Question about Maytag Range/Oven Control Board - 5701M403-60
Need part 5700m662-60
Need replacement part or fix for down arrow not working
Up and down arrows on my ti-84 work as left and right arrows on the main screen! how do i fix this?
Remove one of the AAA batteries.
Press and hold CLEAR while reinstalling the AAA battery.
Continue holding CLEAR button and press ON.
Release buttons and press CLEAR again.
Feb 03, 2013 | Texas Instruments TI-84 Plus Silver...
Hi ! Help! The arrow down button does nothing. Arrow up works fine. It is now at 55 percent and I wanted it at 45. It will not arrow down PLEASE tell me how to make it go down! thanks
Turn the Master ON/OFF Switch to OFF and unplug the unit for 15 minutes. This will give the electronics time to revert back to the original factory setting. The plug the unit back in and turn it ON.
When you press the Arrow Down button, do so in increments. Do Not push and hold the button.
If that does not solve the problem, you may need to replace the control panel.
Hope this helped you.
Jul 13, 2011 | Kenmore 54701 Dehumidifier
I have a HP Deskjet 5440 that I replaced the tri-colour cartridge on and the thing just stopped working. Currently the power light is on and the down arrow button sometimes appears flashing in amber (never...
Unplug the power and replug it .
Make sure you removed the protection tape from the cartridge.
Try pressing the down arrow button and see if the error goes away.
In vista right click the printer and select the option Use printer online.
If you need anymore help please let us know.
Rate the answer if it helped.
Thanks
Sep 21, 2009 | HP Deskjet 5440 InkJet Photo Printer
While cleaning must have hit a button, everthing is upside down and can not figure out what to do, HELP
try hitting the ether these combination of Key's to flip the screen back
combs
ctrl+alt+down arrow
ctrl+down arrow
alt+down arrow
if down dosnt work the replace down arrow with up arrow hope this helps
Jul 30, 2009 | ViewSonic E70 17" CRT Monitor
I've been a geek since the late 80s. I've been seeing my Yahoo email database is not working right. I press the down arrow, it goes up. I press the up arrow it goes down. Anything I can do about it?
It sounds like the arrows are in the worng places. Have you checked to make sure that the up arrow is on the up key and the down arrow is on the down key. If not I suggest you do this and either get a replacement keyboard or replace you keys. Either way it is your choice. Let me know if these help.
Jun 13, 2009 | Gateway MT6451 Notebook
Mitsubishi xl8u projector
go to menu and press it---press right or left arrow button and go to installation press enter.
--go down by down arrow to image reverse- use left and right arrow to adjust the image to the correct position.
Mar 15, 2008 | Mitsubishi XL8U Multimedia Projector
Samsung yp-z5 scroll panel stopped working.
This is a common hardware fault with this player. I guess it is why the model has been replaced.
The cheapest solution is to buy a faulty player from ebay - around £10 including postage and replace your faulty one. Make sure to check the faulty one does not have the touchpad fault.
It is straightforward to replace the touchpad.
Oct 23, 2007 | Samsung YP-Z5 MP3 Player
Down button worn out
Check out Kodak for repair costs
Mar 23, 2007 | Kodak EasyShare DX4530 Digital Camera
Maytag Range/Oven Control Board - 5701M403-60 Logo
43 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
