Question about Kwikset Locks & Locksmithing
Latch doesn't retract when knob is turned. - Kwikset Locks & Locksmithing
    Problem Solver:
  • 26 Answers
Kwikset locks are cheap and not designed to be repaired. If it was working and now doesn't, it's time to replace it.
If it is new, then take it back to the store and ask them to look at it. If it's working the right way, they'll be able to show you what you did wrong (or if it's a feature, then allow you to get one without that feature if you don't like it.) If it's not working right, they can replace it.
If you absolutely must have the replacement lock work with your old keys, then any locksmith and many other places that sell locks can set up a new lock of the same brand to other keys.
Posted on Dec 04, 2014
Exterior door stuck closed manually retract ****** remove knobs KWIKSET
You will probably need to replace the latch assembly. There is a small rivet that holds part of the latch together, and it also acts as a pivot point for a small piece that retracts the latch. If it gets bent, the latch won't retract fully, but you might be able to push it back and get the door open.
May 24, 2014 | Kwikset 740ll 3 Smt Lido Keyed Entry Lever...
I have a Simplex Kaba Ilco Unican 1000 keyless lock and I want to change its password. But I don't know how to do it. Is there anybody to help me? It's urgent please...
I found this instruction elsewhere on this site ( thanks to pctuneup191):
PROCEDURES TO CHANGE THE COMBINATION OF SIMPLEX 1000 SERIES CIPHER LOCKS
1.) ENSURE THE DOOR IS OPEN.
2.) INSERT THE DF-59 CONTROL KEY INTO THE COMBINATION CHANGE PLUG ASSEMBLY (ON THE BACK OF THE DOOR) AND UNSCREW THE CYLINDER BY TURNING THE KEY COUNTERCLOCKWISE.
3.) TAKE THE CHANGE PLUG ASSEMBLY COMPLETELY OUT OF THE DOOR.
4.) TURN THE OUTSIDE DOOR KNOB CLOCKWISE ALL THE WAY UNTIL IT STOPS, THEN RELEASE THE KNOB.
5.) PRESS IN THE EXISTING COMBINATION FIRMLY.
6.) INSERT THE SPANNER WRENCH IN THE COMBINATION CHANGE SLEEVE. IT SHOULD INSERT AT THE NINE O'CLOCK POSITION.
7.) TURN THE SPANNER WRENCH GENTLY CLOCKWISE UNTIL IT STOPS AT THE 12 O'CLOCK POSITION. NOTE THE NOTCHES IN THE COMBINATION CHANGE SLEEVE MOVES AS THE SLEEVE IS MOVED.
8.) TURN THE SPANNER WRENCH COUNTERCLOCKWISE BACK TO THE NINE O'CLOCK POSITION UNTIL IT STOPS. REMOVE THE SPANNER WRENCH.
9.) TURN THE OUTSIDE DOOR KNOB CLOCKWISE (ALL THE WAY, UNTIL IT STOPS), THEN RELEASE.
10.) INSERT THE NEW COMBINATION BY PRESSING IN THE BUTTONS. USE AT LEAST three numbers and a maximum of five.
11.) TURN THE DOOR KNOB CLOCKWISE ONCE, ALL THE WAY, UNTIL IT STOPS. HOLD IN THIS POSITION AND CHECK IF THE LATCH IS RETRACTED.
12.) RELEASE THE DOOR KNOB.
13.) TURN THE DOOR KNOB CLOCKWISE ONE MORE TIME TO THE STOP POSITION. AT THIS POINT, THE LATCH SHOULD NOT RETRACT UNLESS YOU USE THE NEW COMBINATION.
14.) REINSERT THE CYLINDER INTO THE BACK OF THE DOOR BY SCREWING IT IN CLOCKWISE WITH THE DF-59 CONTROL KEY (DO NOT OVERTIGHTEN!)
REMOVE THE KEY.
A Df-59 key can be purchased at this site:
http://absupply.net/kaba-access-control-lock-1000-series-key-df59.aspx
Good Luck!
Mar 04, 2011 | Simplex Kaba Ilco Unican 1000 keyless...
How to change entry code
First, remove the control cylinder with your "DF59" control key. The cylinder unscrews to remove. Next, turn the knob all the way to the right, and release it.
Step three: Enter the existing code
Step four: Using either the spanner wrench that came with the lock, or a medium-sized flat-tip screwdriver, reach into the hole the control cylinder came out of; and turn the cam inside, about 1/4 turn (as far as it will go), and then back.
Step five: Turn the knob as far as it goes, ONLY ONCE, then release it.
Step six: Enter your new code.
Step seven: Turn the knob (this time, it should retract the latch).
Test it by turning the knob again: The latch should not retract. Now enter your new code and it should retract the latch as you turn the knob. If so, you have successfully changed the code.
Dec 23, 2010 | Simplex Kaba Ilco Unican 1000 keyless...
Reset combination to keyless door lock
REMOVE THE KEY.
The spanner wrench (SMPBC201278 Simplex:SpannerWrench $9.00) referred to can be purchased from this site:
http://www.ckilock.com/Mpage18.asp
Dec 09, 2010 | Simplex Kaba Ilco Unican 1000 keyless...
How do I change the combination on my Unican 1000 keyless lock? thx john
The door must be open.
On models with the passage feature, make sure the passage feature is disengaged: turn knob or key should be in vertical position (A) (see figure 1).
1. Insert the DF-59 control key (B) into the combination change plug
assembly (
C) and unscrew the cylinder by turning the key
c
ounterclockwise. Remove the combination change plug to gain access to the combination change sleeve (see figure 1).
2. Turn the outside knob/lever once clockwise (all the way, until it stops) then release. The latch should not retract (see figure 4).
3. Enter the existing combination. On new installations, use the factory- set combination: depress 2 and 4 simultaneously, (release), then 3
(r
elease). You should feel a slight click as each button is depressed.
4. Insert the spanner wrench as shown in figure 2 to engage the combina- tion change sleeve (A). Gently turn the spanner wrench clockwise to the stop position (a slight click should be felt), then turn the spanner wrench counter-clockwise to the stop position (A) (see figure 3). Remove the spanner wrench.
5. Turn the outside knob/lever once clockwise all the way until it stops, then release. The latch should not retract (see figure 4).
6. Choose your new combination, write it down, then enter the new combination-depress buttons carefully (a slight click should be felt as each button is depressed).
Note: You can use one button or all five for a combination, but each button can only be used once. You can depress two or more buttons simultaneously as a step in the combination.
7. Turn the outside knob/lever clockwise once, all the way, until it stops, hold in position and make sure the latch is retracted (see figure 5).
R
elease the knob/lever.
Note: If your lock is opening on every turn of the knob or lever, except upon entering a code, this may be a ZERO CODE. Before attempting to remove the lock from the door, refer to the troubleshooting procedures outlined at bottom of this document for a zero code symptom/solution.
1000/L1000 Series FAQ
Changing the Code/Combination
hope this helps
and here is the link to the change code web site
http://www.locksonline.co.uk/files/pdf/Simplex_1000_CodeChange.pdf
good luck
please take the time to rank my advice
merry christmas
Dec 07, 2010 | Simplex Kaba Ilco Unican 1000 keyless...
Door knob to garage won't open. The "bolt" won't retract.
If all else fails...take pins out of hinges and remove door to get to lock bolt.
Sep 07, 2009 | Amerock 3 Ring Knobs - BP1586
Need instructions on changing combo
6.) INSERT THE SPANNER WRENCH IN THE COMBINATION CHANGE SLEEVE. IT SHOULD INSERT AT THE NINE O’CLOCK POSITION.
7.) TURN THE SPANNER WRENCH GENTLY CLOCKWISE UNTIL IT STOPS AT THE 12 O’CLOCK POSITION. NOTE THE NOTCHES IN THE COMBINATION CHANGE SLEEVE MOVES AS THE SLEEVE IS MOVED.
8.) TURN THE SPANNER WRENCH COUNTERCLOCKWISE BACK TO THE NINE O’CLOCK POSITION UNTIL IT STOPS. REMOVE THE SPANNER WRENCH.
REMOVE THE KEY.
Aug 04, 2009 | Simplex Kaba Ilco Unican 1000 keyless...
Erased the code
FOR YOUR SECURITY THE
COMBINATION MUST BE CHANGED
WHEN THE LOCK IS INSTALLED.
position (A) (see figure 14-1).
combination change plug assembly (C)
key counterclockwise. Remove the combination
14-1).
2. Turn the outside knob once clockwise
14-4).
installations, use the factory-set combination:
(release), then 3 (release). You should
depressed.
Figure 14-2 to engage the combination
then turn the spanner wrench counterclockwise
14-3). Remove the spanner wrench.
5. Turn the outside knob once clockwise all
latch should not retract (see figure 14-4).
on page 26, then enter the new combination
— depress buttons care-fully
Dec 08, 2008 | Simplex Kaba Ilco Unican 1000 keyless...
Can't close back door without turning the knob
Try taking the knob out of the door and spraying the whole latching mechanism with WD40 or some kind of lubricant. There is a few moving parts in there that can get bound up. Hope this helps. Don't forget to leave feed back.
Nov 26, 2008 | Top Knobs Hardware & Accessories
Locks & Locksmithing Logo
99 people viewed this question
Top Kwikset Locks & Locksmithing Experts
Jim Thurston
Mike
J.D. Browning
J.D. Browning
Are you a Kwikset Lock and Locksmithing Expert? Answer questions, earn points and help others
