Question about Transmission & Drivetrain for Chrysler PT Cruiser
Pt cruiser only drives in high gear
Pt cruiser 2002
    Sergeant:
  • 406 Answers
Not much to go from here..is it a stick or auto to start with...are you saying it won'T shift or you can't put Into any other gear..is the engine etc. slowing down or quitting..need more info..sorry...
Posted on Oct 03, 2014
How much coolant goes into the radiator of a 2001 pt cruiser?
Approximate coolant capacity.
2001 to 2002 Chrysler PT Cruiser: 7.2 qt (7 liters)
2003 to 2010 Chrysler PT Cruiser: 6.5 qt (6.2 liters)
Mar 4, 2015
Which coolant for a Chrysler PT Cruiser? - PT Cruiser Repair
pt.cruiser.repair/663/which-coolant-for-a-chrysler-pt-cruiser/
2001 pt cruiser Google Search
Jan 27, 2017 | 2001 Chrysler PT Cruiser
2002 pt cruiser. No reverse. Worked fine yesterday. Today no reverse. All forward gears shift fine.this is an automatic tranny
This is the classic symptom of a failed reverse clutch pack, sorry you will need an overhaul.
Sep 20, 2016 | 2002 Chrysler PT Cruiser
I need a fuse box diagram for a 2002 chrysler pt cruiser limited edition
I am sorry but our diagrams only go back as far as the 2004 model year. I suggest you try eBay for a used owners manual.
Feb 20, 2012 | 2002 Chrysler PT Cruiser
How do I fix low suspenion
If you mean this common problem:
http://www.juhasuomela.com/pt-cruiser/kuvat/alatukivarrenpusla.jpg
Take the lower arm away and replace the rubber bush.
http://www.juhasuomela.com/pt-cruiser/kuvat/alatukivarsi.jpg
If you like drive more than 30,000 miles, you should use urethane bush:
http://www.juhasuomela.com/pt-cruiser/kuvat/uretaani.jpg
May 16, 2011 | 2002 Chrysler PT Cruiser
What does the po 732, 733 and 734 codes mean on a 2002 Chrysler Pt Cruisier?
It means that your input and output shaft speed sensors see an error in the 2nd 3rd and 4th gear final drive ratios during the driving of the vehicle.
Apr 11, 2011 | 2002 Chrysler PT Cruiser
My 2002 pt cruiser won't shift out of low.
the 2nd & 3rd gear solenoid needs replacing. It is mounted by the trans filter inside the trans pan
Jul 27, 2010 | 2002 Chrysler PT Cruiser
PT CRUISER 2002 AUTOMATIC DOESNT CHANGE TO GEAR 3
Take it in & have it scanned, may only be a faulty solenoid or even brake switch may cause code & symptoms. Sooner you get it in, the cheaper it will probably be to repair it
Sep 08, 2009 | 2002 Chrysler PT Cruiser
I hace 02 pt cruiser. while in reverse engine shut down when foot is taken of gas
you might have some wire toughing the ground rabbing when put it in reverse the eng shiftting causing wires to stretch and might touching ground or hot wire
Jul 20, 2009 | 2002 Chrysler PT Cruiser
My 2002 pt cruiser lost power steering suddenly
check to see if the serpantine belt is still there. It sounds like like it broke. this belt runs all of the accesories on the vehicle including the water pump. So if this happened it probably starting running hot too
Jun 23, 2009 | 2002 Chrysler PT Cruiser
Transmission & Drivetrain for Chrysler PT Cruiser Logo
113 people viewed this question
Top Chrysler Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Tim Garcia
Tim Garcia
Are you a Chrysler Vehicle Part and Accessory Expert? Answer questions, earn points and help others
