Question about Husqvarna Chain Saw 20" Bar
Stihl 024 chain oiler is not function, how to troubleshoot or repair
  • 22 Answers
This isn't an easy repair. You'll need to take off the pto clutch and that might not be easy. The oiler is behind the clutch. There is a drive gear behind the clutch that drives the oiler. You should check to make sure oil is getting from the reservoir to the pump. That is easiest to do with the pump off the saw. If you take it to your local Stihl dealer, unless the pump is shot, this is not a complicated or expensive repair.
Posted on Jun 16, 2009
How does one replace the chain oiler in a 0009 Stihl chainsaw?
from stihl documentation it does not seem that you can replace it. I have appended the manual for you and an article dealing with chain oil delivery system for 0009
Stihl Chain Oiler Trouble
How to Unstop the Oiler on Stihl Chainsaw
http://www.stihlusa.com/stihl_ownersmanuals/009_manual.pdf
Jan 26, 2015 | Stihl Garden
Ms290 oiler tube is leaking( looks nicked) just past where it comes out of the oiler tank. What is the procedure to replace it
There is a special puller too that STIHL dealers posess, you cannot get one, sorry, you have to pay to remove it. The good news is, there is a chinese company on eBay that sells the pumps for $6 shipped from china versus the $33 you'd pay from STIHL for the same chinese-made part.
Jun 25, 2012 | Stihl MS 290 Chain Saw include 20" 50cm...
Stihl 024 over oiling
Your oiler is probably defective, or perhaps it just needs the adjusting screw to be turned in a little to restrict some of the flow.
Jan 11, 2012 | Stihl Garden
Cannot find oil regulator on stihl 024
There is no oil "regulator" only an oiler with a screw that adjusts the flow, that is found below the saw, and is fit for a slotted screwdriver.
Jan 11, 2012 | Stihl MS 290 Chain Saw include 20" 50cm...
How do I repair the oiler on my stihl chain saw model 028
You have to remove the little white gear to be able to get to the screws to remove it.
Apr 10, 2011 | Stihl MS 290 Chain Saw include 20" 50cm...
Have an 029 farm boss with 16 inch bar upgraded to 20 inch all was checked and bought from a stihl dealer they even put it on. went home used it for about 15 min and the bar and chain went dry no oil going...
It sounds like you may have something stuck in the oiler port or groove of the bar. You can use the pointy end of the chain file guide to clean the bar out and give it a shot again.
Good luck
Mar 30, 2011 | Stihl Chainsaw 024 026 Oil Pump
My 024 was never correct right out of the box and did not pump the correct amount of oil to the chain which caused quicker loss of sharpness and excessive heat to the bar. The local repair shop replaced...
Stihl offers a higher capacity oiler for the saws, more than likely it was shipped with the lower capacity. Also dealers will install the same oiler as what was in the saw unless you specifically request differently. Let me know if you need any more help, Daniel.
Dec 05, 2010 | Stihl Chainsaw 024 026 Oil Pump
How to adjust chain bar oiler
The Stihl 026 PRO does have an adjustable oiler and it is located on the bottom of the saw just below the clutch drum.
Stihl also builds an 026 "Standard" without the adjustable oiler, however, the hole location for adjustment is still there.
The 026 PRO will also have a decompression valve on top of the saw to make the rope easier to pull during startup. If you have the DECO valve you should also have the adjustable oiler. Hope this helps.
Sep 26, 2009 | Standard Oregon Chainsaw Chain For Stihl...
Chain oiler replacement
If it is Stihl 025 the chain oiler is on the bottom.First check if the worm gear(under the starter)is in good condition.Replace the starter(blocking the piston in the cilinder with a rope with many nods,that rope entering in the sparkplug hole).On the handle there are 4 screws on the right side (under 4 black plastic plugs,at the bottom 2 screws.)CUnlock them and take off the handle.At the bottom you can see the chain oiler( under the hose) the mark for right possition is there.Take off the oiler using a screw(lock clockwise into the oiler)and then pull it out.Clean with compressed air the oil hole.Put back together .Succes!
mihai71
Nov 21, 2008 | Husqvarna Chain Saw 20" Bar
Husqvarna Chain Saw 20" Bar Logo
1,081 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Tim Whalen
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
