Question about Gaggia Coffee Makers & Espresso Machines
Replacing water level sensor - Gaggia Coffee Makers & Espresso Machines
Lg wf-t1022tp gives a PE error code.
Try this first before replacing any parts or disassembling your LG washer:
- Unplug the washing machine for 1 minute.
- Plug the washing machine back into power.
- Restart the wash cycle.
- The washing machine may now have cleared the PE error code, if not see below...
You will need to check the wiring harness that connects the water level pressure sensor to the main control board.
- Check for a loose wire harness, a damaged wire harness, or a burnt faulty wire.
- Check that you get continuity through the wire harness by checking it with a multimeter.
- If the wire harness from the water level pressure sensor to the main control board is found to be faulty, replace it.
- If you get continuity and the wiring harness is securely connected to both the water level pressure sensor and the main control board, then proceed to the step below...
LG WASHER PE ERROR CODE - FIX METHOD #2
Water Level Pressure Sensor Switch Is Faulty And Needs To Be Cleaned Or Removed And Replaced.
Most commonly, if the wire harness is secure, tight, and not damaged, the part that needs to be checked is the water level pressure sensor.
- First check to be sure the water level pressure sensor is not caked with hard water or other debris.
- If the water level pressure sensor is not clean, the PE error can display.
- Remove the water level pressure sensor from your LG washer and clean off any hard water or debris.
- Clean out the tube that connects to the
- If you found the water level pressure sensor was caked with debris and you have cleaned it, replace it back into the washer and run a test.
- If the washer runs without the PE error code displaying, the washer is fixed and the PE error has been cleared.
- If you find that the water level pressure sensor is faulty, remove it and replace with a new OEM part.
lg-electronics-washing-machine-water-level-sensor-pressure-switch-hth0u4ums0hor52ud1sodlv4-2-1.jpg
Replacing the water level pressure sensor simply involves locating the sensor in your LG washer. Remove it from the washer and replace it with a new genuine LG washer part. Test washer to be sure the PE error code has cleared and the washer is now working properly
Mar 20, 2017 | LG Washing Machines
My hotpoint aquaruis WF630 keeps filling up with water and wont drain
Possible that the water level sensor is faulty and does not detect the SET level to shut the inlet valve and start the program
You can remove the pressure level sensor and test , if faulty replace.
Click this link: level sensor
Jan 16, 2013 | Washing Machines
Water will not stop at the right level.
Possible that the water level sensorr had failed. Now if this fault had come after you had replaced the belt it is possible that a damage or a careless fitting was done. So remove and check the water line to the level control sensor. Also check the wire to sensor and to the program controller unit. If this is open the water level will not be detected.
check for tips: washing machine tips
Jun 25, 2012 | Amana Washing Machines
Set dial and water overflows, doesn't stop sending water in tub, No spin cycle
The water level sensor is faulty and so it does not switch even with water level coming to the set level. Unless the water level switch is triggered the water inflow will not stop because the inlet valve will not cut off.Remove the water level sensor and check if the diaphragm is working , if not it must be replaced.
Mar 13, 2012 | Washing Machines
Hello..My washer has stopped rinsing. the lights have gone out completely and the tub is half full with water. What's the problem with this washer? Any ideas?
I have give the same solution in my other post, here it is :
exactly in the water level sensor, please check the hose that connected to water level sensor, make sure no dirt blocking or clogging the hose. also you can clean the tube under the pulsator, usually there is many dirt blocking the hose line.
the problem is in the hose leading to the water level sensor, if there is no dirt and looks normal, water level sensor must be replaced.246ac89.jpg
Oct 19, 2010 | Washing Machines
Admiral washing machine keeps filling up and will not stop till I turned my water valves off, and then it will not wash the clothes but will spin them .
The water level sensor is faulty. After the inlet valve is opened the program controller needs the signal fromt he water level sensor. Thi is normally a pressure switch and as the water builds up the tub through a small opening the water flows through a tube to trigger the switch. So find out the pressure switch and replace. Only once the sensor clicks will the program proceed to wash . Otherwise you can spin becasue the water level sensor need not work for spinning as the level is down.
Sep 17, 2010 | Admiral Washing Machines
Display says error
I have give the same solution in other post, here it is :
usually problem with semi auto washing machine is on the sensors , exactly in the water level sensor, please check the hose that connected to water level sensor, make sure no dirt blocking or clogging the hose. also you can clean the tube under the pulsator, usually there is many dirt blocking the hose line.
Jul 24, 2010 | LG WM2487H Front Load Washer
Water level sensor
remove the rear panel behind the washer timer switch, the level sensor is there.
Apr 23, 2010 | Maytag PAV2300 Top Load Washer
Washer fill with water won't stop
HI.there is a water fill level pressure switch that is malfunctioning at this point. this switch regulates the fill level(water level). you will need to replace this defective switch asap.
Jun 18, 2009 | Kenmore 22642 Top Load Washer
Coffee Makers & Espresso Machines Logo
Top Gaggia Coffee Makers & Espresso Machines Experts
Oloyede Monsuru
Roger Jackson
Roger Jackson
Level 1 Expert
Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
