Question about Home
Manaagement light was on/dead battery x 3 new ones
2009 Sportster 1200 Custom. 2 year Battery was dead, I charged it got one ride and it went dead again. I changed the Battery Sunday and rode for about an hour, parked for about 3 hours and rode again for...
Check all the fusses and the bulb for the check engine light.
If the fuel pump wasnt running it wouldnt start at all.
I think you have a bad voltage regulator and your engine light would be on if it worked.
Sep 17, 2013 | Harley Davidson XL 1200 C Sportster Custom...
202 monte carlo ss put new battery in now it's dead then i recharged it now it's dead again after running the car
Check all the light in the car, one must be on. Check the sun visor lights first. Others include under-hood light, trunk lights and interior lights that come on by themselves due to faulty switches. Other reasons are a bad diode in the alternator, disconnect it and see what happens..
Oct 31, 2012 | Cars & Trucks
My blackberry mobile phone cannot swith on ; the screen cannot come on
To answer all 3 of your questions. There's a chance your phone is dead. Could be a fried battery, could be a totally dead phone. If you've tried charging it and that didn't help. It's dead.
If you get a lightning bolt on the screen while charging. The battery is fried and needs a new one. If you plug it in and get nothing, no lights, just a tethered brick. The phone is dead.
Sep 07, 2011 | AT&T BlackBerry Curve 8310 Cell Phone -...
Battery in my 98 chevy suburban keeps going dead despite I've had it tested 3 times and all three say its a good battery
Are any lights or accessories on that could cause a battery drain Are you testing it immediately after charging? This will give you a false reading, let the battery stand for a while then test. You may have one or more dead cells. The battery will show its Ok but in reality its pouched! Head on down to your local Canadian Tire and get a new one.
Dec 27, 2010 | 1998 GMC Suburban
Dead battery new batt alt gr cable no fues blow jo
Common battery drain would be 1. the light under the hood staying on when the hood is closed. 2. The vanity light over the drivers sun shade if there is anything up there that is keeping the vanity shades from closing all the way. 3. pull the fuse to the rear wiper motor, common for the wiper motor to lose it's position and tries to close even when it's already closed. 4 there is a short in your 4wd encoder motor on the transfer case.
Start with the simple and check them all one by one till you have determined where your voltage drain is coming from.
Thank you for using fixya and good luck
Jun 12, 2010 | 1995 GMC Jimmy
How to get my laptop to charge.
If you battery is totally dead you need a replacement unit - remove the battery power the unit up using external power pack then refitt the battery - if it won't charge the battery is dead. get a new battery
May 19, 2010 | HP Compaq Evo n610c Notebook
Flat batary
Do you drive it everyday? Does it have any extra stuff on it like alarm system, anti-theft device? Get one of those floaty ball things that check the specific gravity of your battery acid. One dead cell is a dead battery. They will tell you a lot. And just because a battery is new doesn't mean it is good. I have seen a lot of good batteries dead! Also, check the water in the battery. also, check the alternator, it can't be charging. The light on? Something is killing your battery. If it isn't being drained, it isn't being charged up either. The clock can kill a battery in a few days. Check this stuff out. Hope it helps.
May 08, 2010 | 1994 Nissan Pathfinder
Wont turn on
Well to be3 a 100% about the battery I would replace it with one that you know or is guaranteed to work. Camera batteries can look OK from outside and be completely collapsed inside.
No Charge lights can indicate NO battery and if there is one inside then it is dead and registers as a no battery ( no charge light)
The red light blinks in very low state, but totally discharged it will not blink and wont blink again until loeft on chareger for about 3-4 hrs to overcome the low state.
Jul 25, 2009 | Kodak Easyshare M753 Slim Digital Camera
Wont turn on
you have one of 3 things wrong here.
1:) the battery is dead, and needs to be replaced ( suggest e-bay china seller for cheapest )
2:) the AC adaptor or dc socket on the motherboard is Faulty.
3:) motherboard fault, regarding charging circuit board.
Go for the most cost effective option First. New Battery. Then AC Adaptor. Finally would be motherboard replacement.
Mike @ compurepair.
Dec 16, 2008 | Toshiba Satellite A100-S8111TD Notebook
Battery charge
the battery is dead. that happened to me and i had 3 choices: 1)buy a new dvd player 2)buy a new recharable battery or 3)keep the portable plugged to the wall while i watch movies. i chose number 3 because i usually just use it at places plugs are available. but yeah, the battery is dead.
Jan 27, 2007 | Insignia I-PD720 Portable DVD Player
Home Logo
29 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
