit you will want to hold down the button for 60 seconds then turn the gas valve to the on position.
Here is an image of a thermo-couple (they will all look similar to this):
Thank you for choosing FixYa.com. If you have any further questions please post them and we will gladly answer them
Justin
on May 03, 2011 | Plumbing
Fan comes on,but no flame.just had the thermo thing replaced,but flame not coming on
No gas= no flame. Thermo is still an issue. Call the tech back under warranty. Should have been tested.
Jan 03, 2015 | Heating & Cooling
Freezer coils are iced up so the unit does not cool
Garth, The defrost Thermo should be closed when installed otherwise when the timer goes into defrost mode (I am not familiar w/ your model, could be 8,12 hr) the heater coil will not heat up.When closed it will allow the heater to defrost the freezer allowing the air to circulate & cool the fridg section also. The thermostat kicks in to turn off the heater, when it feels there is no more ice to defrost. the actual temp of the thermo can vary.
In the field we trained techs to replace the thermo and timer as a rule if all other components checked & visually looked good. If the heater was discolored or bulged we would advise replacement of it also.Remember the timer is the power source, the heater the engine & the thermo the safety. good luck, sl
Aug 24, 2012 | Refrigerators
I pulled the fuse next to the thermistor on my HE3 but I cant tell if it is blown. Nothing is melted
you cant tell by looking at them.you will need an ohms meter to check them for continuity. Place the red lead to one of the spades and the black lead to the other spade. If you get any movement at all on the dial or gauge, the fuse is good.
Aug 11, 2010 | Kenmore Elite HE3 Steam 8674 Dryer
When power is on, H and 4 blink by turns.
your fuser tempature is too low. your lamp may not be coming on. your thermo fuse is bad. your tjermistor is bad. you need a tech to rebuild your fuser
Jan 02, 2010 | Sharp AL-1642CS Copier
KitchenAid W.Q. dishwasher turned itself off cannot restart
Looks like power is been lost, 1st ck power at junction under the unit, if ok ck the thermo fuse on the control panel, if it's out, replace it with the fuse kit recomended by Whirlpool on their Service Flash on this unit.
This should be done by a trained Tech.
Sep 17, 2009 | KitchenAid 24 in. KUDP02CR Built-in...
No hot water, pilot light lights but no burner ignition
Thermo coupler may be defective. it controls the main gas valve by closing main if pilot is out. make sure thermo coupler bulb is positioned over and near tip of pilot flame, but not in the flame. Thermo couplers are inexpensive and easy to change out.
May 05, 2009 | Bosch & Tankless LP Hot Water Heater
Error code H4-00 and machine is "locked-up" in scan mode
H4 is a fuser error. It needs to be replaced by a tech. Sometimes they can reset this error in service program.
Apr 24, 2009 | Toshiba E-Studio 3511 Color Copier
Kenmore side-by-side with thermo switch problem?
Acting like a bad thermostat, One thing to check is make sure compressor isnt overheating. If really hot you could have a relay problem on compressor.
Jan 05, 2008 | Refrigerators
Computers & Internet Logo
29 people viewed this question
Alun Cox
